2001: A Space Odyssey
strubdog
#1 Post by strubdog » Tue Feb 25, 2020 1:02 am
I am trying to rip my copy of 2001: A Space Odyssey. This is the 4K UHD Version. My drive is an ASUS 16D1HT, this is installed an external USB enclosure which is plugged directory into my desktop PC.
This disc is spotless and plays fine. I had no issues with when I watched the movie on my Oppo 203.
Here is the log from MakeMKV.
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00058.m2ts' at offset '32795652096'
Error 'Internal error - Operation result is incorrect (75)' occurred while reading '\Device\CdRom0' at offset '32795652096'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '32795652096'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00058.m2ts' at offset '32797421568'
Error 'Internal error - Operation result is incorrect (75)' occurred while reading '\Device\CdRom0' at offset '32797421568'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '32797421568'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00058.m2ts' at offset '32821278720'
Error 'Internal error - Operation result is incorrect (75)' occurred while reading '\Device\CdRom0' at offset '32821278720'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '32821278720'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00058.m2ts' at offset '33007073280'
Error 'Internal error - Operation result is incorrect (75)' occurred while reading '\Device\CdRom0' at offset '33007073280'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '33007073280'
Re: 2001: A Space Odyssey
#2 Post by Woodstock » Tue Feb 25, 2020 1:55 am
The assumption is that the enclosure is supplying sufficient power for full-speed operation. Some USB-powered drives can run into issues when they try to go too fast.
Your drive is having problems with a few sectors. It is trying REALLY HARD to read them, but the operating system is getting tired of waiting for a response (the device timeouts). The old stand-by of cleaning the disk often works wonders, even if the disk is new and looks clean.
strubdog
#3 Post by strubdog » Tue Feb 25, 2020 3:14 am
Should I get a different drive or enclosure. What would you recommend as far as enclosure?
strubdog
#4 Post by strubdog » Fri Feb 28, 2020 5:25 pm
ON my 2nd copy of 2001. It's still hanging at the same spot. Has anyone had any issues ripping the 4K UHD version of 2001: A Space Odyssey?
#5 Post by Billycar11 » Fri Feb 28, 2020 5:40 pm
Possibly another defective Asus
strubdog
#6 Post by strubdog » Fri Feb 28, 2020 5:51 pm
Everything else rips fine, even a few UHD's (Frozen II, Apollo 13, and Across The Universe). I may have to get a new drive. Should I just grab another BW-16D1HT or a different drive this time?
#7 Post by Billycar11 » Fri Feb 28, 2020 6:20 pm
BU40N
thrillcat
#8 Post by thrillcat » Sat Feb 29, 2020 3:59 am
I’ve successfully ripped it with MakeMKV and an LG internal drive.
VarHD
#9 Post by VarHD » Sat Feb 29, 2020 3:18 pm
Oh yes. It was a bit of a pain for me too. I've put it in, wanted to rip it and the drive said: "I'm sorry Dave, I'm afraid I can't do that" ;)
But seriously, yes, my drive didn't want to mount the disc at first and/or has shown read errors, but it worked after a couple of tries. It's a 3-layered disc and those tend to be more prone to such issues than 1- or 2-layered discs. It could of course be an issue with your drive, but just saying - it doesn't surprise me to see someone else having an issue ripping this movie.
mac404
#10 Post by mac404 » Sun Mar 01, 2020 2:41 pm
I'll put in another plug for an LG drive - my BU40N (in a Vantec enclosure) had no issues ripping this disk first try.
boxman75
#11 Post by boxman75 » Fri Feb 04, 2022 12:25 am
I'm having the same problem and I've tried two drives in two different enclosures. I've got an ASUS BW-16D1HT and an LG WH16NS60. I have successfully burned multiple 4K UHD titles with both drives recently and I just keep getting read errors in the same locations on the disc. I'll try cleaning this brand new disc again, but after that I'm stuck. If anyone has any suggestions I'm all ears.
#12 Post by Billycar11 » Fri Feb 04, 2022 2:03 am
the WH16NS60 and asus BW16D1HT are the same
anyway have you tried replacing the disc?
boxman75
#13 Post by boxman75 » Sat Feb 05, 2022 8:19 pm
I just got my replacement disc from Amazon and it's working like a champ. I returned the non-readable one. Thanks for the help! Also, I didn't know those are the same drive! Who makes them for ASUS and LG? Pioneer?
#14 Post by Billycar11 » Sat Feb 05, 2022 10:44 pm
LG/ Hitachi makes them
sounds
#15 Post by sounds » Tue Feb 15, 2022 2:11 pm
I also had loads of issues with a UHD disc of this film from Amazon being unreadable on a libredrive flashed Asus BW-16D1HT. Disc was clean and looked fine ... replaced and that ripped fine.
