Asus BW-16D1HT Failing?
mr.pope
Post by mr.pope »
Hello Everyone!
I've been a lurker here for many years. All the knowledge, skills, and effort you put into this forum is amazing.
I've had an Asus BW-161HT since almost the beginning of UHD ripping. I don't rip that many titles in 4K (30>), but mostly regular bluray.
Recently I've been unable to rip UHD, makemkv also lost the drive. I replaced the sata cable and moved it to another power cable. It seems to be working correctly now, but it will not finish a rip. I ripped a bluray last week and that worked. here are some of the errors I'm getting after the rip fails. I've cleaned the crap out of that disc, under a magnifier, to no avail. I put in another disc last night, and that also failed. I'm thinking the drive's time is up, but would like to know from the experts, and if there's something I can do.
thanks!
OS device name:\Device\CDRom0
Manufacturer: Asus
Product: BW-16D1HT
Revision 3.01
Serial number SIK9EH5PA495
Firmware date: 2117-03-31 14:26
Bus encription flags: 1F
Highest AACS version: 76
Firmware version 3.01
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '60971876352'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '60971876352'
DEBUG: Code 3221225628 at |v@gGwTzroP3Y(T6Kw:29395149
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '60972134400'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '60973117440'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '60973117440'
DEBUG: Code 3221225488 at |v@gGwTzroP3Y(T6Kw:29395149
DEBUG: Code 101000192 at |v@gGwTzroP3Y(T6Kw:29395149
Flubly
Re: Asus BW-16D1HT Failing?
Post by Flubly »
Are the offsets listed in the errors the same each time you try to rip it?
Have you tried increasing the read retry count in preferences? I think the default is 5 and I've seen people set it from 25 to even 99 and have success.
mr.pope
Post by mr.pope »
Thanks,
I'll give that a try. I bought a WH14NS40 and flashed it. That worked great. Good to know I can try a few more things before I junk it.
mostlife
Post by mostlife »
Try flashing 302 original (but hacked), then 301 and then 3.10MK.
Does this help?
