#6091 Post by RESET_9999 » Mon Feb 14, 2022 11:32 pm
FubbAyH wrote: Mon Feb 14, 2022 5:36 pm The ones that aren't working for me are:
Dune (2021): fails at about 0:03:06 just after Chani says "why did the emperor choose this path, and who will our next oppressors be?". playback freezes, but the player remains responsive
Back to the Future: fails at about 0:00:28 and player skips to next file in directory
Back to the Future Part II: fails at about 0:08:06 and shortly afterwards (not immediately) the player locks up
These 3 movies work flawlessly on my end in all the possible workflow. So it's probably your failing HDD that broke some of your files if I had to guess.
Another possibility (but unlikely) is the different firmware. I bought my player ''pre-owned'' on eBay, so I probably have the old firmware.
IMO the x800m2 is the player I've been looking for since DV remuxes are possible. I'll probably vanish from this forum because my DV needs are met.
Dune ST-DL TS from makemkv ST-P7 = no issue at 3:06
Dune DT-DL TS from makemkv ST-P7 = no issue at 3:06
BTTF I DT-DL from BD = no issue at 28sec
BTTF II DT-DL from BD = no issue at 8:06
I recorded my session:
https://www.youtube.com/watch?v=pHo0wZdqXd4
deadchip12
#6092 Post by deadchip12 » Tue Feb 15, 2022 2:20 am
RESET_9999 wrote: Mon Feb 14, 2022 11:32 pm
So my hope of getting a x800m2 is gone. There's really no place in my country that sells it.
If I have to buy an x700, to get rid of all the green screen or fast forward bug, the correct method is using tsmuxer to mux the original bluray rip to bmdv folder and playing it from root folder of the external hard drive, right? Does this work with every movie out there or there are exceptions and there must be another workflow? Sorry I haven't been able to follow this forum often and all these talks about mel, fel, p7, p8 confuse me.
#6093 Post by RESET_9999 » Tue Feb 15, 2022 2:40 am
deadchip12 wrote: Tue Feb 15, 2022 2:20 am If I have to buy an x700, to get rid of all the green screen or fast forward bug, the correct method is using tsmuxer to mux the original bluray rip to bmdv folder and playing it from root folder of the external hard drive, right? Does this work with every movie out there or there are exceptions and there must be another workflow? Sorry I haven't been able to follow this forum often and all these talks about mel, fel, p7, p8 confuse me.
yes, all the movies in BDMV/USB work on the x700 without the bugs.
DT-DL TS/USB all works as well but with the bug.
I never had a movie that didn't work but to be safe, I recommend always ripping from the original bluray and not from some random MKV torrent.
deadchip12
#6094 Post by deadchip12 » Tue Feb 15, 2022 2:51 am
RESET_9999 wrote: Tue Feb 15, 2022 2:40 am
You mean even muxing to bmdv folder and playing it from root folder won't fix the bugs for these DT-DL movies? Or am I misunderstanding something here...
#6095 Post by RESET_9999 » Tue Feb 15, 2022 2:55 am
deadchip12 wrote: Tue Feb 15, 2022 2:51 am You mean even muxing to bmdv folder and playing it from root folder won't fix the bugs for these DT-DL TS movies?
BDMV playback = bugs free
TS/M2TS playback = bugs
both are DT-DL format.
FubbAyH
#6096 Post by FubbAyH » Tue Feb 15, 2022 3:23 am
RESET_9999 wrote: Mon Feb 14, 2022 11:32 pm These 3 movies work flawlessly on my end in all the possible workflow. So it's probably your failing HDD that broke some of your files if I had to guess.
Thank you again for testing those. That's great news, so I'm hopeful that when I re-rip I'll get the same results. It was actually my Blu-ray drive that is failing now (not my HDD) and my old rips all verified okay so I'm still assuming a software bug somewhere in my workflow is to blame for the differences.
RESET_9999 wrote: Mon Feb 14, 2022 11:32 pm IMO the x800m2 is the player I've been looking for since DV remuxes are possible. I'll probably vanish from this forum because my DV needs are met.
