At first, when MakeMKV was doing the initial scan of this disc, it jerked the player around sounding like something was stuck about halfway through. it said protection was too tough, and was trimming instead. I freaked out and hit eject thinking my Drive was broken. I ripped another DVD and it worked fine, so I tried "HG Catching Fire" again... same place, it started jerking again, but I let it do it this time. About a minute later, it finally got to the results screen. There were 6 selections for the main movie (like there were 6 different movies on this disc), all checkmarked, with slightly different sizes and chapter counts, but the other details were the same (languages, subtitles, aspect ratio, etc...) considering this DVD can only hold probably 7 or 8GB of data, I doubt there are 6 x 6GB movie files on here... I am currently ripping all of them to see which one (if any) are real...
The dummy files are annoying and time consuming, but this thing wrenching my DVDrom drive like that can't be good, what is going on?
"The Hunger Games Catching Fire" dummy files? almost breaks?
barmst
barmst
Re: "The Hunger Games Catching Fire" dummy files? almost bre
Here is a partial copy of the log during this attempt
Sometime around the "trying CellTrim algorithm" part was when I had to sit here while my DVDrom was grinding and jerking (who cares about a $20 Disc Drive when we have experiments to run, right?)... after about a minute of that noise, it continued seemingly normal...
At this point, my DVDrom started to sound like it was jerking and grinding again, so I halted the operation. It appears that "t05" is the legit copy, as the other 4 I looked at (t06 - t09) had a misplaced scene at the start... I will find out when I get around to watching the whole thing, but everything seemed to be in order as i skipped around watching scenes. "t10" seemed to be the one with all of the issues with messing up my DVDrom... I hope it didn't do any permanent damage to it.
Title #2 was added (2 cell(s), 0:06:43)
Title #3 was added (6 cell(s), 0:04:35)
Title #4 was added (2 cell(s), 0:02:30)
Title #5 was added (2 cell(s), 0:02:30)
Title #6 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 was added (1 cell(s), 0:19:05)
Title #15 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Title #19 was added (25 cell(s), 2:25:55)
Title #20 was added (25 cell(s), 2:25:55)
Title #21 was added (23 cell(s), 1:50:42)
Title #23 was added (28 cell(s), 2:26:05)
Title #24 was added (25 cell(s), 2:25:55)
Title #26 was added (25 cell(s), 2:25:55)
Title #28 was added (25 cell(s), 2:02:40)
Title #29 was added (24 cell(s), 1:56:40)
Title #30 was added (25 cell(s), 2:25:55)
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithmCode: Select all
Title #31 was added (25 cell(s), 2:25:55)
Title #32 was added (25 cell(s), 2:02:40)
Title #33 was added (29 cell(s), 2:31:40)
Title 1 in VTS 19 is equal to title 1 and was skipped
Title 1 in VTS 28 is equal to title 1 and was skipped
Saving 6 titles into directory X:/MOVIES 13/H
AV synchronization issues were found in file 'X:/MOVIES 13/H/The_Hunger_Games_Catching_Fire_t06.mkv' (title #7)
AV sync issue in stream 1 at 0:00:00.001 with duration of 160ms : 5 early frame(s) dropped at start
AV sync issue in stream 0 at 0:00:02.535 : video frame timecode differs by +47.066ms
AV sync issue in stream 1 at 0:00:02.337 with duration of 1226.545ms : audio gap - 38.329 missing frame(s)
AV sync issue in stream 0 at 0:00:07.540 : video stream has 10 frames with invalid timecodes
AV synchronization issues were found in file 'X:/MOVIES 13/H/The_Hunger_Games_Catching_Fire_t07.mkv' (title #8)
AV synchronization issues were found in file 'X:/MOVIES 13/H/The_Hunger_Games_Catching_Fire_t08.mkv' (title #9)
AV synchronization issues were found in file 'X:/MOVIES 13/H/The_Hunger_Games_Catching_Fire_t09.mkv' (title #10)
AV synchronization issues were found in file 'X:/MOVIES 13/H/The_Hunger_Games_Catching_Fire_t10.mkv' (title #11)
