LG WH16NS40 - Downgraded to 1.02MK - Sleep Bug Fix to 1.01MK
djdownfawl
Post by djdownfawl »
I just bought a LG WH16NS40 and successfully downgraded to 1.02MK. Everything is working fine except while ripping a UHD disc, it will stop spinning half-way and the only solution is to eject the disc. I know this is called the sleep bug and the recommended option is to downgrade to 1.01MK for MakeMKV.
But my question is what do I lose from downgrading from 1.02 to 1.01?
Thank you
Re: LG WH16NS40 - Downgraded to 1.02MK - Sleep Bug Fix to 1.01MK
Show us your makemkv drive info
Stalling at the layer break half way is usually a sign of a bad drive.
That's not the sleep bug the sleep bug does not happen while the drive is ripping
djdownfawl
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLZL25E4014
Highest AACS version: 68
Firmware version: 1.02
djdownfawl
Please see attached.
Screenshot 2022-01-31 125845.png (80.52 KiB) Viewed 6069 times
djdownfawl wrote: Mon Jan 31, 2022 5:59 pm Please see attached.
First thing to try is clean the discs
Then replace them
Then if it still happens clean the laser
After that time for a BU40N
