This is RPU info of file.nekno wrote: ↑Fri Feb 04, 2022 8:28 pm
You can extract the values from the original RPU and see what it's using.
Or maybe quiet_void or RESET_9999 can confirm what happens if you specify 0 for MaxCLL and MaxFALL when editing the L6 data. Some of RESET_9999's tutorial videos show leaving those values at 0 when editing the L6 data with dovi_tool.
That should show the MaxCLL and MaxFALL values already in use. Copy those to your L6.json file, and just set the min display luminance value to 50 and the max display luminance value to 1000 to correct those values.Code: Select all
dovi_tool extract-rpu video.hevc dovi_tool info -i RPU.bin -f 0
Then you can follow the remaining steps to edit and inject the RPU from my earlier post.
I want to convert this RPU from P5 to P8.1
