My old LG drive is refusing to write so I just ordered an LG WH16NS60 which should arrive Friday along with an OWC enclosure.
I started reading about needing to flash the drive with a modified firmware to allow for UHD ripping.
I plan on using the SDFtool flasher as opposed to the command line version. My question is for that drive should I use the modified 1.02 version as I saw referenced in a different thread here, or the 1.03 which is in the latest firmware pack on these boards?
Thanks for any help you can provide.
Mike
LG WH16NS60 Drive question
Re: LG WH16NS60 Drive question
1.02-MK is good.mld218 wrote: Wed Jan 27, 2021 2:06 am My old LG drive is refusing to write so I just ordered an LG WH16NS60 which should arrive Friday along with an OWC enclosure.
Mike
hardcore_gamer29
why do you need to flash it as it is already official uhd drivemld218 wrote: Wed Jan 27, 2021 2:06 am My old LG drive is refusing to write so I just ordered an LG WH16NS60 which should arrive Friday along with an OWC enclosure.
Mike
It needs to be flashed to be able to rip UHD discs.hardcore_gamer29 wrote: Sat Jan 15, 2022 8:30 amwhy do you need to flash it as it is already official uhd drivemld218 wrote: Wed Jan 27, 2021 2:06 am My old LG drive is refusing to write so I just ordered an LG WH16NS60 which should arrive Friday along with an OWC enclosure.
Mike
hardcore_gamer29
then what is the use of buying a ofiicial uhd drive?MartyMcNuts wrote: Sat Jan 15, 2022 8:38 amIt needs to be flashed to be able to rip UHD discs.hardcore_gamer29 wrote: Sat Jan 15, 2022 8:30 amwhy do you need to flash it as it is already official uhd drivemld218 wrote: Wed Jan 27, 2021 2:06 am My old LG drive is refusing to write so I just ordered an LG WH16NS60 which should arrive Friday along with an OWC enclosure.
Mike
to officially playback UHD. but you cant because you have an nvidia GPUhardcore_gamer29 wrote: Sat Jan 15, 2022 8:49 am
didnt i recommend you get a WH14NS40 a few days ago? since you wanted internal 5.25 drive
hardcore_gamer29
thanks for help , i can use onboard intel uhd 630 also . my question is will this 16ns60 atleast read the uhd disk natively?Billycar11 wrote: Sat Jan 15, 2022 9:24 amto officially playback UHD. but you cant because you have an nvidia GPUhardcore_gamer29 wrote: Sat Jan 15, 2022 8:49 am
You could but your board only has HDMI 1.4 so no HDR unless your using display port or display port to HDMI and then you lose lossless audio.hardcore_gamer29 wrote: Sat Jan 15, 2022 2:15 pm thanks for help , i can use onboard intel uhd 630 also . my question is will this 16ns60 atleast read the uhd disk natively?
I'm telling you it's just better to go the unofficial play back route and flash your drive it's not a big deal I could send you 1000s of people who the stuff should work with powerdvd official but it does not.
Mostly because of sgx and a bug with power DVD that it only works with an old sgx and once you upgrade the sgx downgrade is no longer valid
hardcore_gamer29
hello sir, just received my wh16ns60 today and bluray works good with powerdvd 21 ultra? will 4k disk be read by this drive natively?Billycar11 wrote: Sat Jan 15, 2022 3:52 pmYou could but your board only has HDMI 1.4 so no HDR unless your using display port or display port to HDMI and then you lose lossless audio.hardcore_gamer29 wrote: Sat Jan 15, 2022 2:15 pm thanks for help , i can use onboard intel uhd 630 also . my question is will this 16ns60 atleast read the uhd disk natively?
Likely not but check with the UHD advisor app from cyber linkhardcore_gamer29 wrote: Thu Feb 03, 2022 1:11 pm hello sir, just received my wh16ns60 today and bluray works good with powerdvd 21 ultra? will 4k disk be read by this drive natively?
hardcore_gamer29
mine uhd drive came with 1.03 what should i do?Billycar11 wrote: Thu Feb 03, 2022 5:37 pmLikely not but check with the UHD advisor app from cyber linkhardcore_gamer29 wrote: Thu Feb 03, 2022 1:11 pm hello sir, just received my wh16ns60 today and bluray works good with powerdvd 21 ultra? will 4k disk be read by this drive natively?
You should follow my guide linked below.
Or get an automated flasher from me or Marty
hardcore_gamer29
can you send a link to firmware to downgrade 16ns60 from 1.03?MartyMcNuts wrote: Wed Jan 27, 2021 2:57 am1.02-MK is good.mld218 wrote: Wed Jan 27, 2021 2:06 am My old LG drive is refusing to write so I just ordered an LG WH16NS60 which should arrive Friday along with an OWC enclosure.
Mike
Yeah email me billycar5924@gmail.comhardcore_gamer29 wrote: Sun Feb 06, 2022 8:10 pm can you send a link to firmware to downgrade 16ns60 from 1.03?
hardcore_gamer29
will the downgrade also make the drive region free?Billycar11 wrote: Sun Feb 06, 2022 10:38 pmYeah email me billycar5924@gmail.comhardcore_gamer29 wrote: Sun Feb 06, 2022 8:10 pm can you send a link to firmware to downgrade 16ns60 from 1.03?
