I know that Final Cut Pro X can do that. See here: https://help.apple.com/finalcutpro/mac/ ... rbf72f3e96powdeau wrote: Sun Jan 30, 2022 4:55 pm Is there a way to convert HLG into HDR10 in order to convert it into DV?
mtotheb
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
anshulsaini
Hi Everyone,
I know the windows process using tsmuxer and CMD.
Can anyone help me with the process of doing this on a MAC?
Which files to download, where should I keep them, and what is the command line
I'm using Intel base Macbook 2016 running on macOS Monterey 12.2
jayper
Is it possible to create BDMV folders or ISO files with Dolby Vision Profile 8 files and have them properly play back on a UHD Disc player, like an Oppo? Or is profile 8 not supported by the BD player spec?
I am asking, as I only have an Nvidia Shield, x700 and an Oppo 203 clone, and from what I have gathered, the Shield does not have accurate coloring for Profile 8 DV.
I had pretty much the same question a week ago.jayper wrote: Sun Jan 30, 2022 7:53 pm Is it possible to create BDMV folders or ISO files with Dolby Vision Profile 8 files and have them properly play back on a UHD Disc player, like an Oppo? Or is profile 8 not supported by the BD player spec?
Is there any way to make these to 7.06 / Oppo compatible files?
jayper
I've been successful with TS files, but would prefer ISO or BDMV files as they have better usability support (chapters, track names, etc).Coopervid wrote: Sun Jan 30, 2022 8:05 pmI had pretty much the same question a week ago.jayper wrote: Sun Jan 30, 2022 7:53 pm Is it possible to create BDMV folders or ISO files with Dolby Vision Profile 8 files and have them properly play back on a UHD Disc player, like an Oppo? Or is profile 8 not supported by the BD player spec?
To clarify: The ISO and BDMV outputs from TSMuxer only have audio playback, video is blank.
How? There is a small chance to run then the resulting TS through BDRebuilder. Only a theory.
jayper
Use TSMuxer, select 'TS Muxing' as the output.Coopervid wrote: Sun Jan 30, 2022 10:31 pm How? There is a small chance to run then the resulting TS through BDRebuilder. Only a theory.
nekno
OK, so you want to convert P5 to P8 but Apple is using an odd "max_display_mastering_luminance".Robert89 wrote: Sun Jan 30, 2022 8:00 am no is what happens when I try to convert an appletv + web-dl.
in sum to explain myself better ... the first step.Code: Select all
dovi_tool -m 3 convert --discard dolby.hevc
If you check the file with MediaInfo, or check the file properties in a player like MPC-BE or MPC-HC, can you see if it has "Mastering display luminance" values?
For example, here's a random HDR10 file. If I play it in MPC-BE, right-click > Properties > MediaInfo tab, it shows:
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Le : 293 cd/m2
Using the example file above, MaxCLL is 1000 and MaxFALL is 293. If you don't have those values I believe you can leave them as 0 in your json file and they won't be changed.
If you can't find Mastering display luminance values, using 1000 and 50 should be safe value.
Make the file and save it as L6.json:
"cm_version": "V29",
"length": 0,
"level6": {
"min_display_mastering_luminance": 50,
"max_content_light_level": 1000,
"max_frame_average_light_level": 293
}Make the file and save it as mode3.json:
"mode": 3
dovi_tool extract-rpu dolby.hevc
dovi_tool editor -i RPU.bin -j L6.json -o RPU_L6.bin
dovi_tool editor -i RPU_L6.bin -j mode3.json -o RPU_p8.bin
dovi_tool inject-rpu -i dolby.hevc --rpu-in RPU_p8.bin -o dolby_p8.hevc
nekno
DV supports both HLG and HDR10 with different profile compatibility IDs.powdeau wrote: Sun Jan 30, 2022 4:55 pm Is there a way to convert HLG into HDR10 in order to convert it into DV?
DV P8.1 is P8 with an HDR10 base layer.
DV 8.4 is P8 with an HLG base layer.
So you don't necessarily need to convert from HLG to HDR10 to get DV, it just depends on your playback device.
The latest iPhones, iPads, and Apple TV, for example, support DV P8.4 with an HLG BL. I haven't seen if, e.g., Infuse is working with P8.4 properly yet.
A lot of variables depending on where you're trying to play a file.
nekno
I don't know about the other players, but the X700 wouldn't play P8 in BDMV format in my testing. It locked up the player with a black screen.jayper wrote: Sun Jan 30, 2022 7:53 pm Is it possible to create BDMV folders or ISO files with Dolby Vision Profile 8 files and have them properly play back on a UHD Disc player, like an Oppo? Or is profile 8 not supported by the BD player spec?
The only DV profile supported by UHD BD is P7, with either FEL or MEL.
The best combo of DV P8 + lossless audio + subtitles + FF/RW support on the X700 is to use tsMuxer to create m2ts files.
I also asked about this a week or so back, and to use BDMV format, we'd need a legitimate EL with the same frame types in the same order as each frame in the BL in order to carry the RPU. P7 doesn't support BL+RPU, it needs BL+EL+RPU.
I haven't seen anyone successfully accomplish that yet.
quietvoid mentioned he might think about adding support for generating an MEL to dovi_tool, which would make P8 or P5 conversions to P7 possible.
jayper
Thanks very much, appreciate all the insight.
powdeau
Thanks, I will play it on C7 or x700 but the problem is that madVR (madMeasureHDR) doesn't measure HLG video.nekno wrote: Mon Jan 31, 2022 1:12 amDV supports both HLG and HDR10 with different profile compatibility IDs.powdeau wrote: Sun Jan 30, 2022 4:55 pm Is there a way to convert HLG into HDR10 in order to convert it into DV?
looun
Should it be possible to create DV P4 or P8.2 (SDR compatibly ) from madVR HDR measurements?
i have tried Dynamic.HDR.Optimizer.exe with target nits 100 and --use-custom-targets parameters, but i don't see lot of change.
Can be very usell using Dynamic.HDR.Optimizer. + DV as dynamic tone mapping as madvr for projector, like or better than tips Dolby Vision/DTM with HDFury .
thanks.
thanks.
quietvoid
No, only profile 8.1 with HDR10 backwards compatibility is supported.looun wrote: Tue Feb 01, 2022 10:01 am Should it be possible to create DV P4 or P8.2 (SDR compatibly ) from madVR HDR measurements?
looun
ok , which is th best way to use Dynamic.HDR.Optimizer.exe with "target nits" and dovi_tool.exe with --use-custom-targets ?
