Asus BW-16D1HT: DVD and Blu-Ray regions
So, I need to change the Blu-Ray region on my Asus BW-16D1HT drive, but I can't seem to find out how to do it. When I open the properties for the drive in device manager, there's a tab for changing the DVD region. Does this also change the Blu-Ray region, or does that one need to be changed in some other way?
Also, when I purchased the drive, the DVD region was wrong, so I set it to the correct one. I then right afterwards flashed the 3.10MK firmware to make the drive UHD-compatible, but Windows still says that I can only change the DVD region four more times. Doesn't the counter get reset when I flash a firmware to the drive, and if not, how can I reset it? How many times can I change the Blu-Ray region?
Thanks in advance.
Kind regards:
Aksel Christoffersen
Thanks in advance.
Kind regards:
Re: Asus BW-16D1HT: DVD and Blu-Ray regions
why even bother with the region? makemkv works around all of thatakse0435 wrote: Tue Feb 01, 2022 10:11 am Hi,
Thanks in advance.
Kind regards:
When I first tried inserting a DVD bought in Denmark, where I live, MakeMKV said, that the region was wrong and that it tried to Work around the problem, but nothing happened. I haven't seen that error with Blu-Ray discs, so for all I know the Blu-Ray region on the drive could be wrong as well, and maybe MakeMKV doesn't care when it comes to Blu-Rays.
How old is your drive? I also have an ASUS BW-16D1HT. And I never had any problems with US DVDs while being European.
I bought it 2 weeks ago.
Can you copy what MakeMKV says about the drive on the right when you open it? the Drive and LibreDrive information.
Yes, I'll copy it when I get home from Work.
The reason I'm interested in changing the Blu-Ray region is, that I've just bought a Blu-Ray with region A, and I live in Denmark, which is region B. I haven't received the new Blu-Ray yet though, so I haven't tested it in the drive.
It's strange - usually when I rip out-of-region BDs, I simply end up with the movie and one or more files that display, "Sorry, this is a Region X disk, and cannot be played in your player." MakeMKV doesn't care. Bluray regions are almost always enforced in the menu of the BD, not the drive.
OK, here is what MakeMKV says about the drive. My MakeMKV is in danish, so I've tried to translate all the danish parameters back to english.
Manufacture: ASUS
Product: BW-16D1HT
Version: 3.10
Serial number: KLZL5EB2449
Encryption flag for databuss: 1F
Highest AACS version: 76
Firmware version: 3.10
Manufacture: ASUS
Product: BW-16D1HT
Version: 3.10
