NiCE77
#5986 Post by NiCE77 » Thu Feb 03, 2022 8:35 am
RESET_9999 wrote: Thu Dec 30, 2021 7:42 pm yes but the file has the 8.1 rpu from @quietvoid L1L2 HDR10 BL test file.
I'll try to edit the original HLG 8.4 footage.
Did you succeed?
#5987 Post by RESET_9999 » Thu Feb 03, 2022 12:05 pm
NiCE77 wrote: Thu Feb 03, 2022 8:35 am
Did you succeed?
no :(
mtotheb
#5988 Post by mtotheb » Thu Feb 03, 2022 8:35 pm
So after ups and downs with the delivery company I received my Xiaomi Mi TV 4K and can report on its capabilities.
Things that work:
- HEVC (high bitrate too) / AV1
- DTS (HD*) 5.1 & 7.1
— My Soundbar only shows “DTS Audio” for HD and compressed but by playing back the 5.1/7.1 HD Test files the channels are mapped correctly and it is highly likely passing through the right format using OMX.amlogic.audio.decoder.dtshd
- In the settings switching between TV-Led and Source-Led Dolby Vision
- DV MEL DT DL // DV 5 / 8.1 RPU
(Edit2)
- OTG Support with powered micro usb hub: 1TB External hard drive and ethernet. (around 120mbps)
EDIT: Things that don’t work now confirmed:
- DV (FEL DT DL)
— Tested with “black level pattern mp4/ts” & “RPU-FEL Test DT DL p7”, somebody please tell me what to look for in the last one. @Reset_9999 ?
Things that don’t work:
- TrueHD (any) +Atmos
- DTS:X
- The “Dolby Vision FEL Test p7.06 Dual Layer.mp4” I’m assuming it’s because it’s missing rpu? It plays until the 23 frame and then gets stuck.
- Any Single Layer Dual Track DV files
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
#5989 Post by RESET_9999 » Thu Feb 03, 2022 8:52 pm
mtotheb wrote: Thu Feb 03, 2022 8:35 pm — Tested with “RPU-FEL Test DT DL p7”, somebody please tell me what to look for in the last one. @Reset_9999 ?
You will see a video from another movie over the orange picture if FEL is used and a couple of flashes if the RPU is used.
mtotheb
#5990 Post by mtotheb » Thu Feb 03, 2022 9:06 pm
RESET_9999 wrote: Thu Feb 03, 2022 8:52 pm
Is there a reference image for that?
I have Blank red until ~26sec then I get the Warner Bros over the red part, a stanley… over the blue part then clockwork over red switching to a movie scene at ~45
#5991 Post by RESET_9999 » Thu Feb 03, 2022 9:10 pm
mtotheb wrote: Thu Feb 03, 2022 9:06 pm Is there a reference image for that?
If you only see a blank red picture, it means FEL is not processed. I'll try to take a picture when I get home.
Do you see the flashes though?
mtotheb
#5992 Post by mtotheb » Thu Feb 03, 2022 9:17 pm
RESET_9999 wrote: Thu Feb 03, 2022 9:10 pm
If you only see a blank red picture only, it means FEL is not processed. I'll try to take a picture when I get home.
I don’t get flashes with P7 only P5 and P8 RPU’s seem to work on the Amlogic S905Y4 sadly.
#5993 Post by RESET_9999 » Thu Feb 03, 2022 9:27 pm
mtotheb wrote: Thu Feb 03, 2022 9:17 pm
yep, unfortunately, it sounds like that device is doing fake DV with P7.
staknhalo
#5994 Post by staknhalo » Thu Feb 03, 2022 10:26 pm
https://photos.google.com/share/AF1QipO ... h6VzZKWlFn
Here's what the FEL test looks like when FEL and RPU are 'working' as intended
#5995 Post by RESET_9999 » Thu Feb 03, 2022 10:36 pm
thank's @staknhalo
the FEL and RPU test files can also be used to find out if your device uses the L5 active area metadata in the RPU.
if it uses L5, there will be black bars otherwise it will be fullscreen.
C8 internal player = black bars
Shield = full screen
x700 = full screen
Albano
#5996 Post by Albano » Fri Feb 04, 2022 4:45 am
nekno wrote: Mon Jan 31, 2022 1:07 am
OK, so you want to convert P5 to P8.1 but Apple is using an odd "max_display_mastering_luminance".
Please tell me the way convert P5 to P8 of this file.
This file have not info of Mastering display luminance, Maximum Content Light Level, Maximum Frame-Average Light Le
mimi8384
#5997 Post by mimi8384 » Fri Feb 04, 2022 2:06 pm
RESET_9999 can you link me the files that i can test to see if dolby vision is correctly displayed?
I’have buy a minix u22 that must support dolby vision, i have try several bluray with DV ( converted to .ts format ) and all seem to play correctly…
Sorry for my english, i’m italian.
Ah, another question how i can convert a DTS audio bluray traks to AC3 5.1 ( or best ) , because my sound bar ( SONOS ARC ) not support DTS .
#5998 Post by RESET_9999 » Fri Feb 04, 2022 3:05 pm
mimi8384 wrote: Fri Feb 04, 2022 2:06 pm RESET_9999 can you link me the files that i can test to see if dolby vision is correctly displayed?
the link is in my signature.
mimi8384 wrote: Fri Feb 04, 2022 2:06 pm Ah, another question how i can convert a DTS audio bluray traks to AC3 5.1 ( or best ) , because my sound bar ( SONOS ARC ) not support DTS .
I recommend converting to DD+ 1536kbps with ffmpeg:
ffmpeg.exe -i input.mkv -map 0:1 -c:a eac3 -b:a 1536k -c:s copy output.mkv
mimi8384
#5999 Post by mimi8384 » Fri Feb 04, 2022 4:06 pm
RESET_9999 wrote: Fri Feb 04, 2022 3:05 pm
But i not have the mkv file.I can demux m2ts file from bluray to obtain DTS audio track with TS MUXER, and then?
mimi8384
#6000 Post by mimi8384 » Fri Feb 04, 2022 4:32 pm
Tested “RPU-FEL Test DT DL p7” .mp4 and .ts, both show same images ( as your post ), but .mp4 stuck at 0,20” while .ts play entitely….so, DV work?
