darrrkmanxxx
Post by darrrkmanxxx » Sun Jan 30, 2022 12:21 pm
Hey guys, many of the streaming versions contain e-ac-3+atmos, which doesn‘t exists on blu-rays. Blu-rays have usually a TrueHD Atmos and an E-AC-3 tracks. Unfortunately Truhd isn‘t supported by my tv, but e-ac3+atmos plays very well and sounds better that just e-ac3 or even dts-he master audio. Is there a way to take the atmos information from the TruHD Atmos track and embed ist into the e-ac-3, so we get the same as in streaming versions or even just downconvert truhd but keep the atmos?
My goal is to get from TrueHD Atrmos to E-AC-3 JOC (Dolby Digital Plus with Dolby Atmos)
Post by RESET_9999 » Sun Jan 30, 2022 1:52 pm
darrrkmanxxx wrote: Sun Jan 30, 2022 12:21 pm My goal is to get from TrueHD Atrmos to E-AC-3 JOC (Dolby Digital Plus with Dolby Atmos)
you need DEE for that. The best you can get right now is e-AC3 1536kbps with ffmpeg.
https://professional.dolby.com/product/ ... ng-engine/
https://www.rspeaudio.com/Dolby-Media-P ... -suite.htm
ffmpeg.exe -i E:\input.mkv -map 0:1 -c:a eac3 -b:a 1536k -c:s copy output.mkv
powdeau
Post by powdeau » Sun Jan 30, 2022 4:55 pm
Is there a way to convert HLG into HDR10 in order to convert it into DV?
mtotheb
Post by mtotheb » Sun Jan 30, 2022 6:13 pm
powdeau wrote: Sun Jan 30, 2022 4:55 pm Is there a way to convert HLG into HDR10 in order to convert it into DV?
I know that Final Cut Pro X can do that. See here: https://help.apple.com/finalcutpro/mac/ ... rbf72f3e96
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
anshulsaini
Post by anshulsaini » Sun Jan 30, 2022 7:00 pm
Hi Everyone,
I know the windows process using tsmuxer and CMD.
Can anyone help me with the process of doing this on a MAC?
Which files to download, where should I keep them, and what is the command line
I'm using Intel base Macbook 2016 running on macOS Monterey 12.2
jayper
Post by jayper » Sun Jan 30, 2022 7:53 pm
Is it possible to create BDMV folders or ISO files with Dolby Vision Profile 8 files and have them properly play back on a UHD Disc player, like an Oppo? Or is profile 8 not supported by the BD player spec?
I am asking, as I only have an Nvidia Shield, x700 and an Oppo 203 clone, and from what I have gathered, the Shield does not have accurate coloring for Profile 8 DV.
Post by Coopervid » Sun Jan 30, 2022 8:05 pm
jayper wrote: Sun Jan 30, 2022 7:53 pm Is it possible to create BDMV folders or ISO files with Dolby Vision Profile 8 files and have them properly play back on a UHD Disc player, like an Oppo? Or is profile 8 not supported by the BD player spec?
I had pretty much the same question a week ago.
Is there any way to make these to 7.06 / Oppo compatible files?
jayper
Post by jayper » Sun Jan 30, 2022 8:12 pm
Coopervid wrote: Sun Jan 30, 2022 8:05 pm
I've been successful with TS files, but would prefer ISO or BDMV files as they have better usability support (chapters, track names, etc).
To clarify: The ISO and BDMV outputs from TSMuxer only have audio playback, video is blank.
Post by Coopervid » Sun Jan 30, 2022 10:31 pm
How? There is a small chance to run then the resulting TS through BDRebuilder. Only a theory.
jayper
Post by jayper » Sun Jan 30, 2022 10:51 pm
Coopervid wrote: Sun Jan 30, 2022 10:31 pm How? There is a small chance to run then the resulting TS through BDRebuilder. Only a theory.
Use TSMuxer, select 'TS Muxing' as the output.
nekno
Post by nekno » Mon Jan 31, 2022 1:07 am
Robert89 wrote: Sun Jan 30, 2022 8:00 am no is what happens when I try to convert an appletv + web-dl.
in sum to explain myself better ... the first step.
dovi_tool -m 3 convert --discard dolby.hevc
OK, so you want to convert P5 to P8 but Apple is using an odd "max_display_mastering_luminance".
If you check the file with MediaInfo, or check the file properties in a player like MPC-BE or MPC-HC, can you see if it has "Mastering display luminance" values?
For example, here's a random HDR10 file. If I play it in MPC-BE, right-click > Properties > MediaInfo tab, it shows:
Mastering display luminance    : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level    : 1000 cd/m2
Maximum Frame-Average Light Le : 293 cd/m2
Then make a json file with those values.
Using the example file above, MaxCLL is 1000 and MaxFALL is 293. If you don't have those values I believe you can leave them as 0 in your json file and they won't be changed.
If you can't find Mastering display luminance values, using 1000 and 50 should be safe value.
Make the file and save it as L6.json:
    "cm_version": "V29",
    "length": 0,
    "level6": {
        "min_display_mastering_luminance": 50,
        "max_content_light_level": 1000,
        "max_frame_average_light_level": 293
Then you need to create a separate json file to set edit mode 3 to convert to P8.
Make the file and save it as mode3.json:
    "mode": 3
Then you need to extract the RPU, edit it the json file to set the L6 metadata, edit it again with the json file to convert it to P8, and then re-inject it.
dovi_tool extract-rpu dolby.hevc
dovi_tool editor -i RPU.bin -j L6.json -o RPU_L6.bin
dovi_tool editor -i RPU_L6.bin -j mode3.json -o RPU_p8.bin
dovi_tool inject-rpu -i dolby.hevc --rpu-in RPU_p8.bin -o dolby_p8.hevc
nekno
Post by nekno » Mon Jan 31, 2022 1:12 am
DV supports both HLG and HDR10 with different profile compatibility IDs.
DV P8.1 is P8 with an HDR10 base layer.
DV 8.4 is P8 with an HLG base layer.
So you don't necessarily need to convert from HLG to HDR10 to get DV, it just depends on your playback device.
The latest iPhones, iPads, and Apple TV, for example, support DV P8.4 with an HLG BL. I haven't seen if, e.g., Infuse is working with P8.4 properly yet.
A lot of variables depending on where you're trying to play a file.
nekno
Post by nekno » Mon Jan 31, 2022 1:36 am
I don't know about the other players, but the X700 wouldn't play P8 in BDMV format in my testing. It locked up the player with a black screen.
The only DV profile supported by UHD BD is P7, with either FEL or MEL.
The best combo of DV P8 + lossless audio + subtitles + FF/RW support on the X700 is to use tsMuxer to create m2ts files.
I also asked about this a week or so back, and to use BDMV format, we'd need a legitimate EL with the same frame types in the same order as each frame in the BL in order to carry the RPU. P7 doesn't support BL+RPU, it needs BL+EL+RPU.
I haven't seen anyone successfully accomplish that yet.
quietvoid mentioned he might think about adding support for generating an MEL to dovi_tool, which would make P8 or P5 conversions to P7 possible.
jayper
Post by jayper » Mon Jan 31, 2022 1:54 am
Thanks very much, appreciate all the insight.
powdeau
Post by powdeau » Mon Jan 31, 2022 12:06 pm
nekno wrote: Mon Jan 31, 2022 1:12 am
Thanks, I will play it on C7 or x700 but the problem is that madVR (madMeasureHDR) doesn't measure HLG video.
