thecapsaicinkid
#1
Post
by thecapsaicinkid » Wed Mar 02, 2011 1:08 pm
makemkvcon stream disc:0
MakeMKV v1.6.5 linux(x64-release) started
Debug logging enabled, log will be saved as /home/dom/MakeMKV_log.txt
Evaluation period has expired, shareware functionality unavailable.
Evaluation period has expired. Please purchase an activation key if you've found this application useful. You may still use all free functionality without any restrictions.
DEBUG: Code 0 at Zul7war+~7F/cAPJ:213131686
DEBUG: Code 0 at Zul7war+~7F/cAPJ:29396943
Segmentation fault
Seen on both 'The Crazies' and 'Afro Samurai'
If I can provide more information, let me know.
thecapsaicinkid
#3
Post
by thecapsaicinkid » Wed Mar 02, 2011 10:43 pm
The key isn't the issue, I still get the same segfault and 'unable to open disc'.
Post
by mike admin » Thu Mar 03, 2011 8:31 am
thecapsaicinkid wrote:The key isn't the issue, I still get the same segfault and 'unable to open disc'.
But then you should get different errors. Please try makemkvcon info disc:0 with current beta key and post the log here.
thecapsaicinkid
#5
Post
by thecapsaicinkid » Thu Mar 03, 2011 6:55 pm
001005:0000 MakeMKV v1.6.5 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/dom/MakeMKV_log.txt
DISCID=6B09D96018A1151F71E8738D22FC8AC003FF6A0E
003025:0000 Title #00035.m2ts has length of 1575 seconds which is less than minimum title length of 5300 seconds and was therefore skipped
003025:0000 Title #00052.m2ts has length of 1422 seconds which is less than minimum title length of 5300 seconds and was therefore skipped
Application exited at Thu Mar 3 18:53:29 2011
Post
by mike admin » Fri Mar 04, 2011 11:16 am
Titles are skipped because they are shorter than you've set in preferences. What is the length of main title? Please send all blu-ray CLPI and MPLS files per
http://www.makemkv.com/faq/item/8/catid/6
thecapsaicinkid
#7
Post
by thecapsaicinkid » Wed Mar 09, 2011 5:54 pm
Giving a smaller value for the min length and the Afro Samurai disc is now streaming but only for about a minute until the program crashes with an error message "Fatal error occurred, program will exit".
The other disc reports that it uses an newer version of AACS and the title key is unknown which I reported with included url.
EDIT: Just tried a 3rd disc and this gives the fatal error the instant I attempt to play the stream. Will try to rip it to mkv.
gettons
#9
Post
by gettons » Mon Jul 25, 2011 8:00 pm
Hi there,
I had similar problems with 2 discs recently.
So now I am trying to disable direct disc access but it's quite unsuccessful so far.
( I am on ubuntu lucid 32bit and xbmc dharma on zotac zbox with external usb plextor bray player. )
I have tried passing the option --directio=false but the program starts with these options regardless:
xbmc@zotacchino:~/.xbmc$ makemkvcon --debug --directio=false stream disc:0
MakeMKV v1.6.12 linux(x86-release) started
Debug logging enabled, log will be saved as /home/xbmc/MakeMKV_log.txt
Am I doing something wrong?
tracy91
#10
Post
by tracy91 » Fri Oct 28, 2011 1:21 pm
Don't you think it is a power supply unit problem, which is not able to give enough power to 2 drives?
if every single movie on both
**Unwanted Spam** the disks is working properly?
tracy91 on Mon Feb 13, 2012 11:31 am, edited 2 times in total.
swan11
#11
Post
by swan11 » Sat Nov 26, 2011 4:45 am
Well, as Roman SH have said here, if key is not the issue that you are dealing with, then it should definitely give you errors that are different to the ones that are caused by keys. Are you sure you get the same SEGFault and unable to open disc errors? Please retry the process and confirm it.
“Read Today, Lead Tomorrow”
