bluray quality
hardcore_gamer29
bluray quality
Post by hardcore_gamer29 »
is there any advantage of buying bluray disk and playing on pc over streaming services like amazon prime in terms of video quality? or both offer exactly the same quality?
Re: bluray quality
Blurays are much higher quality on streaming services your lucky to get a bitrate of 15Mbps
regular blurays are at least double that and UHD bluray can peak over 100Mbps
Re: bluray quality
To echo what Billycar11 said… if you buy a movie on iTunes (or whatever) and download it, you'll end up with a file around 5GB. That same movie ripped from a blu-ray will be about 30GB.
hardcore_gamer29
Re: bluray quality
thanks for clarification
