Pioneer BDR XS07UHD
Umer Shahzad
- Contact:
Pioneer BDR XS07UHD
I have purchased this new ultra hd bluray drive from Amazon . Need guidance about its performace regarding ripping .
Re: Pioneer BDR XS07UHD
Assuming it is actually a Pioneer drive inside (MakeMKV can tell you that), then ripping UHD is not currently in your future. That may change, but right now, Pioneer drives will refuse to allow UHD disks to be read by non-approved programs.
DVD and regular BD, it should be fine.
Umer Shahzad
- Contact:
Respected Sir ! Can you further elaborate non approved programs . Further explain that how ripping can be possible for my drive . Latest updated version of this drive available since 2020 . What should do rip UHD . Need your suggestions ..
Approved software is Cyberdrive PowerDVD. Unfortunately, due to changes in Intel processors, the newest versions of PowerDVD won't even do that.
The firmware in Pioneer drives will prevent reading UHD disks without that (older version) software. And that software won't allow saving what is read to your local machine.
UHD Friendly drives (LG and Asus brands) can have firmware that will allow reading/saving UHD disks. This topic lists the current- and recent-production drives that can be used for UHD ripping, and how to enable it.
Pioneer hardware may be supported in the future; it will require firmware updates.
Umer Shahzad
- Contact:
Thanks for guidance . I have just searched on the webpage of Pioneer and latest update d firmware available since October,2020 . Can it be possible to rip 4k after updating to latest version . Right now I am using Intel Ci5 4690 processor in 4th generation motherboard . Keen to rip 4k UHD movies but unable to do . Kindly give your precious advice .
Not happening with that drive yetUmer Shahzad wrote: Thu Feb 03, 2022 5:21 pm Thanks for guidance . I have just searched on the webpage of Pioneer and latest update d firmware available since October,2020 . Can it be possible to rip 4k after updating to latest version . Right now I am using Intel Ci5 4690 processor in 4th generation motherboard . Keen to rip 4k UHD movies but unable to do . Kindly give your precious advice .
Nor firmware is going to make a difference
Umer Shahzad
- Contact:
Kindly suggest methods or tricks to rip UHD using this drive . What can we expect from such drive in near future .
There are no methods to rip UHD with this drive at all right nowUmer Shahzad wrote: Thu Feb 03, 2022 6:02 pm Not happening with that drive yet
Umer Shahzad
- Contact:
Billycar11 wrote: Thu Feb 03, 2022 6:10 pmThere are no methods to rip UHD with this drive at all right nowUmer Shahzad wrote: Thu Feb 03, 2022 6:02 pm Not happening with that drive yet
What can I expect in future ? Can it be possible to rip UHD in future?
The answer is, "Possibly, but not now."
If you plan on ripping UHD disks in 2022, the surest way to do it is to get a UHD-friendly drive.
I've been waiting 2 years (so far) for Pioneer support, but I have Asus and LG drives that do UHD just fine. If Pioneer support shows up someday, that adds one UHD and one non-UHD drive to my ripping array.
Umer Shahzad
- Contact:
Hope is still alive . I had purchased this UHD drive from Amazon last year in the month of May and the price was $175 . It is really a quality product . Outer body is in matte black with a silver coloured logo of bluray on the middle of drive . Light in weight so it is easy to adjust in smaller space .Woodstock wrote: Thu Feb 03, 2022 7:39 pm The answer is, "Possibly, but not now."
Just want to raise voice to allow this drive 4k UHD rip . Can you please send me the weblink,email or community support forum address to deliver my grievances .
You should try now.
Umer Shahzad
- Contact:
Where should I try ! Tell me the forum to raise voice .
Check this:
viewtopic.php?f=19&t=21503&start=30
Makemkv needs to have online access to load a new SDF.bin. Hopefully your Pioneer is also supported. No need to flash firmware.
Umer Shahzad
- Contact:
Kindly further elaborate it . What should I do ?Coopervid wrote: Fri Feb 11, 2022 6:28 pm Check this:
