I have done the steps to compile MakeMKV on my WSL (on Windows 11). When I start the application and select the corresponding index.bdmv file, the scan is started but after some time I get the following error:
MakeMKV v1.16.5 linux(x64-release) started
The program can't find any usable optical drives.
Opening files on harddrive at /mnt/d
Saved AACS dump file as /home/markus/.MakeMKV/XXXXXXXXXXXXX.tgz
The volume key is unknown (WSL)
