MakeMKV 1.6.5 Application failed to initialize
dvdrcha
Re: MakeMKV 1.6.5 Application failed to initialize
Post by dvdrcha »
Same exact issue for me as well, I'm also running Win7 64-bit.
Tried re-installing in Admin mode but received same error.
Post by mike admin »
Please navigate to the folder where MakemKV is installed, run
makemkvcon info disc:0
and see if any errors show up.
shadeblack
Post by shadeblack »
Thanks for the fix!
I got the error with 1.6.5.
win7 64 bit.
killed a previous makemkv process that was still running.
Uninstalled makemkv.
cleaned registry.
installed, and working again.
lars69
Post by lars69 »
shadeblack wrote:Thanks for the fix!
win7 64 bit.
cleaned registry.
I'm new to this (and W7 for that matter) and try to figure out why the program insists on installing in the x86 Program files folder. Is it supposed to do that?
win7 64 bit.
cleaned registry.
Because MakeMKV is a hybrid application, both 32-bit and 64-bit. You may install it to any location.
