Yup and make sure the modes are supported by your monitor/tv
Directly Play 4K UHD BluRays ?
Re: Directly Play 4K UHD BluRays ?
hardcore_gamer29
if using vlc player, use 64bit then there will be no lagzarc987 wrote: ↑Thu Jan 20, 2022 1:39 amHow come the playback lags a little, do I have to change some settings ?Billycar11 wrote: ↑Thu Jan 20, 2022 1:01 amYes many
Mpc be with mad VR
VLC
Just check the integration box in makemkv for the program.
Hello.
I am using latest version of MakeMKV and VLC Video Player. I checked all boxes on integration tab, but VLC can't play blu ray. It says "disc is corrupted". With DVDFab passkey VLC play BDs. Drive is LG BU40N with DE firmware 1.0. How to configure MakeMKV and VLC to work together?
Do you own makemkv?IceCool wrote: ↑Tue Feb 22, 2022 7:26 amHello.
Integration only works if you own it
Thanks, i already figured it out. I activated trial period:) Now it's working.Billycar11 wrote: ↑Tue Feb 22, 2022 2:28 pmDo you own makemkv?