Yes, I'm the feeling the same way, and hoping that this is the endgame. Hopefully we can just replace all 400 pages of this thread with a post that says:
How to make and watch Dolby Vision rips (every other way is a world of pain and misery):
#1 Buy a Sony UBP-X800M2
#2 Make a full-disc decrypted backup using MakeMKV
#3 Find the playlist for the version of the movie you want (it's probably 00800.mpls for the English version)
#4 Drop that into tsMuxer
#5 Set it to output M2TS, and select the audio and subtitle tracks you want
#6 Watch the movie
#7 Be free
#8 Live your life
#9 Never think about Dolby Vision ever again
deadchip12 wrote: Tue Feb 15, 2022 2:20 am So my hope of getting a x800m2 is gone. There's really no place in my country that sells it.
Is it particularly difficult to import things in your country? There do seem to be lots of places that sell the X800M2 and will ship internationally (but I know there are sometimes a few countries that they can't ship to).
Baer2021
#6097 Post by Baer2021 » Tue Feb 15, 2022 12:59 pm
RESET_9999 wrote: Tue Feb 15, 2022 2:55 am
Is this the FF/RW bug you're mentioning? And is that bug only present on the X700 or also present on the UBP-X800M2?
#6098 Post by RESET_9999 » Tue Feb 15, 2022 1:09 pm
Baer2021 wrote: Tue Feb 15, 2022 12:59 pm Is this the FF/RW bug you're mentioning? And is that bug only present on the X700 or also present on the UBP-X800M2?
x700 BDMV= bugs free
x700 TS/M2ts = FF/RW bug and Green/purple Screen bug
x800m2 in both format= bugs free
FubbAyH wrote: Tue Feb 15, 2022 3:23 am How to make and watch Dolby Vision rips (every other way is a world of pain and misery):
#6 Watch the movie
#7 Be free
#8 Live your life
Exactly!!
FubbAyH wrote: Tue Feb 15, 2022 3:23 am Is it particularly difficult to import things in your country? There do seem to be lots of places that sell the X800M2 and will ship internationally (but I know there are sometimes a few countries that they can't ship to).
I got mine from there: https://www.ebay.com/itm/255334121617?e ... Sw2XxhpWAK
looks like they ship almost worldwide...
codeXRes
#6099 Post by codeXRes » Tue Feb 15, 2022 1:27 pm
Great news! I'll start looking for an X800M2.
Slightly off topic, I'm also looking to upgrade my to TV to an OLED - preferably LG CX or C1. C1 is obviously newer but more expensive, so I'm leaning towards CX. Any idea if there are any known issues with either of them regarding DV playback? Many thanks.
Baer2021
#6100 Post by Baer2021 » Tue Feb 15, 2022 2:40 pm
Thanks for the advice on the X800M2. The price has been under $200 a few times in the last year, but for some reason jumped up to like $329 in the last few weeks. Will probably wait a while until it goes on sale again to pick it up as a secondary player along with my Oppo.
ArArdin
#6101 Post by ArArdin » Tue Feb 15, 2022 2:44 pm
@RESET_9999
Hi, I'm thinking about buying a X800M2 for another room but am bothered with something. In a Dutch online review I read that Dolby Vision video isn't auto-recognised and you have to enable it in the menu. Which isn't a problem of course. But when enabled, the X800M2 is said to output every HDR content in a form of DV. Which wouldn't be without noticeable artifacts for non-DV content. Consequently, a user should switch between disabling/enabling DV for every other occasion.
Can you confirm this behavior? Because this review is a few years old, I actually imagine the issues are solved with later FW.
#6102 Post by RESET_9999 » Tue Feb 15, 2022 2:51 pm
ArArdin wrote: Tue Feb 15, 2022 2:44 pm @RESET_9999
yes, this is true and still the case for USB and disc playback.
But with file playback via the network , somehow the player displays SDR/HDR10/DV in their native dynamic range.
AndreasT
#6103 Post by AndreasT » Tue Feb 15, 2022 3:36 pm
I had a look into the users-guide for the x800m2, and on page 36 of the English language version it says;
• The player can support video bit rate up to 40 Mbps
4th bullet point from the bottom of the right hand side column.
Is that a limitation to be worried about? Isn't it normal for a modern 4k+HDR title to have a video bit rate higher than that?
#6104 Post by RESET_9999 » Tue Feb 15, 2022 3:43 pm
AndreasT wrote: Tue Feb 15, 2022 3:36 pm • The player can support video bit rate up to 40 Mbps
sickb
#6105 Post by sickb » Tue Feb 15, 2022 8:03 pm
Replaced my switch and cabling today, and the 800M2 seems to fare better so far.
Sometimes I have truehd movies start without audio, but when I FF/RWD a bit, it works.
