Cloudy with a chance of meatballs 2D version
pseudo7
Post by pseudo7 » Wed Mar 02, 2011 3:07 pm
I have successfully ripped other disks (some with mild fingerprints on) however cloudy with a chance of meatballs does not work.
Sometimes it scans the titles ok then fails, other it fails the scanning properly (of which the code below is an example of).
The disk is not scratched (perfectly clean - not a mark on it) and the blu-ray drive is a few days old.
I've tried ripping without DASPI and with - no difference.
There seems to be two main errors:
'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED'
and
Error 'OS error - (ipc/send) invalid destination port'
MakeMKV v1.6.5 darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HC09" opened in DASPI mode.
Optical drive "BD-RE SONY BD RW BDX-S500U 1.D1" opened in DASPI mode.
Evaluation version, 29 day(s) out of 30 remaining
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00065.m2ts' at offset '258048'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00504.m2ts' at offset '528384'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00504.m2ts' at offset '122880'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00504.m2ts' at offset '411648'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/05012.m2ts' at offset '37201920'
Title #00099.mpls has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00999.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/05045.m2ts' at offset '0'
Title #00001.mpls was skipped
File 00000.mpls was added as title #0
Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 05003.m2ts was added as title #1
File 05004.m2ts was added as title #2
Title #05005.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #05006.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 05007.m2ts was added as title #3
File 05008.m2ts was added as title #4
Title #05009.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #05010.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #05011.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 05012.m2ts was added as title #5
Title #05013.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 05014.m2ts was added as title #6
File 05017.m2ts was added as title #7
File 05018.m2ts was added as title #8
File 05019.m2ts was added as title #9
File 05015.m2ts was added as title #10
File 05016.m2ts was added as title #11
Title #05020.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #05021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 05025.m2ts was added as title #12
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/05045.m2ts' at offset '0'
Title #05045.m2ts was skipped
Title #05046.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #05047.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #05048.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Also a disk back-up without decrypting fails:
Backing up disc into folder "/Users/Chris/Tasks/Encode Projects/backup/CLOUDY"
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/BACKUP/index.bdmv' at offset '0'
Backup failed
Can anyone help?
pseudo7
Re: Cloudy with a chance of meatballs 2D version
Post by pseudo7 » Wed Mar 02, 2011 4:09 pm
here's a debug log of a successful (ish) scan and a failed copy:
Debug logging enabled, log will be saved as /Users/Chris/MakeMKV_log.txt
DEBUG: Code 0 at uUGZ'iOUvOj%b.{iG:213131042
DEBUG: Code 100864257 at K|cLd{ope%9ew1RFdJ:29395885
DEBUG: Code 100864257 at K|cLd{ope%9ew1RFdJ:121262049
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00504.m2ts' at offset '79872'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00504.m2ts' at offset '288768'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00504.m2ts' at offset '319488'
File 00001.mpls was added as title #0
File 00000.mpls was added as title #1
File 05003.m2ts was added as title #2
File 05004.m2ts was added as title #3
File 05007.m2ts was added as title #4
File 05008.m2ts was added as title #5
File 05012.m2ts was added as title #6
File 05014.m2ts was added as title #7
File 05017.m2ts was added as title #8
DEBUG: Code 0 at rx]G(``rE@:F0#7{m:121264211
File 05018.m2ts was added as title #9
File 05019.m2ts was added as title #10
File 05015.m2ts was added as title #11
File 05016.m2ts was added as title #12
File 05025.m2ts was added as title #13
Saving 1 titles into directory /Users/Chris/Tasks/Encode Projects
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/05045.m2ts' at offset '13891584'
DEBUG: Code 0 at #;T"M"((KWQ(BN@0+&DY:29394298
DEBUG: Code 0 at Jv=}O/f18Nlqc%&i6<I=:121261681
DEBUG: Code 0 at #;T"M"((KWQ(BN@0+&DY:29394183
DEBUG: Code 6783 at #;T"M"((KWQ(BN@0+&DY:29393309
DEBUG: Code 0 at luo#3Eb+D*r/#@J397H>s:29397449
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121263751
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121265108
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:213130444
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121261934
DEBUG: Code 0 at luo#3Eb+D*r/#@J397H>s:121265775
DEBUG: Code 0 at x\a?3*Imqm*~?QB+vvl:29394160
DEBUG: Code 0 at x\a?3*Imqm*~?QB+vvl:29395195
Failed to save title 0 to file /Users/Chris/Tasks/Encode Projects/title00.mkv
0 titles saved, 1 failed
Here's the log file
Post by mike admin » Thu Mar 03, 2011 8:33 am
Please make sure that you have latest DASPI, v1.2
Then try making full disc backup with or without decryption http://www.makemkv.com/faq/item/4/catid/4
But this error does indicate a physically damaged disc.
pseudo7
Post by pseudo7 » Thu Mar 03, 2011 1:12 pm
Thanks for you reply mike,
I do have the latest DASPI (1.2) installed and it won't do a complete unencrypted backup.
So what your saying is most likely correct (dodgy disk), was just checking.
Many thanks again.
