#6091 Post by RESET_9999 » Mon Feb 14, 2022 3:56 pm
guys please list the movies that don't work so I can test them too. Sounds like your files or your wifi is the problem. What's your wifi speed test on your cell phone?
I watched one more FEL DT-DL movie last night: Mission impossible 1996. Played from start to end without any issue. This one was converted from ST-DL MKV to DT-DL TS.
FubbAyH
#6092 Post by FubbAyH » Mon Feb 14, 2022 5:36 pm
RESET_9999 wrote: Mon Feb 14, 2022 12:43 am you can test this high bitrate file and rule out your network: https://drive.google.com/file/d/1j0mILN ... sp=sharing
*audio is DD+ and doesn't work.
That played fine so I think the network part of things is okay. I have slow internet but decent local Wi-Fi. I just did a test holding my phone by the X800M2 and got about 400Mbps to my local server.
RESET_9999 wrote: Mon Feb 14, 2022 12:43 am and which movie did you try ? i can try too
Thank you, that's very kind. If you have the titles handy I'd be curious to know if they work for you.
The ones that aren't working for me are:
Dune (2021): fails at about 0:03:06 just after Chani says "why did the emperor choose this path, and who will our next oppressors be?". playback freezes, but the player remains responsive
Back to the Future: fails at about 0:00:28 and player skips to next file in directory
Back to the Future Part II: fails at about 0:08:06 and shortly afterwards (not immediately) the player locks up
I also tried Black Panther and The Matrix and didn't have any problems with those, but I only played a few minutes of each so can't confirm they were definitely working.
After I posted last night I decided to try converting some P8.1 hybrid rips, and those were much more successful. I played one movie (Luca) all the way through with no problems at all, and played about 30 minutes of another (Rogue One) with no problems either. So it looks like it might be the ST-DL to DT-DL conversion that is causing problems for me.
I went to re-rip my Dune disc today and discovered that my drive is now failing :x So I've ordered another and will resume experimenting in a couple of days :)
#6093 Post by RESET_9999 » Mon Feb 14, 2022 5:58 pm
thanks I'll try all of them tonight when I get home....
quite surprised that Dune didnt work because its a MEL movie. The MEL movie with 69kbps EL usually even works in ST-DL TS. My copy is P8 like all the MEL movies I have but I'm downloading the ISO right now and will test every workflow possible :)
#6094 Post by RESET_9999 » Mon Feb 14, 2022 11:32 pm
FubbAyH wrote: Mon Feb 14, 2022 5:36 pm The ones that aren't working for me are:
These 3 movies work flawlessly on my end in all the possible workflow. So it's probably your failing HDD that broke some of your files if I had to guess.
Another possibility (but unlikely) is the different firmware. I bought my player ''pre-owned'' on eBay, so I probably have the old firmware.
IMO the x800m2 is the player I've been looking for since DV remuxes are possible. I'll probably vanish from this forum because my DV needs are met.
Dune ST-DL TS from makemkv ST-P7 = no issue at 3:06
Dune DT-DL TS from makemkv ST-P7 = no issue at 3:06
BTTF I DT-DL from BD = no issue at 28sec
BTTF II DT-DL from BD = no issue at 8:06
I recorded my session:
https://www.youtube.com/watch?v=pHo0wZdqXd4
deadchip12
#6095 Post by deadchip12 » Tue Feb 15, 2022 2:20 am
RESET_9999 wrote: Mon Feb 14, 2022 11:32 pm
So my hope of getting a x800m2 is gone. There's really no place in my country that sells it.
If I have to buy an x700, to get rid of all the green screen or fast forward bug, the correct method is using tsmuxer to mux the original bluray rip to bmdv folder and playing it from root folder of the external hard drive, right? Does this work with every movie out there or there are exceptions and there must be another workflow? Sorry I haven't been able to follow this forum often and all these talks about mel, fel, p7, p8 confuse me.
#6096 Post by RESET_9999 » Tue Feb 15, 2022 2:40 am
deadchip12 wrote: Tue Feb 15, 2022 2:20 am If I have to buy an x700, to get rid of all the green screen or fast forward bug, the correct method is using tsmuxer to mux the original bluray rip to bmdv folder and playing it from root folder of the external hard drive, right? Does this work with every movie out there or there are exceptions and there must be another workflow? Sorry I haven't been able to follow this forum often and all these talks about mel, fel, p7, p8 confuse me.
yes, all the movies in BDMV/USB work on the x700 without the bugs.
DT-DL TS/USB all works as well but with the bug.
I never had a movie that didn't work but to be safe, I recommend always ripping from the original bluray and not from some random MKV torrent.
deadchip12
#6097 Post by deadchip12 » Tue Feb 15, 2022 2:51 am
RESET_9999 wrote: Tue Feb 15, 2022 2:40 am
You mean even muxing to bmdv folder and playing it from root folder won't fix the bugs for these DT-DL movies? Or am I misunderstanding something here...