AV sync issue in stream 1 at 2:26:21.492 with duration of 897.678ms : audio gap - 28.052 missing frame(s)
AV sync issue in stream 0 at 2:26:21.506 : video frame timecode differs by +47.066ms
AV sync issue in stream 1 at 2:26:27.999 with duration of 32ms : broken timecode, apparent audio skew is -130.5ms
AV sync issue in stream 1 at 2:26:29.631 with duration of 32ms : broken timecode, apparent audio skew is -261ms
AV sync issue in stream 1 at 2:26:31.263 with duration of 32ms : broken timecode, apparent audio skew is -391.5ms
AV sync issue in stream 1 at 2:26:32.895 with duration of 32ms : broken timecode, apparent audio skew is -522ms
AV sync issue in stream 1 at 2:26:34.527 with duration of 32ms : broken timecode, apparent audio skew is -652.5ms
AV sync issue in stream 1 at 2:26:36.159 with duration of 32ms : broken timecode, apparent audio skew is -783ms
AV sync issue in stream 1 at 2:26:37.791 with duration of 32ms : broken timecode, apparent audio skew is -913.5ms
AV sync issue in stream 1 at 2:26:39.423 with duration of 32ms : broken timecode, apparent audio skew is -1044ms
AV sync issue in stream 1 at 2:26:41.055 with duration of 32ms : broken timecode, apparent audio skew is -1174.5ms
AV sync issue in stream 1 at 2:26:42.687 with duration of 32ms : broken timecode, apparent audio skew is -1305ms
AV sync issue in stream 1 at 2:26:44.319 with duration of 32ms : broken timecode, apparent audio skew is -1435.5ms
AV sync issue in stream 1 at 2:26:45.951 with duration of 32ms : broken timecode, apparent audio skew is -1566ms
AV sync issue in stream 1 at 2:26:47.583 with duration of 32ms : broken timecode, apparent audio skew is -1696.5ms
AV sync issue in stream 1 at 2:26:49.215 with duration of 32ms : broken timecode, apparent audio skew is -1827ms
AV sync issue in stream 1 at 2:26:50.847 with duration of 32ms : broken timecode, apparent audio skew is -1957.5ms
AV sync issue in stream 1 at 2:26:52.479 with duration of 32ms : broken timecode, apparent audio skew is -2088ms
AV sync issue in stream 1 at 2:26:54.111 with duration of 32ms : broken timecode, apparent audio skew is -2218.5ms
AV sync issue in stream 1 at 2:26:55.743 with duration of 32ms : broken timecode, apparent audio skew is -2349ms
AV sync issue in stream 1 at 2:26:57.375 with duration of 32ms : broken timecode, apparent audio skew is -2479.5ms
AV sync issue in stream 1 at 2:26:59.007 with duration of 32ms : broken timecode, apparent audio skew is -2610ms
AV sync issue in stream 1 at 2:27:00.639 with duration of 32ms : broken timecode, apparent audio skew is -2740.5ms
AV sync issue in stream 1 at 2:27:02.271 with duration of 32ms : broken timecode, apparent audio skew is -2871ms
AV sync issue in stream 1 at 2:27:03.903 with duration of 32ms : broken timecode, apparent audio skew is -3001.5ms
AV sync issue in stream 1 at 2:27:05.535 with duration of 32ms : broken timecode, apparent audio skew is -3132ms
AV sync issue in stream 1 at 2:27:07.167 with duration of 32ms : broken timecode, apparent audio skew is -3262.5ms
AV sync issue in stream 1 at 2:27:08.799 with duration of 32ms : broken timecode, apparent audio skew is -3393ms
AV sync issue in stream 1 at 2:27:10.431 with duration of 32ms : broken timecode, apparent audio skew is -3523.5ms
AV sync issue in stream 1 at 2:27:12.063 with duration of 32ms : broken timecode, apparent audio skew is -3654ms
AV sync issue in stream 1 at 2:27:13.695 with duration of 32ms : broken timecode, apparent audio skew is -3784.5ms
AV sync issue in stream 1 at 2:27:15.327 with duration of 32ms : broken timecode, apparent audio skew is -3915ms
AV sync issue in stream 1 at 2:27:16.959 with duration of 32ms : broken timecode, apparent audio skew is -4045.5ms-
djstarfox
Re: "The Hunger Games Catching Fire" dummy files? almost breaks?
I'm having the same problem. Did you figure it out? T5 is way too short to be the movie.
