Angle 1, 2, 3
pm2017
Angle 1, 2, 3
Post by pm2017 »
Went to rip a blu ray of Meet the Robinsons and it shows 3 titles same size but one was angle 1, another angle 2, and last one angle 3 in parentheses. It automatically selected angle 1 so I went with that one. Didn’t know if someone could explain what that might be related to.
Re: Angle 1, 2, 3
Angles are usually different features enabled. Sometimes, there will be an "angle" that adds story boards to the video.
Ezatoka
Re: Angle 1, 2, 3
Post by Ezatoka »
Could also be different languages for overlays or signs in the scene. Like Angle 1 is English, Angle 2 is French, Angle 3 is German etc.
With a BluRay you should be able to see the segment list. If there are some segments differing from each other, they could be such a thing.
pm2017
Re: Angle 1, 2, 3
Post by pm2017 »
Thank you. Now I know what the differences may be if something isn't as expected after ripping.
