#6076 Post by RESET_9999 » Sat Feb 12, 2022 10:49 pm
ok after a bit more tests. The DT-DL TS files that wont play are the ones made from an MKV (mkvtoolnix) that has both layers in two different tracks( not merged into P7 ST, the early remux on rarbg )...
But if your source is an untouched bluray folders or a ST-DL P7 MKV made with makemkv or yusesope tool, it can be demuxed and remuxed into a working DT-DL TS.
EDIT:. if I remux the dual-track mkv to ISO first and then to DT-DL TS, it works.
sickb
#6077 Post by sickb » Sun Feb 13, 2022 10:41 am
RESET_9999 wrote: Sat Feb 12, 2022 10:49 pm EDIT:. if I remux the dual-track mkv to ISO first and then to DT-DL TS, it works.
Great, I remuxed the dtdl dovi test from mp4 to ts and this also plays now.
#6078 Post by RESET_9999 » Sun Feb 13, 2022 5:08 pm
So far so good. I watched 5 DV movies (FEL P7 and MEL P8) already with the 5ghz wifi and not a single issue. FF/RW on the wifi is as fast as my x700 USB. My router is only 15 feet away from my player.
No dual-track green/purple screen and no long movie FF/RW bug is so great!!
No DD+ support (except atmos) is not a big problem, I just use my C8 internal plex app. Same for cropped content.
Also, I FF to the ending credit of Power Rangers just to make sure FEL stays in sync (Chromecast loses FEL sync when you FF) and no issue there, Bright white text without any ghosting.
I also like the fact that the x800m2 is pickier than the x700 about what works (or not) because I noticed that when a DV file is broken, the x700 will still play it in DV but the RPU doesn't work at all(fel still works tho).
The x800m2 will just refuse to play the broken DV file. I much prefer this behavior and I fear I may have watched fake DV on the x700 with some particular files.
sickb
#6079 Post by sickb » Sun Feb 13, 2022 8:06 pm
Does anyone have an idea why I get different results in the DV enabled ST-DL video track when I follow these workflows:
Source: Ghostbusters Afterlife [MEL]
a)
- Use MakeMKV directly on the blu-ray
vs:
b)
- First mux the blu-ray to TS with TSMuxer
- Then mux the TS to blu-ray with TSMuxer
- Use MakeMKV on the blu-ray created by TSMuxer
for the same movie,
in the first case I have a 49.3mb/s 42.7gb video track
in the seco case I have a 48.0mb/s 41.6gb video track
I know workflow b) seems odd at first sight, but I wish I could store just the TS, and then get the (correct) MKV at any time when I need it.
Now instead I need to keep the blu-ray arround, convert to TS to watch on X800M2, and convert to MKV for other purposes.
#6080 Post by RESET_9999 » Sun Feb 13, 2022 8:50 pm
sickb wrote: Sun Feb 13, 2022 8:06 pm Source: Ghostbusters Afterlife [MEL]
I don't know about your question but in the case of a MEL movie like Ghostbusters , the best way is to convert profile 8 and your TS will work everywhere.
so p8 for mel and p7 for fel, that's what I do.
ArArdin
#6081 Post by ArArdin » Sun Feb 13, 2022 8:57 pm
sickb wrote: Sun Feb 13, 2022 8:06 pm Does anyone have an idea why I get different results...
That's weird indeed. Maybe waste of space in MEL that tsMuxer would solve when muxing? I recently had a title with 1.6 GB MEL, of which RPU was 36MB. You can of course investigate by demuxing BL and EL from both mkvs and compare sizes.
Even better of course is what RESET_9999 suggested and convert to Profile 8.1 "BL+RPU". You'll have no EL at all.
FubbAyH
#6082 Post by FubbAyH » Sun Feb 13, 2022 11:12 pm
I had a chance to play with my X800M2 today and my experience wasn't quite as good, but I've still got more investigating to do.
