HLDS WH16NS60 SVC Number
rwbryant
Post by rwbryant »
Is there any way to determine the SVC number of my HLDS WH16NS60 that I just purchased without cracking open my PC? I didn't realize I needed that info before installing the drive. Thanks in advance for any help! Here is the info on my drive from MakeMKV:
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: <Removed>
Firmware date: 2120-05-08 10:10
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Re: HLDS WH16NS60 SVC Number
You are good to go to flash.
rwbryant wrote: Sun Feb 13, 2022 11:12 pm Is there any way to determine the SVC number of my HLDS WH16NS60 that I just purchased without cracking open my PC? I didn't realize I needed that info before installing the drive. Thanks in advance for any help! Here is the info on my drive from MakeMKV:
Revision: 1.03
You don't need to worry about the SVC code for the NS60 drives. The SVC code is NS60.
Just flash it directly to WH16NS60 1.02-MK firmware using "enc" as the stock 1.03 firmware is encrypted.
hardcore_gamer29
Post by hardcore_gamer29 »
Revision: 1.03
see my post i jut downgraded my wh16ns60 a few days ago successfully
viewtopic.php?f=16&t=27332
