LibreDrive for Pioneer drives
#16 Post by Coopervid » Sat Feb 12, 2022 10:32 am
Coopervid wrote: Sat Feb 12, 2022 12:35 am I will my buddies with the 211s check tomorrow. Feedback is certain.
The Pioneer 211M works now. 8) 8)
#17 Post by Coopervid » Sat Feb 12, 2022 10:51 am
emrysblack wrote: Sat Feb 12, 2022 1:19 am screen.jpg
This drive doesn't support UHD.
ryley
#18 Post by ryley » Sat Feb 12, 2022 11:03 am
Coopervid wrote: Sat Feb 12, 2022 10:51 am
UHD aside, unless I misread Mike's initial post, I thought it would now support LibreDrive as one of the RS8xxx drives. My experience with an older BDR-XD05 on the RS8231 platform is similar:
Pioneer BDR-XD05.PNG (62.53 KiB) Viewed 88135 times
#19 Post by Coopervid » Sat Feb 12, 2022 11:24 am
ryley wrote: Sat Feb 12, 2022 11:03 am
You should verify that you have internet access allowed since Makemkv needs to update sdf.bin to version 81. If you enable debug you can see which version is used when you rip a disc. If you have version 81 then it needs more work for Mike.
#20 Post by mike admin » Sat Feb 12, 2022 7:07 pm
Just pushed the update, SDF v82 . It uses a new discovery method, that bypasses USB enclosures that damage the inquiry data. The Slim 'Optiarc' should work now...
Braku
#21 Post by Braku » Sat Feb 12, 2022 7:49 pm
Hello all, I have a (new) BDR-S12UHT which does not work with v82. Did someone have news about that?
Tested with the movie Dune.
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-S12U
Revision: 1.01
Serienummer: xxxxxxxxxxxx
Firmware-Datum: 2020-07-21
Highest AACS version: 76
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8F01
Firmware version: ID43
Disk-Informationen
Label: DUNE
Zeitstempel: 2021-10-25 15:48:03
Schutz: AACS2.0/C v76
Datenkapazität: 90.66 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 3
Markierungen der Bus-Verschlüsselung: 80
regards braku
#22 Post by Coopervid » Sat Feb 12, 2022 8:06 pm
A 212m won't work. No Libredrive. Log attached
https://1drv.ms/t/s!AhdE7WXu02uygUe_Ob2 ... X?e=Yb6IHA
Drive platform is RS8F00
#23 Post by mike admin » Sat Feb 12, 2022 8:30 pm
Coopervid wrote: Sat Feb 12, 2022 8:06 pm A 212m won't work. No Libredrive. Log attached
No  SDF v082: PIONEER_BD-RW___BDR-212M_1.00_TGDL005056WL
I don't have 1.00 firmware. We would need to dump the full firmware over the internet, takes about 15 minutes. Please PM me or email me for details.
#24 Post by MartyMcNuts » Sat Feb 12, 2022 8:53 pm
Braku wrote: Sat Feb 12, 2022 7:49 pm Hello all, I have a (new) BDR-S12UHT which does not work with v82. Did someone have news about that?
Produzent: PIONEER
Revision: 1.01
Disk-Informationen
Label: DUNE
Anzahl der Layer: 3
regards braku
Yeah, it is the firmware. My S12-UHT with 1.00 works fine.
Mike needs a dump of your 1.01 firmware to add support. Please contact him and he can extract it from the drive online. Only takes about 15 minutes.
#25 Post by Coopervid » Sat Feb 12, 2022 8:57 pm
mike admin wrote: Sat Feb 12, 2022 8:30 pm
Please write a private message with instructions.
EDIT: A friend has this drive - not me.
jesuuu
#26 Post by jesuuu » Sat Feb 12, 2022 9:03 pm
Hello. Is there any chance that this drive could be supported? It is actually Pioneer rebranded as Verbatim Slimline 4K. Thanks.
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.11
Firmware date: 2018-11-28
Highest AACS version: 72
Drive platform: Pioneer RS8A10
Firmware version: GENE
Braku
#27 Post by Braku » Sat Feb 12, 2022 9:51 pm
MartyMcNuts wrote: Sat Feb 12, 2022 8:53 pm
Braku wrote: Sat Feb 12, 2022 7:49 pm ...
dump is done! Mike will add support to SDF v083.
#28 Post by MartyMcNuts » Sat Feb 12, 2022 9:58 pm
jesuuu wrote: Sat Feb 12, 2022 9:03 pm Hello. Is there any chance that this drive could be supported? It is actually Pioneer rebranded as Verbatim Slimline 4K. Thanks.
Revision: 1.11
Mike will need a dump of your 1.11 firmware to add support. Please contact him to see if he can extract it from the drive online. Only takes about 15 minutes.
#29 Post by SamuriHL » Sat Feb 12, 2022 10:16 pm
Product: BD-RW BDR-212U
Revision: 1.01
Serial number: xxxxxxxxxx
Firmware date: 2020-07-21
Firmware version: ID58
Disc Information
Label: RESIDENT_EVIL_RACCOON_CITY
Timestamp: 2021-12-02 18:22:09
Protection: AACS2.0/C v76
Data capacity: 57.79 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Happy to help in any way.
EDIT: Mike has the firmware from this drive now.
#30 Post by Coopervid » Sat Feb 12, 2022 10:21 pm
I don't want to push it but are firmware dumps using DVRTool OK or is additional info required?
https://club.myce.com/t/dvrtool-pioneer ... -02/312464
