I tried burning a Blu-Ray but kept getting errors
wisetone
Post by wisetone » Mon Jan 24, 2022 9:04 pm
When I tried to burn a film at the last 88 percent of the process it says
MakeMKV v1.16.5 win(x64-release) started
Uses direct access option
Loaded contents of control table, trying to validate integrity of M2TS files.
File 00025.mpls was added as title #0
File 00034.mpls was added as title #1
Title 00000.mpls is the same as title 00034.mpls and is skipped
File 00008.mpls was added as title #2
Title #00001.m2ts has a length of 12 seconds, which is less than the minimum title length of 120 seconds and is therefore skipped
Title #00002.m2ts has a length of 10 seconds which is less than the minimum title length of 120 seconds and is therefore skipped
Title #00003.m2ts has a length of 1 second which is less than the minimum title length of 120 seconds and is therefore skipped
Title #00010.m2ts has a length of 23 seconds which is less than the minimum title length of 120 seconds and is therefore skipped
File 00013.m2ts was added as title #3
File 00014.m2ts was added as title #4
Title #00017.m2ts has a length of 0 seconds, which is less than the minimum title length of 120 seconds and is therefore skipped
File 00027.m2ts was added as title #5
File 00028.m2ts was added as title #6
File 00029.m2ts was added as title #7
File 00030.m2ts was added as title #8
File 00031.m2ts was added as title #9
File 00032.m2ts was added as title #10
File 00033.m2ts was added as title #11
Title #00034.m2ts has a length of 92 seconds, which is less than the minimum title length of 120 seconds and is therefore skipped
File 00035.m2ts was added as title #12
File 00036.m2ts was added as title #13
Title #00042.m2ts has a length of 52 seconds, which is less than the minimum title length of 120 seconds and is therefore skipped
Action taken
Save 1 title to folder D:/vedeo/CHARLIE_AND_THE_CHOCO
Title 1 was skipped
0 titles saved
Saves 1 title to folder D:/vedeo/CHARLIE_AND_THE_CHOCO
Error 'SCSI error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred when reading '/BDMV/STREAM/00070.m2ts' at offset '22987536384'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred when reading '\Device\CdRom0' at offset '22987536384'
Error 'SCSI error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred when reading '/BDMV/STREAM/00070.m2ts' at offset '22990221312'
Error 'SCSI error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred when reading '/BDMV/STREAM/00070.m2ts' at offset '22990614528'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred when reading '\Device\CdRom0' at offset '22990614528'
Error 'SCSI error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred when reading '/BDMV/STREAM/00070.m2ts' at offset '22991468544'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred when reading '\Device\CdRom0' at offset '22991468544'
Error 'SCSI error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred when reading '/BDMV/STREAM/00070.m2ts' at offset '22991861760'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred when reading '\Device\CdRom0' at offset '22991861760'
Error 'OS error -
Translated with www.DeepL.com/Translator (free version)
Re: I tried burning a Blu-Ray but kept getting errors
Post by Woodstock » Mon Jan 24, 2022 9:25 pm
Burning isn't ripping. MakeMKV does ripping.
The error messages are consistent with a USB-powered drive spinning too fast for the power available to it. Make sure that the cable is plugged into a FULLY POWERED USB port, not an external hub (unless it has its own power supply).
wisetone
Post by wisetone » Mon Jan 24, 2022 9:40 pm
I use this blu ray player to rip them with Pioneer BDR-XD07TB I only have the usb connection to use cause my laptop doesn't have any disc drive :/
Post by Woodstock » Mon Jan 24, 2022 10:04 pm
In any case, USB-powered drives require fully-powered ports. Some require TWO powered ports, and come with a 2-headed cable. It is not normally a problem because most programs won't spin the drive at full speed... but MakeMKV can. When the drive tries to pull too much power from the port, the drive resets mid-rip.
If you're using the drive on a laptop, look at buying a POWERED USB hub that can provide at least 1 amp. USB 3 ports with a power supply are a good bet.
Some drives can have their speed limited in MakeMKV, but Pioneer drives don't do that right now.
wisetone
Post by wisetone » Mon Jan 24, 2022 10:22 pm
Maybe if I use my gaming desktop computer it would help?
Post by Woodstock » Mon Jan 24, 2022 10:40 pm
What ever allows you to get enough current to the drive for the higher speeds you will see on longer rips.
wisetone
Post by wisetone » Mon Jan 24, 2022 11:06 pm
I found out what the problem was, there is a protection on the blu-ray called AACS v12 which preventing me from ripping it.
Post by Woodstock » Tue Jan 25, 2022 12:01 am
AACS v12 is ANCIENT. v76 has been out for a year now, and MakeMKV v1.16.5 can handle any AACS version up to 76 (higher with LibreDrive-compatible drives).
If you were experiencing an AACS issue, you wouldn't get any part of it ripped.
