The French Dispatch - which title?
tondef
Post by tondef » Sat Feb 12, 2022 10:44 pm
I have the blu-ray disc of The French Dispatch and two titles seem nearly identical. Both 27.0 GB and 18 chapters. They are 00800.mpls and 01664.mpls. Below is the log.
Thank you!
Debug log started at Sat Feb 12 22:12:25 2022 , written by MakeMKV v1.16.5 darwin(x64-release)
001005:0000 MakeMKV v1.16.5 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/tony/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.54.0/SecureTransport (x86_64-apple-darwin16.0) , proxy server not set.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE  WH16NS60 1.00 KL6J9NL2139" opened in DASPI v1.5 mode.
002014:0000 Optical drive "BD-ROM HL-DT-ST BDDVDRW UH12NS30 1.03 K9GFBJD1503" opened in DASPI v1.5 mode.
SDF  v082: HL-DT-ST_BD-RE__WH16NS60_1.00_211704251756_KL6J9NL2139
SDF  v082: HL-DT-ST_BDDVDRW_UH12NS30_1.03_211404241900_K9GFBJD1503
001003:0020 DEBUG: Code 0 at pl?NW7g&O)x$%.,Siy^xcN%.8:121263314
DEBUG: Code 0 at T(jk*.ybc.3^x8nmsB9.@{^6v:29394344
001011:0000 Using LibreDrive mode (v06.3 id=4FBA32AEC678)
DEBUG: Code 2147483648 at Qf$x9S0z@vSRd|Sf:121264625
Found java version=1.8.0.321 path=/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Found java version=1.8.0 path=/Applications/Xcode.app/Contents/Applications/Application Loader.app/Contents/itms/java/bin/java
003344:0000 Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
001003:0020 DEBUG: Code 0 at !Q\8nH)^+ZrE$T+C-):213139759
DEBUG: Code 0 at !Q\8nH)^+ZrE$T+C-):213130973
DEBUG: Code 0 at !Q\8nH)^+ZrE$T+C-):121261451
001003:0020 DEBUG: Code 0 at 9=U@:9j|MGM';:x:121262371
001003:0020 DEBUG: Code 0 at E>)^WXTao%kW$FZUYRV :213132353
001003:0020 DEBUG: Code 0 at E>)^WXTao%kW$FZUYRV :121264257
DEBUG: Code 0 at E>)^WXTao%kW$FZUYRV :121267569
001003:0020 DEBUG: Code 0 at E>)^WXTao%kW$FZUYRV :29397035
DISCID=77B3F91AF44C73AFA4E73AE8A0FBFF1AC3C7ABB2
003025:0000 Title #01113.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01460.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01468.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01481.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #0
003307:0000 File 00149.mpls was added as title #1
003025:0000 Title #01355.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00805.mpls is equal to title 00800.mpls and was skipped
003025:0000 Title #01525.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01527.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01528.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01529.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01530.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01531.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01532.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01533.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01534.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01535.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01536.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01537.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01538.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01539.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01540.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01541.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01542.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01543.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01544.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01545.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01546.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01547.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01548.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01549.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01550.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01551.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01552.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01553.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01554.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01555.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01556.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01557.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01558.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01559.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01560.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01561.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01562.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01563.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01564.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01565.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01566.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01567.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01568.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01569.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01570.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01571.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01572.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01573.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01574.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01575.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01576.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01577.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01578.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01579.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01580.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01581.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01582.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01583.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01584.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01585.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01586.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01587.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01588.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01589.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01590.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01591.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01592.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01593.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01594.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01595.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01596.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01597.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01598.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01599.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01600.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01601.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01602.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01603.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01604.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01605.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01606.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01607.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01664.mpls was added as title #2
003025:0000 Title #00165.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00256.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00257.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00264.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00570.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00572.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00573.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00574.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00575.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00576.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00577.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00578.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00579.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00580.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00581.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00586.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00582.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00583.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00584.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00585.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00587.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00588.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00589.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00590.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00591.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00592.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00593.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00594.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00595.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00596.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00597.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00598.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00599.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00600.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00601.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00602.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00603.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00604.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00607.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00608.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00609.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00610.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00611.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00612.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00615.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00605.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00606.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00613.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00614.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00616.m2ts was added as title #3
003307:0000 File 00617.m2ts was added as title #4
