nekno
#6061 Post by nekno » Sat Feb 12, 2022 1:37 am
FubbAyH wrote: Fri Feb 11, 2022 11:04 pm
RESET_9999 wrote: Fri Feb 11, 2022 3:09 pm this seems to take the same processing time as converting the core to regular 640kbps 5.1...
is there a way to generate an ac3 core without re-encoding like they are trying to do in tsmuxer? even if the core is silent, I don't mind as long as TrueHD works.
Yeah, I've been trying to figure out if that's possible too. My guess is that because the TrueHD is based on the AC3 core, when you add the core it needs to re-encode the TrueHD too to match? (which I'm presuming is why it takes a while) So maybe it's possible to create a core that doesn't need the TrueHD data to be re-encoded, but I don't know anywhere near enough about the details of AC3 or TrueHD to know :?
Thank you for your scripts too!
Encoding DTS-HD takes in a lossless LPCM stream, encodes a lossy DTS core, and saves the rest of the discarded audio as lossless extensions. When decoding, the extensions are recombined with the lossy DTS core and decoded to arrive at the original lossless stream.
But TrueHD doesn't require an AC3 lossy core; it isn't a required part of the TrueHD spec. When an AC3 core is included with a TrueHD track it's because of the BD spec, where it's required for BD / UHD BD.
TrueHD tracks are comprised of "access units" where the audio has been divided into frames.
A TrueHD+AC3 track has audio frames alternating between TrueHD and AC3. It's just two completely separate streams interleaved into a single track, kind of how STDL puts two distinct video streams into separate NALUs of a single track.
A THD+AC3 track is the STDL of TrueHD audio streams, where a THD track with a separate AC3 track is DTDL.
So if you have a TrueHD track and an AC3 track, you have all of the encoded audio data you need, you just need to remux/repack the audio frames into the correct format.
That's what I understand they're working on for tsMuxer, and there is no other tool I've found that can do it.
eac3to can remux a TrueHD stream into a THD+AC3 stream, but has to encode a new AC3 stream to do it. It doesn't support remuxing an existing AC3 stream.
The mlp tool for accurately/losslessly editing THD streams has an open issue requesting support, but there's no activity on it.
deadchip12
#6062 Post by deadchip12 » Sat Feb 12, 2022 1:39 am
RESET_9999 wrote: Fri Feb 11, 2022 1:08 pm
FubbAyH wrote: Fri Feb 11, 2022 2:48 am transcoding my MKVs back to M2TS!
If all your DV movies are in MKV, you'll have a lot of work to do because you'll have to convert TrueHD to TrueHD+ac3 with eac3to (unless the tsmuxer devs add support soon).
Also, if your profile 7 files are single track dual layer MKV, you'll have(sometimes) to 1- demux the layers and 2- convert trueHD because some ST file gives a black screen.
If you have fast internet, it might be faster just to download the complete ISO and make a new TS.
If I just put the dv mkv file into tsmuxer and press remux to bmdv folder, the bmdv folder is still generated. But will that work?
nekno
#6063 Post by nekno » Sat Feb 12, 2022 1:46 am
deadchip12 wrote: Sat Feb 12, 2022 1:39 am
He listed the exceptions.
If you have DTS-HD/DTS/EAC3/AC3 audio, remuxing to BDMV will work. If you want TrueHD audio you have to use eac3to to make THD+AC3 audio first. (If your mkv has both TrueHD and AC3 streams, tsMuxer should support remuxing to THD+AC3 in the future, but not today.)
If you have P7 in mkv, that will be STDL. For some files you may need to demux the video to DTDL with dovi_tool first.
sickb
#6064 Post by sickb » Sat Feb 12, 2022 9:45 am
Is there a way to have a ts file that plays well in both, x800m2 and Nvidia shield just player?
My makemkv stdl converted with tsmuxer to ts, only plays in hdr :/
#6065 Post by RESET_9999 » Sat Feb 12, 2022 2:39 pm
sickb wrote: Sat Feb 12, 2022 9:45 am Is there a way to have a ts file that plays well in both, x800m2 and Nvidia shield just player?
only HDR10, that's strange.
With TS ST-DL files I get DV or a black screen with some files but never HDR10.
