The volume key is unknown (WSL)
fdauo
#1 Post by fdauo » Fri Feb 04, 2022 5:28 pm
I have done the steps to compile MakeMKV on my WSL (on Windows 11). When I start the application and select the corresponding index.bdmv file, the scan is started but after some time I get the following error:
MakeMKV v1.16.5 linux(x64-release) started
The program can't find any usable optical drives.
Opening files on harddrive at /mnt/d
Saved AACS dump file as /home/markus/.MakeMKV/XXXXXXXXXXXXX.tgz
Re: The volume key is unknown (WSL)
#2 Post by d00zah » Fri Feb 04, 2022 5:55 pm
