Tammy and the T-Rex
Mountainmohawk
Tammy and the T-Rex
Post by Mountainmohawk » Tue Feb 08, 2022 4:28 am
Hey All,
I'm having trouble ripping this movie in particular, but have had some issues with other 4k discs too. I've tried cleaning the discs and making sure there wasn't any dirt in the drive either, but still no luck. Below is my drive information and the error with the rip.
OS device name: H:
Product: BD-RE BU40N
Revision: 1.00
Serial number: MO7JAII2722
Firmware date: 2116-12-20 15:28
Highest AACS version: 76
Firmware version: 1.00
Disc Information
Label: TAMMY AND THE TREX UHD
Timestamp: 2019-11-08 21:09:46
Protection: AACS2.0/C v72
Data capacity: 57.90 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
And here is the error log for the rip
Saving 1 titles into directory Z:/Movies/Tammy and the T-Rex (1993)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '28556918784'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom8' at offset '28556918784'
DEBUG: Code 3221225628 at |v@gGwTzroP3Y(T6Kw:29395149
DEBUG: Code 100864261 at |v@gGwTzroP3Y(T6Kw:29395149
DEBUG: Code 0 at O{]l*x<upg.5#Kt)+A?Z:29395471
DEBUG: Code 0 at +j,$qy}{6LI[t,':zp\x:29394068
DEBUG: Code 0 at O{]l*x<upg.5#Kt)+A?Z:213131157
DEBUG: Code 0 at O{]l*x<upg.5#Kt)+A?Z:121262647
DEBUG: Code 13943808 at O{]l*x<upg.5#Kt)+A?Z:121261773
DEBUG: Code 0 at _Y+8iB|^MtysP|GFt:}V/:213137068
DEBUG: Code 0 at ;_f9#/b4hPJ&JP1#8pml:29394022
DEBUG: Code 0 at ;_f9#/b4hPJ&JP1#8pml:29404878
DEBUG: Code 0 at ;_f9#/b4hPJ&JP1#8pml:29405384
DEBUG: Code 0 at ;_f9#/b4hPJ&JP1#8pml:29403383
DEBUG: Code 0 at 5'}E6Z2XsHwf;,OGn>lz:213140863
DEBUG: Code 0 at 3B#\%:BlUEu3k2A;:213132537
DEBUG: Code 0 at ?X91v,pcw_IIt^>v7:121264464
DEBUG: Code 0 at ?X91v,pcw_IIt^>v7:121263912
DEBUG: Code 0 at ?X91v,pcw_IIt^>v7:213130145
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file Z:/Movies/Tammy and the T-Rex (1993)/title_t00.mkv
Encountered 26 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Mounty1997
Re: Tammy and the T-Rex
Post by Mounty1997 » Wed Feb 09, 2022 7:11 pm
Hi
Im getting the same issue with 'No Time To Die'. Other discs work fine.
Protection: AACS2.0/C v76
Revision: 1.04
Can anyone let me know if its my drive or is the AACS version higher than MakeMKV can currently do
Saved AACS dump file as C:\Users\mount/.MakeMKV/MKB20_v76_No_Time_to_Die_7BE7.tgz
Post by Billycar11 » Wed Feb 09, 2022 10:45 pm
Hi
Revision: 1.04
Do you have contacting webserver for updates enabled?
Post by dcoke22 » Thu Feb 10, 2022 5:38 am
Hey All,
Is your drive in an external enclosure and powered by USB? If so, are both cables connected? And if so, are the directly connected to your computer or to a powered USB hub? MakeMKV can make a drive work hard enough that it exceeds how much power a single USB plug can provide.
Mounty1997
Post by Mounty1997 » Fri Feb 11, 2022 8:39 am
Hi
Revision: 1.04
Yep. It appears to be enabled. I have tried MakeMKV on different machines and same issue. I know my disc drive is supported so im a bit lost to why this blu-ray in particular wont rip :/
Post by Billycar11 » Fri Feb 11, 2022 11:54 am
post your makemkv drive info just so we can double check
Mounty1997
Post by Mounty1997 » Sun Feb 13, 2022 4:01 pm
Here's the device info. Thanks
Revision: 1.04
Serial number: MO4L66B5100
Firmware date: 2120-05-06 11:42
Post by Billycar11 » Sun Feb 13, 2022 11:28 pm
Revision: 1.04
The full drive info where it says the libre drive status and stuff too
Mounty1997
Post by Mounty1997 » Mon Feb 14, 2022 2:41 pm
Revision: 1.04
Apologies. Here's the full section. Thanks
Revision: 1.04
Harware support: Yes
Firmware support: No
Firmware version: 1.04
Post by Billycar11 » Mon Feb 14, 2022 2:45 pm
Revision: 1.04
You need to flash that drive to do UHD you have never done any UHD with it.
See the guide below or email me for an automated flasher