003025:0000 Title #00618.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00619.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00620.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00621.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00622.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00623.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00624.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00625.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00626.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00627.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00628.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00629.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00630.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00631.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00632.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00633.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00634.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00635.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00636.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00637.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00638.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00639.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00640.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00641.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00642.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00643.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00644.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00645.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00646.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00647.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00648.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00649.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00650.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00651.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00654.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00655.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00656.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00657.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00658.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00659.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00660.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00661.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00662.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00663.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00665.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00666.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00667.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00668.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00669.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00670.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00671.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00672.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00673.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00674.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00675.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00676.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00677.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00678.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00679.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00680.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00681.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00682.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00683.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00684.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00685.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00686.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00687.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00688.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00689.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00690.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00691.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00692.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00693.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00694.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00695.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00696.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00697.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00698.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00699.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00700.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00701.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00702.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00703.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00704.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00706.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00707.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00708.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00709.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00710.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00258.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00726.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00728.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00281.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00282.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00283.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00284.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00285.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00286.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00287.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00288.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00289.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00290.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00291.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00292.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00293.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00294.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00295.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00296.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00297.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00298.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00299.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00300.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00301.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00302.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00303.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00304.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00305.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00306.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00307.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00308.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00309.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00310.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00311.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00312.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00313.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00314.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00315.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00316.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00317.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00318.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00319.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00320.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00434.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00487.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00489.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00491.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00493.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00495.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00497.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00499.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00501.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00503.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00505.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00507.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00509.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00511.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00513.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00515.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00517.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00519.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00521.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00523.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00525.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00527.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00528.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00530.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00532.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00534.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00536.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00538.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00540.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00542.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00544.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00546.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00548.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00550.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00552.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00554.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00556.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00558.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00560.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00562.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00564.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00566.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00729.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00730.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00731.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00732.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00733.m2ts was added as title #5
003025:0000 Title #00734.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00735.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00736.m2ts was added as title #6
003307:0000 File 00737.m2ts was added as title #7
003025:0000 Title #00738.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00739.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00740.m2ts was added as title #8
003307:0000 File 00741.m2ts was added as title #9
003307:0000 File 00742.m2ts was added as title #10
003307:0000 File 00743.m2ts was added as title #11
003307:0000 File 00744.m2ts was added as title #12
003025:0000 Title #00745.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00746.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00747.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00748.m2ts was added as title #13
003307:0000 File 00749.m2ts was added as title #14
003025:0000 Title #00750.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00751.m2ts was added as title #15
003307:0000 File 00752.m2ts was added as title #16
003307:0000 File 00753.m2ts was added as title #17
003025:0000 Title #00754.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00755.m2ts was added as title #18
003025:0000 Title #00756.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00757.m2ts was added as title #19
003307:0000 File 00758.m2ts was added as title #20
003025:0000 Title #00759.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00760.m2ts was added as title #21
003307:0000 File 00761.m2ts was added as title #22
003025:0000 Title #00762.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00763.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00764.m2ts was added as title #23
003025:0000 Title #00767.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00768.m2ts was added as title #24
003025:0000 Title #00769.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00770.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00771.m2ts was added as title #25
003307:0000 File 00772.m2ts was added as title #26
003025:0000 Title #00773.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00774.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00775.m2ts was added as title #27
003307:0000 File 00776.m2ts was added as title #28
003307:0000 File 00777.m2ts was added as title #29
003307:0000 File 00778.m2ts was added as title #30
003307:0000 File 00779.m2ts was added as title #31
003025:0000 Title #00780.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00781.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00782.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00783.m2ts was added as title #32
Re: The French Dispatch - which title?
Post by Woodstock » Sun Feb 13, 2022 3:05 pm
Choose 00800.mpls if you want English.
