Mad Max The Road Warror 4K UHD
mldardy
I submitted the tgz file for The Road Warrior on Saturday for 'The volume key is unknown for this disc - video can't be decrypted'. Does anyone know how long it normally takes to fix?
Re: Mad Max The Road Warror 4K UHD
mldardy
Thanks for fixing this
DeadPixel
I read this disc was originally faulty and wondered if anyone knows what to look out for to know I get the correct replacement disc?
As is often the case, you didn't provide much to go on (like what, specifically, you read & where you read it),,. but google came to the rescue.DeadPixel wrote: Mon May 16, 2022 5:47 pm I read this disc was originally faulty and wondered if anyone knows what to look out for to know I get the correct replacement disc?
blu-raydotcom details particulars of both the "corrected" (Feb 01, 2022 release)/"wrong audio" (Nov 16, 2021 release) versions, along w/ purchase links. Should you desire to purchase elsewhere, there ought to be enough specific info to identify the correct version?
Hope this helps.
jayper
The UPC for the correct disc is: 883929789993
DeadPixel
Thanks, that will help