#6098 Post by RESET_9999 » Tue Feb 15, 2022 2:55 am
deadchip12 wrote: Tue Feb 15, 2022 2:51 am You mean even muxing to bmdv folder and playing it from root folder won't fix the bugs for these DT-DL TS movies?
BDMV playback = bugs free
TS/M2TS playback = bugs
both are DT-DL format.
FubbAyH
#6099 Post by FubbAyH » Tue Feb 15, 2022 3:23 am
RESET_9999 wrote: Mon Feb 14, 2022 11:32 pm These 3 movies work flawlessly on my end in all the possible workflow. So it's probably your failing HDD that broke some of your files if I had to guess.
Thank you again for testing those. That's great news, so I'm hopeful that when I re-rip I'll get the same results. It was actually my Blu-ray drive that is failing now (not my HDD) and my old rips all verified okay so I'm still assuming a software bug somewhere in my workflow is to blame for the differences.
RESET_9999 wrote: Mon Feb 14, 2022 11:32 pm IMO the x800m2 is the player I've been looking for since DV remuxes are possible. I'll probably vanish from this forum because my DV needs are met.
Yes, I'm the feeling the same way, and hoping that this is the endgame. Hopefully we can just replace all 400 pages of this thread with a post that says:
How to make and watch Dolby Vision rips (every other way is a world of pain and misery):
#1 Buy a Sony UBP-X800M2
#2 Make a full-disc decrypted backup using MakeMKV
#3 Find the playlist for the version of the movie you want (it's probably 00800.mpls for the English version)
#4 Drop that into tsMuxer
#5 Set it to output M2TS, and select the audio and subtitle tracks you want
#6 Watch the movie
#7 Be free
#8 Live your life
#9 Never think about Dolby Vision ever again
deadchip12 wrote: Tue Feb 15, 2022 2:20 am So my hope of getting a x800m2 is gone. There's really no place in my country that sells it.
Is it particularly difficult to import things in your country? There do seem to be lots of places that sell the X800M2 and will ship internationally (but I know there are sometimes a few countries that they can't ship to).
Baer2021
#6100 Post by Baer2021 » Tue Feb 15, 2022 12:59 pm
RESET_9999 wrote: Tue Feb 15, 2022 2:55 am
Is this the FF/RW bug you're mentioning? And is that bug only present on the X700 or also present on the UBP-X800M2?
#6101 Post by RESET_9999 » Tue Feb 15, 2022 1:09 pm
Baer2021 wrote: Tue Feb 15, 2022 12:59 pm Is this the FF/RW bug you're mentioning? And is that bug only present on the X700 or also present on the UBP-X800M2?
x700 BDMV= bugs free
x700 TS/M2ts = FF/RW bug and Green/purple Screen bug
x800m2 in both format= bugs free
FubbAyH wrote: Tue Feb 15, 2022 3:23 am How to make and watch Dolby Vision rips (every other way is a world of pain and misery):
#6 Watch the movie
#7 Be free
#8 Live your life
Exactly!!
FubbAyH wrote: Tue Feb 15, 2022 3:23 am Is it particularly difficult to import things in your country? There do seem to be lots of places that sell the X800M2 and will ship internationally (but I know there are sometimes a few countries that they can't ship to).
I got mine from there: https://www.ebay.com/itm/255334121617?e ... Sw2XxhpWAK
looks like they ship almost worldwide...
codeXRes
#6102 Post by codeXRes » Tue Feb 15, 2022 1:27 pm
Great news! I'll start looking for an X800M2.
Slightly off topic, I'm also looking to upgrade my to TV to an OLED - preferably LG CX or C1. C1 is obviously newer but more expensive, so I'm leaning towards CX. Any idea if there are any known issues with either of them regarding DV playback? Many thanks.
Baer2021
#6103 Post by Baer2021 » Tue Feb 15, 2022 2:40 pm
Thanks for the advice on the X800M2. The price has been under $200 a few times in the last year, but for some reason jumped up to like $329 in the last few weeks. Will probably wait a while until it goes on sale again to pick it up as a secondary player along with my Oppo.
ArArdin
#6104 Post by ArArdin » Tue Feb 15, 2022 2:44 pm
@RESET_9999
Hi, I'm thinking about buying a X800M2 for another room but am bothered with something. In a Dutch online review I read that Dolby Vision video isn't auto-recognised and you have to enable it in the menu. Which isn't a problem of course. But when enabled, the X800M2 is said to output every HDR content in a form of DV. Which wouldn't be without noticeable artifacts for non-DV content. Consequently, a user should switch between disabling/enabling DV for every other occasion.
Can you confirm this behavior? Because this review is a few years old, I actually imagine the issues are solved with later FW.
#6105 Post by RESET_9999 » Tue Feb 15, 2022 2:51 pm
ArArdin wrote: Tue Feb 15, 2022 2:44 pm @RESET_9999
yes, this is true and still the case for USB and disc playback.
But with file playback via the network , somehow the player displays SDR/HDR10/DV in their native dynamic range.