Every M2TS I tried to play worked fine to start with, with DV recognized and sent correctly to the TV. Unfortunately most of the files failed at some point during playback: either they just stopped playing (and the player went on to the next file in the folder), or more concerningly they locked up the player and it had to be power cycled. Sometimes it happened within 30 seconds, and sometimes the movie played fine for ~10 minutes before failing. The failure always seemed to happen at the same point in the title, so it looks like there's something in my files that the player doesn't like.
Now I'm not devastated, because all my M2TS files were converted from MKV, and so those files have been through a bunch of different tools at various points in their lives, and it seems very plausible that some bug in some version of any one of tools could have broken the strict conformance that a UHDBD player needs.
So my next step is going to be to try re-ripping straight from a full disc backup with tsMuxer and hopefully that will give the same good results that @RESET_9999 is having. I'll report back whatever happens (might be next weekend at this point).
Some other observations about the X800M2:
I had the FEL_test_for_AVS.mp4 file handy so I tried that on a whim and it surprised me by playing fine with RPU and FEL both visibly working. Obviously that's not a full movie so I don't know if it MP4 FEL playback would be completely reliable, and I didn't investigate which audio formats would be supported.
The quality of the player seems pretty good. I like the remote and the setup menus are mostly clear and comprehensive. The on-screen playback info display is extremely useful with the way it shows the source video and audio formats and current bitrates, and what formats the player is outputting. I'd give the interface responsiveness of the player a B- grade. It's a lot better than the Zidoo z9x, but not in the same league as Apple TV or LG TVs. The interface is rendered in a crappy resolution (maybe even less than 1080p?) and upscaled, which made me think the player wasn't outputting 4K at first.
I thought I might be able to get away with using the 100Mbps Ethernet, but got stuttering very quickly in the second file I tried (Back to the Future Part II, which works well for testing that because it has very high bitrate scenes in the first couple of minutes). I switched to Wi-Fi, though, and that does seem to be working well. It's connecting at ~300 Mbps to my access point about 6m away.
My favorite feature of the player so far is the Bluetooth audio support, which seems to work fantastically. The player has the neat capability of outputting audio over HDMI and Bluetooth simultaneously, which is great for verifying that lipsync is correct, and it seemed perfect in my testing. The quality sounded superb on my WH-1000XM2 headphones, presumably because they and the player both support Sony's high bitrate LDAC codec. I did all my tests with Bluetooth audio disabled too, just in case that was the cause, and it didn't seem to make any difference: everything that failed with Bluetooth audio on also failed with it off.
FubbAyH
#6083 Post by FubbAyH » Sun Feb 13, 2022 11:16 pm
nekno wrote: Sat Feb 12, 2022 1:37 am Encoding DTS-HD takes in a lossless LPCM stream, encodes a lossy DTS core, and saves the rest of the discarded audio as lossless extensions. When decoding, the extensions are recombined with the lossy DTS core and decoded to arrive at the original lossless stream.
A TrueHD+AC3 track has audio frames alternating between TrueHD and AC3. It's just two completely separate streams interleaved into a single track, kind of how STDL puts two distinct video streams into separate NALUs of a single track.
Thank you for the superb explanation. I guess I had a vague memory about how DTS-HD works and assumed that TrueHD worked the same way.
nekno wrote: Sat Feb 12, 2022 1:37 am The mlp tool for accurately/losslessly editing THD streams has an open issue requesting support, but there's no activity on it.
I hadn't heard of that tool, and didn't know about the old MakeMKV bug that it was made to address, so now I have even more re-ripping to do :lol:
#6084 Post by RESET_9999 » Sun Feb 13, 2022 11:29 pm
FubbAyH wrote: Sun Feb 13, 2022 11:12 pm I didn't investigate which audio formats would be supported.
only dd+ without a core doesn't work. And strangely DD+ Atmos (without a core too) works.
and yep ripping from a disc is the way to go, thankfully 95% of my movie library was done from untouched bluray folders
did you convert to DT-DL ?
FubbAyH wrote: Sun Feb 13, 2022 11:12 pm I had the FEL_test_for_AVS.mp4 file handy so I tried that on a whim and it surprised me by playing fine with RPU and FEL both visibly working. Obviously that's not a full movie so I don't know if it MP4 FEL playback would be completely reliable, and I didn't investigate which audio formats would be supported.
