Sound playback issues
jimmyboy0727
Post by jimmyboy0727 » Tue Jan 25, 2022 8:11 pm
I haven't used this in a while, under the trial now until the admin can get back to me as I upgraded my computer and lost my key. My dilemma is that I'm trying to record ghostbusters 2. If I do the whole 28 gig version, I get sound. The problem is, that it's not the English version. So I go back and check only the English sound to be used and the movie plays back with no sound at all. I am just trying to put the movie on my hard drive to save space from collecting discs anymore. Any ideas or suggestions?
Re: Sound playback issues
Post by dcoke22 » Wed Jan 26, 2022 1:17 am
What does MediaInfo say about your .mkv file? Amongst the data it shows, it should tell us something about the audio tracks in your .mkv file.
For example…
Audio #1
Format                                   : DTS XLL
Commercial name                          : DTS-HD Master Audio
Duration                                 : 1 h 48 min
Bit rate                                 : 3 895 kb/s
Channel layout                           : C L R Ls Rs LFE
Stream size                              : 2.95 GiB (12%)
Audio #2
Format                                   : DTS
Bit rate                                 : 1 509 kb/s
Stream size                              : 1.14 GiB (5%)
jimmyboy0727
Post by jimmyboy0727 » Wed Jan 26, 2022 1:43 pm
I hope this helps. I am not familiar with this program. When I test it on the computer, it shows english as the first option, when it plays, it's in French. If I record it over with just the english option, it has no sound at all.
Post by dcoke22 » Wed Jan 26, 2022 3:41 pm
This tells us that your file has audio tracks in it and that the problem probably is with playback.
How are you playing it?
jimmyboy0727
Post by jimmyboy0727 » Wed Jan 26, 2022 5:40 pm
I was testing on my computer with windows 11 media player, saved to a 12TB extrenal HD that I pplug into the TV or blu-ray player to watch.
Post by dcoke22 » Wed Jan 26, 2022 6:10 pm
Can you try VLC or MPV?
Personally, I have no experience with Windows 11 or the Windows Media Player.
jimmyboy0727
Post by jimmyboy0727 » Wed Jan 26, 2022 6:16 pm
Can't say I'm familiar to that, those other apps/programs?
jimmyboy0727
Post by jimmyboy0727 » Wed Jan 26, 2022 7:39 pm
I just plugged it into the blu-ray player and it runs with english...... really odd!
ArArdin
Post by ArArdin » Fri Jan 28, 2022 9:49 pm
jimmyboy0727 wrote: Tue Jan 25, 2022 8:11 pmIf I do the whole 28 gig version, I get sound. The problem is, that it's not the English version.
Chances are that the bluraydisc is authored with another audiolanguage as default track, and/or in your player's settings, audio language is set to another default. The first audiotrack in the list does not necessarily mean it's flagged as default.
Doing the whole version would let MakeMKV mux all audio-tracks. In which case it's always possible to select your desired audiotrack with the AUDIO-key on the remote of your bluray player.
albert90
Post by albert90 » Sun Jan 30, 2022 9:35 pm
jimmyboy0727 wrote: Wed Jan 26, 2022 6:16 pm Can't say I'm familiar to that, those other apps/programs?
They are, they're other video players. I consider VLC a staple for media playback, highly recommend you try it over the default Windows video player.
Post by dcoke22 » Wed Feb 02, 2022 1:39 am
Pierrea wrote: Tue Feb 01, 2022 9:29 am Same issue here and i cant find any solutions
Which player are you using? Have you tried a different player?