I stopped using ST-DL because a lot of FEL files don't play. ( all the MEL 2mbps bitrate also fails to play)
sickb
#6066 Post by sickb » Sat Feb 12, 2022 2:49 pm
only hdr10 - on shield tv.
btw im trying to find the most recent working links of your/the test files, but can't seem to find them.
I got the X800M2 today, all my content so far says Dolby Vision BT.2020 YCbCr 4:2:0/10bit,
is that supposed to show 12bit if FEL is applied properly?
#6067 Post by RESET_9999 » Sat Feb 12, 2022 3:03 pm
sickb wrote: Sat Feb 12, 2022 2:49 pm only hdr10 - on shield tv.
oh, I see... It's been a while since I played a movie on my Shield but last time I checked. ST-DL TS played fine with PLEX as long as you don't use PGS subtitles ( external SRT is fine)
Dolby Vision BT.2020 YCbCr 4:2:0/10bit is the input signal info of the BL + DV.
I didn't connect my vertex yet but I assume that this player reports for the HDMI output:
1-Dolby vision for TV-LED
2-Dolby vision 422 12bit for player-led
the test files link is in my signature.
ST-DL fel test = passed
DT-Dl fel test = passed
btw, the movies don't have to be in your windows library, you can start any movie from your PC.
sickb
#6068 Post by sickb » Sat Feb 12, 2022 4:22 pm
RESET_9999 wrote: Sat Feb 12, 2022 3:03 pm ...
Thanks :) Im on Mac, im using Plex atm as DLNA server.
The interesting part is that the DT-DL doesn't play at all, black screen on my X800M2.
Neither via Universal Media Server
#6069 Post by RESET_9999 » Sat Feb 12, 2022 4:27 pm
sickb wrote: Sat Feb 12, 2022 4:22 pm
Thanks :) Im on Mac, im using Plex atm as DLNA server. The interesting part is that the DT-DL doesn't play at all, black screen on my X800M2.
yep, I'm noticing that too.. some work, some don't. Looks like the x800 is pickier than the x700.
p8 seem fine so far
sickb
#6070 Post by sickb » Sat Feb 12, 2022 4:29 pm
RESET_9999 wrote: Sat Feb 12, 2022 4:27 pm
p8 seem fine so far
What would be the alternative to check DT DL FEL?
#6071 Post by RESET_9999 » Sat Feb 12, 2022 4:35 pm
sickb wrote: Sat Feb 12, 2022 4:29 pm What would be the alternative to check DT DL FEL?
I already tested FEL as I said.
RPU-FEL TEST DT DL p7.mp4 works but the TS file doesn't. Same with some movies, looks like it's the one that were remuxed from mkv files. I'll do some test about that
EDIT: yes, so far, all the DT DL ts file made from bluray iso works but a lot of those I made from MKV ST-DL fails to play.
sickb
#6072 Post by sickb » Sat Feb 12, 2022 4:48 pm
RESET_9999 wrote: Sat Feb 12, 2022 4:35 pmEDIT: yes, so far, all the DT DL ts file made from bluray iso works but a lot of those I made from MKV ST-DL fails to play.
Bummer, my hope in all this madness would be to keep all ST-DL mkv's, and when I want to watch a FEL movie, I run it through the conversion process and watch the movie :)
(Most of my library consists of ST-DL mkv atm)
#6073 Post by RESET_9999 » Sat Feb 12, 2022 4:50 pm
yep, I replicated the issue. I remuxed an ISO to MKV and then to TS DT-DL and it doesn't play ( black screen and player sees lpcm audio)
I remuxed the same ISO to DT-DL using tsmuxer only and the file play just fine in DV+atmos
#6074 Post by RESET_9999 » Sat Feb 12, 2022 4:55 pm
So mkvtoolnix and makemkv are breaking something in DV.
probably because of this: https://forum.doom9.org/showpost.php?p= ... count=1084
sickb
#6075 Post by sickb » Sat Feb 12, 2022 5:09 pm
RESET_9999 wrote: Sat Feb 12, 2022 4:55 pm So mkvtoolnix and makemkv are breaking something in DV.
It may explain then why the files as ST-DL also sometimes don't work?
Here's a topic on it but no answer from Mike atm:
viewtopic.php?f=12&t=26034