I checked a movie. Power Rangers ending credit is bright white in FEL and dark grey in MEL/HDR10
FubbAyH wrote: Sun Feb 13, 2022 11:16 pm I hadn't heard of that tool, and didn't know about the old MakeMKV bug that it was made to address, so now I have even more re-ripping to do :lol:
Tsmuxer also handles seamless disc perfectly. No poping in Atmos track
FubbAyH
#6085 Post by FubbAyH » Mon Feb 14, 2022 12:03 am
RESET_9999 wrote: Sun Feb 13, 2022 11:29 pm and yep ripping from a disc is the way to go, thankfully 95% of my movie library was done from untouched bluray folders
Yep, all my test movies were DT-DL converted from ST-DL MKVs.
RESET_9999 wrote: Sun Feb 13, 2022 11:29 pm Tsmuxer also handles seamless disc perfectly. No poping in Atmos track
I'm very glad to hear that, I was just about to look it up! :D
#6086 Post by RESET_9999 » Mon Feb 14, 2022 12:43 am
you can test this high bitrate file and rule out your network: https://drive.google.com/file/d/1j0mILN ... sp=sharing
*audio is DD+ and doesn't work.
and which movie did you try ? i can try too
FubbAyH wrote: Mon Feb 14, 2022 12:03 am
sickb
#6087 Post by sickb » Mon Feb 14, 2022 3:21 pm
FubbAyH wrote: Sun Feb 13, 2022 11:12 pm I had a chance to play with my X800M2 today and my experience wasn't quite as good, but I've still got more investigating to do.
I'm having a similar experience, may just be my wifi and or my DLNA messing up at times.
Also I can't seem to CEC control the player with my LG remote.. only the menus.
I'm going to compare with an M9203 oppo clone (1gbps lan etc).
#6088 Post by RESET_9999 » Mon Feb 14, 2022 3:56 pm
guys please list the movies that don't work so I can test them too. Sounds like your files or your wifi is the problem. What's your wifi speed test on your cell phone?
I watched one more FEL DT-DL movie last night: Mission impossible 1996. Played from start to end without any issue. This one was converted from ST-DL MKV to DT-DL TS.
FubbAyH
#6089 Post by FubbAyH » Mon Feb 14, 2022 5:36 pm
RESET_9999 wrote: Mon Feb 14, 2022 12:43 am you can test this high bitrate file and rule out your network: https://drive.google.com/file/d/1j0mILN ... sp=sharing
That played fine so I think the network part of things is okay. I have slow internet but decent local Wi-Fi. I just did a test holding my phone by the X800M2 and got about 400Mbps to my local server.
RESET_9999 wrote: Mon Feb 14, 2022 12:43 am and which movie did you try ? i can try too
Thank you, that's very kind. If you have the titles handy I'd be curious to know if they work for you.
The ones that aren't working for me are:
Dune (2021): fails at about 0:03:06 just after Chani says "why did the emperor choose this path, and who will our next oppressors be?". playback freezes, but the player remains responsive
Back to the Future: fails at about 0:00:28 and player skips to next file in directory
Back to the Future Part II: fails at about 0:08:06 and shortly afterwards (not immediately) the player locks up
I also tried Black Panther and The Matrix and didn't have any problems with those, but I only played a few minutes of each so can't confirm they were definitely working.
After I posted last night I decided to try converting some P8.1 hybrid rips, and those were much more successful. I played one movie (Luca) all the way through with no problems at all, and played about 30 minutes of another (Rogue One) with no problems either. So it looks like it might be the ST-DL to DT-DL conversion that is causing problems for me.
I went to re-rip my Dune disc today and discovered that my drive is now failing :x So I've ordered another and will resume experimenting in a couple of days :)
#6090 Post by RESET_9999 » Mon Feb 14, 2022 5:58 pm
thanks I'll try all of them tonight when I get home....
quite surprised that Dune didnt work because its a MEL movie. The MEL movie with 69kbps EL usually even works in ST-DL TS. My copy is P8 like all the MEL movies I have but I'm downloading the ISO right now and will test every workflow possible :)
