KyleLeMarbe
Created some powershell scripts to handle MKV to MP4 with dolby vision. Hoping others can get some value out of them.
https://github.com/KyleLeMarbe/DolbyVisionMuxer
I'm new here, sorry if I ask a question that maybe has already been answered, but I can't find a way to do what I want, so I'm probably not looking at the right styff...
I have a DV MP4 file working fine via USB on my LG oled. Point is I want to add another audio track/different language to it.
How do I do that? Which program can I use to remux the MP4 correctly with the added track...?
Thanks to anyone who can help me.
It depends on what you want the resulting filetype to be. If you're looking for a ts, m2ts, ISO, Blu-ray folder you can use TS-Muxer.Ichisuke wrote: Mon Feb 07, 2022 4:15 pm I'm new here, sorry if I ask a question that maybe has already been answered, but I can't find a way to do what I want, so I'm probably not looking at the right styff...
How do I do that? Which program can I use to remux the MP4 correctly with the added track...?![]()
If you're looking for an MKV, you should use ffmpeg to convert the mp4 to an mkv and then you can use MKVToolNix to multiplex the new audio track with the MKV you created with ffmpeg.
I move away from MP4s, so I can't recommend anything if you're looking to keep the file as an MP4. Others will need to weigh in.
I agree with @jayper ... The easiest solution is txMuxer.
DV MP4 only gives me issues on my C8 internal player and Shield( stutter and audio hiccup).
RESET_9999 wrote: Mon Feb 07, 2022 6:15 pm I agree with @jayper ... The easiest solution is txMuxer.
Tsmuxer (latest nightly version) won't open the MP4 file. Don't know why. As said the file is played perfectly fine on the LG. I thought that if I convert the file I'd lose the Dolby Vision? Will it retain the Dolby Vision track if I convert it to mkv with ffmpeg?jayper wrote: Mon Feb 07, 2022 5:33 pmIt depends on what you want the resulting filetype to be. If you're looking for a ts, m2ts, ISO, Blu-ray folder you can use TS-Muxer.Ichisuke wrote: Mon Feb 07, 2022 4:15 pm I'm new here, sorry if I ask a question that maybe has already been answered, but I can't find a way to do what I want, so I'm probably not looking at the right styff...
I move away from MP4s, so I can recommend anything if you're looking to keep the file as an MP4. Others will need to weigh in.
yep, some mp4 wont work in tsmuxer but the solution is easy. Remux the mp4 to mkv with mkvtoolnix and then to TS with tsmuxer.Ichisuke wrote: Mon Feb 07, 2022 7:01 pm
KyleLeMarbe
Extracting the video stream with FFMpeg will preserve the dolby vision profile. MP4Muxer should be able to take multiple audio streams, but I have not tested that. I would extract the video file you want as well as any audio tracks and use MP4Muxer to put them back together. I have scripts in my signature that would be able to help. Would only need slight modification.Ichisuke wrote: Mon Feb 07, 2022 7:01 pmRESET_9999 wrote: Mon Feb 07, 2022 6:15 pm I agree with @jayper ... The easiest solution is txMuxer.
DV MP4 only gives me issues on my C8 internal player and Shield( stutter and audio hiccup).Tsmuxer (latest nightly version) won't open the MP4 file. Don't know why. As said the file is played perfectly fine on the LG. I thought that if I convert the file I'd lose the Dolby Vision? Will it retain the Dolby Vision track if I convert it to mkv with ffmpeg?jayper wrote: Mon Feb 07, 2022 5:33 pmIt depends on what you want the resulting filetype to be. If you're looking for a ts, m2ts, ISO, Blu-ray folder you can use TS-Muxer.Ichisuke wrote: Mon Feb 07, 2022 4:15 pm I'm new here, sorry if I ask a question that maybe has already been answered, but I can't find a way to do what I want, so I'm probably not looking at the right styff...
this has been happening to me only as of the latest update as well, hopefully it's resolved with the next rollup update. I switched back to the SHIELD because the CCwGTV has stuttering too on DV (maybe mp4 only who knows) content with it's latest updateRESET_9999 wrote: Mon Feb 07, 2022 6:15 pm DV MP4 only gives me issues on my C8 internal player and Shield( stutter and audio hiccup).
can't win
@RESET_9999
I just practiced remux WEB-DL P5 to Blu-ray on Arrival movies in my computer.
However, my remove frame result is a negative number, not a positive number like yours.
So what should I do next?
duplicate 131 frames with ''edit.duplicate.frames.json'' and ''RPU.EDIT.duplicate.frames.bat''Albano wrote: Mon Feb 07, 2022 11:19 pm @RESET_9999
@nekno
@RESET_9999
Thanks for your helping.
After many tries, I found out that, only convert PRU P5 to P8.2, can't convert P5 to P8.1 or P8.6 by dovi_tool.
The reason is because P5 use YCbCr color space while P8.1 and P8.6 use BT2020 color space.
Only Colorfront Transkoder tool is able to convert PRU P5 to P8.1 or P8.6.
It's definitely a high end feature requiring licensing Dolby Vision technology.
Netflix mention that particular software here: Dolby Vision HDR Mastering
@RESET_9999
what? basicaly none of what you just said is true.Albano wrote: Tue Feb 08, 2022 4:08 pm @nekno
@RESET_9999
I mean if you only have one DV P5 file, you can't creat one DV P8.1 or DV P8.6 file.RESET_9999 wrote: Tue Feb 08, 2022 5:33 pmwhat? basicaly none of what you just said is true.Albano wrote: Tue Feb 08, 2022 4:08 pm @nekno
@RESET_9999
ha you're talking about the conversion of profile 5 videos (IcTcP colorspace) to PQ YCBCR and not the RPU itself.Albano wrote: Tue Feb 08, 2022 8:36 pm I mean if you only have one DV P5 file, you can't creat one DV P8.1 or DV P8.6 file.
The dovi_tool is not a video encoder, it only converts the RPU to 8.1. not the video
@RESET_9999
Due to some hardware compatibility issues, I had to go back to Windows 7.
Of course, when I go back to Windows 7, I won't be able to use D3D11 anymore, so I should choose DXVA2 (native) or DXVA2 (copy-back) for best measureHDR quality result?
