2021 Dune 4K UHD - Failed to Open Disc
Re: 2021 Dune 4K UHD - Failed to Open Disc
Post by d00zah »
lcsbaldy wrote: Mon Jan 24, 2022 8:16 pm The volume key is unknown for this disc.
From the UHD FAQ...
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
This will get results more quickly than posting dump to forum...
pesos
Post by pesos »
Hmm I tried a decrypt/backup but didn't get a tgz file... i got all the text below and now even after a reboot i'm getting "no disc" in makemkv?
MakeMKV v1.16.5 win(x64-release) started
Using LibreDrive mode (v06.2 id=64754CF46FCA)
Backing up disc into folder "E:/backups/DUNE"
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO9L1UA3518' at offset '97339506688'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO9L1UA3518' at offset '97339508736'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO9L1UA3518' at offset '97343373312'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO9L1UA3518' at offset '97343391744'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO9L1UA3518' at offset '6225920'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO9L1UA3518' at offset '1804468224'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO9L1UA3518' at offset '1804474860'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while ...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MO9L1UA3518' at offset '97338329088'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/AACS/Content002.cer' at offset '0'
Encountered 1 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup failed
pesos wrote: Wed Jan 26, 2022 11:27 pm Hmm I tried a decrypt/backup but didn't get a tgz file... i got all the text below and now even after a reboot i'm getting "no disc" in makemkv?
Backup failed
Your drive is not getting enough power it rebooted and no longer has the removed buss encryption and that why you get the key error use both USB plugs or get a high powered usb hub
sahzed
Post by sahzed »
I emailed a dump file for Dune 4K UHD + BluRay I got off Amazon (looks like the same dump file name that lcsbaldy attached here a few days ago, MKB20_v76_Dune_96FE.tgz) to svq@makemkv.com on the 23rd, but no luck yet. I have "Enable internet access" on - is the idea then just keep trying until it eventually works? Just want to make sure I don't have to do anything else.
sahzed
Post by sahzed »
Well speak of the devil, an hour later and it's working now, it it looks like the key was added!
pesos
Post by pesos »
Billycar11 wrote: Thu Jan 27, 2022 12:03 am
The strange thing is nothing at all had been physically touched (both usbs have been plugged in for weeks). Didn't mess with the usb cables at all but went ahead and fully powered off the computer and back on and it is detecting again (and seems to be decrypting fine so far) - thank you!
Jaborvols
Post by Jaborvols »
Similar thing happened to me. Tried it with a European Disc and at first it failed at opening the disc (dump file already sent), then it suddenly stopped recognizing the disc altogether.
Now it just rattles for a minute or so and shows "no disc". Really weird. Other UHDs work just fine.
muabDib
Post by muabDib »
JulesKeeper wrote: Thu Jan 13, 2022 4:43 pm Mine is working now. Thank you Mike
I got the same message on my Dune 4K UHD disc. Did you take a specific action to make it work? If I understand correctly, we all send the tgz files in and Mike makes changes so that, if your MakeMKV installation is configured for internet access, it should go retrieve the necessary info to decrypt the disc. Is that right? If that's correct, then I guess I have a version of the Dune 4K disc that has not been seen yet by users of MakeMKV (or at least not sent in). Should I then send in my tgz dump file?
muabDib wrote: Thu Feb 17, 2022 1:02 pm I got the same message on my Dune 4K UHD disc. Did you take a specific action to make it work? If I understand correctly, we all send the tgz files in and Mike makes changes so that, if your MakeMKV installation is configured for internet access, it should go retrieve the necessary info to decrypt the disc. Is that right? If that's correct, then I guess I have a version of the Dune 4K disc that has not been seen yet by users of MakeMKV (or at least not sent in). Should I then send in my tgz dump file?
Yes, MakeMKV will download the necessary things if configured to access the internet (and your internet isn't blocking things; the server it downloads from is in Russia). Sometimes, movies have more than one key, so yes you should send in your .tgz file.
Read more about Fixing Volume Key is Unknown
Andy_Tsunami
Post by Andy_Tsunami »
Submitted Dump for Australian Retail (JB Hi-Fi)
cranks
Post by cranks »
by Andy_Tsunami » Fri Mar 04, 2022 7:35 pm
I can't open disk ..Purchased yesterday in JBHiFi and cant open disk...no dump file created.
Is yours working ok??
Cancel that! It is working now!
lslmtl
Post by lslmtl »
Not sure where to submit this, but here's my dump, from Dune 4K purchased in Canada.
MKB20_v76_Dune_3611.tgz
(184.73 KiB) Downloaded 502 times
Post by d00zah »
lslmtl wrote: Sun May 15, 2022 11:10 pm Not sure where to submit this, but here's my dump, from Dune 4K purchased in Canada.MKB20_v76_Dune_3611.tgz
Suggested reading... UHD FAQ
lslmtl
Post by lslmtl »
Thanks, from that post, my dump was sent automatically and all I have to do is retry in a few days. Awesome!!
Post by d00zah »
lslmtl wrote: Tue May 17, 2022 2:10 pm Thanks, from that post, my dump was sent automatically and all I have to do is retry in a few days. Awesome!!
Not quite. Dumps are generated automatically, but MUST be manually emailed to svq@makemkv.com.
