Re: SDFtool Flasher
Post by MartyMcNuts » Tue Jan 25, 2022 9:58 pm
eatont9999 wrote: Tue Jan 25, 2022 9:03 pm I just flashed my new LG WH16NS60 drive from its original 1.03 firmware to the MK/old/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin and selected non-encrypted. It seems to read Blu-ray discs but not UHD disks. It would read either one before the flash but I couldn't rip UHD disks, obviously. Now it just sits there seeking and MakeMKV says the disc is being loaded. It does not move from that status.
I had to connect it via SATA due to the recent Vantec issues. I did all flashing connected via SATA. Before it would give me a handshake error.
I tried version 1.01 and 1.03 but both do the same thing. Is it me doing something wrong or is this process not working with the latest drives. Mine was manufactured on 2021-08-18, SVC Code: NS60, ROM: 1.03.
Any help is appreciated.
Are you sure it actually flashed?? As 1.03 is encrypted, so you need to make sure encrypted is checked before flashing. Show us your MakeMKV info.
ThatOneGuy
Re: SDFtool Flasher
Post by ThatOneGuy » Wed Jan 26, 2022 4:22 am
As of recent I've been opting to get the 4k Blu Ray disc, as it comes with the standard Blu Ray disc as well.
After some reading it turns out the Blu Ray drive I have can do 4k with patched firmware. 10 minutes later (more reading, then flashing) I can confirm that this works!
I have the Asus BW-16D1HT and its working like a charm!
Thank you!
So glad that I paid for MakeMKV a while ago!
eatont9999
Re: SDFtool Flasher
Post by eatont9999 » Thu Jan 27, 2022 3:59 am
Here is what MakeMKV states under info:
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: M00L8JA4004
Highest AACS version: 76
Firmware version: 1.02
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Jan 27, 2022 10:39 pm
eatont9999 wrote: Thu Jan 27, 2022 3:59 am Here is what MakeMKV states under info:
OS device name: F:
Revision: 1.02
Yep, flashed and ready. If using it in the Vantec, make sure the drive is getting enough power. Either connect to USB on motherboard directly or to a USB hub that has it's own seperate power supply. Also, if you get some read errors, clean the disc before trying again.
thatmediaguy
Re: SDFtool Flasher
Post by thatmediaguy » Sat Jan 29, 2022 11:13 pm
I just tried this on an ASUS 16D1HT. I am getting an erorr message that says "Command produced error code 0x8f052400.
What does this mean? I was flashing to the file called "DE_ASUS_BW-16D1HT_1.01.bin"
Note when I chose my drive the drive details were:
"D: ASUS_BW-16D1HT_3.02_211711241413_KL9K15G1611"
Re: SDFtool Flasher
Post by Billycar11 » Sat Jan 29, 2022 11:15 pm
thatmediaguy wrote: Sat Jan 29, 2022 11:13 pm I just tried this on an ASUS 16D1HT. I am getting an erorr message that says "Command produced error code 0x8f052400.
Who told you to flash Asus 1.01 your trying to kill your drive
thatmediaguy
Re: SDFtool Flasher
Post by thatmediaguy » Sat Jan 29, 2022 11:30 pm
Yikes maybe I am confused. What firmware should I be tryng to flash this too?
I had originally flashed this some time ago. Then all of a sudden the drive started not recognizing certain drives. So I thought perhaps there was an issue. I just noticed that the firmware is 1.02 on the drive and this led me to believe that maybe I had flashed it with the wrong firmware orginaly.
Is 1.02 the right firmware? And if so whey is the drive not reading certain 4k UHD disks?
thatmediaguy
Re: SDFtool Flasher
Post by thatmediaguy » Sat Jan 29, 2022 11:36 pm
To be clear this is my drive information:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: KL9K15G1611
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Highest AACS version: 66
Firmware version: 3.02
Re: SDFtool Flasher
Post by Billycar11 » Sat Jan 29, 2022 11:37 pm
thatmediaguy wrote: Sat Jan 29, 2022 11:30 pm Yikes maybe I am confused. What firmware should I be tryng to flash this too?
If it sees or saw UHD discs your are fine I responded to you in another post about turning the drive off if it no longer sees discs
freakdiablo
Re: SDFtool Flasher
Post by freakdiablo » Sun Feb 06, 2022 8:16 pm
Hey, sorry new member here and don't know if it's been covered.
Downloaded and tried v1.31, but the window is coming up compressed -
Using a fairly fresh W10 install, anything I need to add?
Re: SDFtool Flasher
Post by d00zah » Sun Feb 06, 2022 10:08 pm
freakdiablo wrote: Sun Feb 06, 2022 8:16 pm Hey, sorry new member here and don't know if it's been covered.
Had you read through this very thread... viewtopic.php?f=16&t=22896&start=330#p114370
bd-one
Re: SDFtool Flasher
Post by bd-one » Wed Feb 09, 2022 6:29 am
Hi, I did a search but couldn't find any similar errors.
I can't run the latest v1.3.1 sdftool flasher on my Win7 x64 Pro install. It comes up with the error here:
Am I missing some dependency?
Re: SDFtool Flasher
Post by d00zah » Wed Feb 09, 2022 2:20 pm
bd-one wrote: Wed Feb 09, 2022 6:29 am Hi, I did a search but couldn't find any similar errors.
I had the same issue w/ Win 7 X64 & guessed it was a component of some Win dev stuff I otherwise didn't need? Downloaded the .dll from a trusted source, dropped it in the dir w/ SDFTool. No more error. It was more direct than doing research to determine what was missing. YMMV
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Feb 09, 2022 10:04 pm
That is because Win 10 x64 is a requirement.
bd-one
Re: SDFtool Flasher
Post by bd-one » Thu Feb 10, 2022 4:31 am
MartyMcNuts wrote: Wed Feb 09, 2022 10:04 pm
DERP. I see it now, right in the OP, under requirements. Thanks.
