KyleLeMarbe
#6016 Post by KyleLeMarbe » Mon Feb 07, 2022 3:24 am
Created some powershell scripts to handle MKV to MP4 with dolby vision. Hoping others can get some value out of them.
https://github.com/KyleLeMarbe/DolbyVisionMuxer
Ichisuke
#6017 Post by Ichisuke » Mon Feb 07, 2022 4:15 pm
I'm new here, sorry if I ask a question that maybe has already been answered, but I can't find a way to do what I want, so I'm probably not looking at the right styff...
I have a DV MP4 file working fine via USB on my LG oled. Point is I want to add another audio track/different language to it.
How do I do that? Which program can I use to remux the MP4 correctly with the added track...? :(
Thanks to anyone who can help me.
jayper
#6018 Post by jayper » Mon Feb 07, 2022 5:33 pm
It depends on what you want the resulting filetype to be. If you're looking for a ts, m2ts, ISO, Blu-ray folder you can use TS-Muxer.
If you're looking for an MKV, you should use ffmpeg to convert the mp4 to an mkv and then you can use MKVToolNix to multiplex the new audio track with the MKV you created with ffmpeg.
I move away from MP4s, so I can't recommend anything if you're looking to keep the file as an MP4. Others will need to weigh in.
#6019 Post by RESET_9999 » Mon Feb 07, 2022 6:15 pm
I agree with @jayper ... The easiest solution is txMuxer.
DV MP4 only gives me issues on my C8 internal player and Shield( stutter and audio hiccup).
Ichisuke
#6020 Post by Ichisuke » Mon Feb 07, 2022 7:01 pm
I move away from MP4s, so I can recommend anything if you're looking to keep the file as an MP4. Others will need to weigh in.
Tsmuxer (latest nightly version) won't open the MP4 file. Don't know why. As said the file is played perfectly fine on the LG. I thought that if I convert the file I'd lose the Dolby Vision? Will it retain the Dolby Vision track if I convert it to mkv with ffmpeg?
#6021 Post by RESET_9999 » Mon Feb 07, 2022 8:25 pm
yep, some mp4 wont work in tsmuxer but the solution is easy. Remux the mp4 to mkv with mkvtoolnix and then to TS with tsmuxer.
KyleLeMarbe
#6022 Post by KyleLeMarbe » Mon Feb 07, 2022 8:30 pm
Extracting the video stream with FFMpeg will preserve the dolby vision profile. MP4Muxer should be able to take multiple audio streams, but I have not tested that. I would extract the video file you want as well as any audio tracks and use MP4Muxer to put them back together. I have scripts in my signature that would be able to help. Would only need slight modification.
staknhalo
#6023 Post by staknhalo » Mon Feb 07, 2022 9:07 pm
this has been happening to me only as of the latest update as well, hopefully it's resolved with the next rollup update. I switched back to the SHIELD because the CCwGTV has stuttering too on DV (maybe mp4 only who knows) content with it's latest update
can't win
Albano
#6024 Post by Albano » Mon Feb 07, 2022 11:19 pm
@RESET_9999
I just practiced remux WEB-DL P5 to Blu-ray on Arrival movies in my computer.
However, my remove frame result is a negative number, not a positive number like yours.
So what should I do next?
#6025 Post by RESET_9999 » Tue Feb 08, 2022 12:20 am
@RESET_9999
duplicate 131 frames with ''edit.duplicate.frames.json'' and ''RPU.EDIT.duplicate.frames.bat''
Albano
#6026 Post by Albano » Tue Feb 08, 2022 4:08 pm
@nekno
@RESET_9999
Thanks for your helping.
After many tries, I found out that, only convert PRU P5 to P8.2, can't convert P5 to P8.1 or P8.6 by dovi_tool.
The reason is because P5 use YCbCr color space while P8.1 and P8.6 use BT2020 color space.
Only Colorfront Transkoder tool is able to convert PRU P5 to P8.1 or P8.6.
It's definitely a high end feature requiring licensing Dolby Vision technology.
Netflix mention that particular software here: Dolby Vision HDR Mastering
#6027 Post by RESET_9999 » Tue Feb 08, 2022 5:33 pm
@nekno
@RESET_9999
what? basicaly none of what you just said is true.
Albano
#6028 Post by Albano » Tue Feb 08, 2022 8:36 pm
@nekno
@RESET_9999
I mean if you only have one DV P5 file, you can't creat one DV P8.1 or DV P8.6 file.
#6029 Post by RESET_9999 » Tue Feb 08, 2022 9:02 pm
ha you're talking about the conversion of profile 5 videos (IcTcP colorspace) to PQ YCBCR and not the RPU itself.
The dovi_tool is not a video encoder, it only converts the RPU to 8.1. not the video
Albano
#6030 Post by Albano » Wed Feb 09, 2022 9:51 pm
@RESET_9999
Due to some hardware compatibility issues, I had to go back to Windows 7.
Of course, when I go back to Windows 7, I won't be able to use D3D11 anymore, so I should choose DXVA2 (native) or DXVA2 (copy-back) for best measureHDR quality result?
