Should it be possible to create DV P4 or P8.2 (SDR compatibly ) from madVR HDR measurements?
i have tried Dynamic.HDR.Optimizer.exe with target nits 100 and --use-custom-targets parameters, but i don't see lot of change.
Can be very usell using Dynamic.HDR.Optimizer. + DV as dynamic tone mapping as madvr for projector, like or better than tips Dolby Vision/DTM with HDFury .
thanks.
thanks.
ok , which is th best way to use Dynamic.HDR.Optimizer.exe with "target nits" and dovi_tool.exe with --use-custom-targets ?
Did you succeed?RESET_9999 wrote: ↑Thu Dec 30, 2021 7:42 pmyes but the file has the 8.1 rpu from @quietvoid L1L2 HDR10 BL test file.
I'll try to edit the original HLG 8.4 footage.
noNiCE77 wrote: ↑Thu Feb 03, 2022 8:35 amDid you succeed?RESET_9999 wrote: ↑Thu Dec 30, 2021 7:42 pmyes but the file has the 8.1 rpu from @quietvoid L1L2 HDR10 BL test file.
So after ups and downs with the delivery company I received my Xiaomi Mi TV 4K and can report on its capabilities.
Things that work:
- HEVC (high bitrate too) / AV1
- DTS (HD*) 5.1 & 7.1
— My Soundbar only shows “DTS Audio” for HD and compressed but by playing back the 5.1/7.1 HD Test files the channels are mapped correctly and it is highly likely passing through the right format using OMX.amlogic.audio.decoder.dtshd
- In the settings switching between TV-Led and Source-Led Dolby Vision
- DV MEL DT DL // DV 5 / 8.1 RPU
(Edit2)
- OTG Support with powered micro usb hub: 1TB External hard drive and ethernet. (around 120mbps)
EDIT: Things that don’t work now confirmed:
- DV (FEL DT DL)
— Tested with “black level pattern mp4/ts” & “RPU-FEL Test DT DL p7”, somebody please tell me what to look for in the last one. @Reset_9999 ?
Things that don’t work:
- TrueHD (any) +Atmos
- DTS:X
- The “Dolby Vision FEL Test p7.06 Dual Layer.mp4” I’m assuming it’s because it’s missing rpu? It plays until the 23 frame and then gets stuck.
- Any Single Layer Dual Track DV files
Things that work:
(Edit2)
- DV (FEL DT DL)
- DTS:X
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
You will see a video from another movie over the orange picture if FEL is used and a couple of flashes if the RPU is used.
Is there a reference image for that?RESET_9999 wrote: ↑Thu Feb 03, 2022 8:52 pmYou will see a video from another movie over the orange picture if FEL is used and a couple of flashes if the RPU is used.
I have Blank red until ~26sec then I get the Warner Bros over the red part, a stanley… over the blue part then clockwork over red switching to a movie scene at ~45
If you only see a blank red picture, it means FEL is not processed. I'll try to take a picture when I get home.
Do you see the flashes though?
I don’t get flashes with P7 only P5 and P8 RPU’s seem to work on the Amlogic S905Y4 sadly.RESET_9999 wrote: ↑Thu Feb 03, 2022 9:10 pm
If you only see a blank red picture only, it means FEL is not processed. I'll try to take a picture when I get home.
yep, unfortunately, it sounds like that device is doing fake DV with P7.mtotheb wrote: ↑Thu Feb 03, 2022 9:17 pmI don’t get flashes with P7 only P5 and P8 RPU’s seem to work on the Amlogic S905Y4 sadly.RESET_9999 wrote: ↑Thu Feb 03, 2022 9:10 pm
https://photos.google.com/share/AF1QipO ... h6VzZKWlFn
Here's what the FEL test looks like when FEL and RPU are 'working' as intended
thank's @staknhalo
the FEL and RPU test files can also be used to find out if your device uses the L5 active area metadata in the RPU.
if it uses L5, there will be black bars otherwise it will be fullscreen.
C8 internal player = black bars
Shield = full screen
x700 = full screen
x700 = full screen
Please tell me the way convert P5 to P8 of this file.
This file have not info of Mastering display luminance, Maximum Content Light Level, Maximum Frame-Average Light Le
RESET_9999 can you link me the files that i can test to see if dolby vision is correctly displayed?
I’have buy a minix u22 that must support dolby vision, i have try several bluray with DV ( converted to .ts format ) and all seem to play correctly…
Sorry for my english, i’m italian.
Ah, another question how i can convert a DTS audio bluray traks to AC3 5.1 ( or best ) , because my sound bar ( SONOS ARC ) not support DTS .
