UHD (Official) Friendly Drive - Archgon MD-8107S-U3-UHD (Powered by LG BU40N)
Re: UHD (Official) Friendly Drive - Archgon MD-8107S-U3-UHD (Powered by LG BU40N)
#46 Post by Billycar11 » Sun Jan 03, 2021 12:26 pm
telex wrote: Sun Jan 03, 2021 11:46 am which is the right firmware for MD-8107S-U3YC-UHDB-S ?
HL-DT-ST-BD-RE_BU40N-U100-3M01801-211910161036.bin
or
HL-DT-ST-BD-RE_BU40N-1.01-RM00000-211712221221.bin
or
HL-DT-ST-BD-RE_BU40N-U101-MM01201-211711301153.bin
or
HL-DT-ST-BD-RE_BU40N-1.01-RM01801-211910161032.bin
I cant see a "1.00" ....
If you want 1.00 so bad it's here: https://www.makemkv.com/forum/viewtopic ... 873#p70284
telex
#47 Post by telex » Sun Jan 03, 2021 2:44 pm
this?
DE_LG BU40N_1.00.bin
is the right for MD-8107S-U3YC-UHDB-S ?
#48 Post by MartyMcNuts » Sun Jan 03, 2021 10:49 pm
or
or
or
I'm not familiar with a model with an "S" at the end?
Anyway, there is no 1.00 in the MK firmware as 1.00 is the stock,already enable firmware (so no need for an MK version). You can find it in the firmware pack provided with the modified ASUS flasher. The firmware is called DE_LG_BU40N_1.00.
metroplex2k7
#49 Post by metroplex2k7 » Wed Mar 10, 2021 2:32 pm
Hi guys, new to the forums. My fiance bought this drive. It is the MD-8107S-U3 (it does not have the -UHD at the end, but on the front of the drive it does say Ultra HD). So it included the shitty Cyberlink software which didn't work. She couldn't even watch 1080 BluRays on it. We found a way to get it to work on VLC Player. But we can NOT find a way to play UHD. She just wants to watch her UHD disks, nothing more. I hope you guys can help. I see mention of a firmware downgrade. Is there a step by step for dummies to do that? We've tried VLC Player, Windows Media Player, MakeMKV, AnyDVD with no luck. Here is what we know...
fljoemon
#50 Post by fljoemon » Wed Mar 24, 2021 1:42 am
@metroplex2k7 .. these slim drives are NOT UHD friendly drives and there is no firmware available to downgrade them to UHD friendly drives. Hence they wont work with AnyDVD HD .. these however work great with MakeMKV when flashed with the appropriate firmware as mentioned on this thread.
EyzOnJim68
#51 Post by EyzOnJim68 » Sat Jan 22, 2022 6:45 am
I''ve purchased the same drive that arrived today and I'm going in circles trying to find the specific links to obtain what I need to flash the firmware but with no luck inside and outside of the forums.
Could you please reply with the links for:
SDFTool
BU40N Firmware 1.00
I would really appreciate it. Thanks in advance.
Jim Hernandez
____________________________________________________________________________
Drive Information Archgon md-8107s-u3-uhd
Product: BD-RE BU40N
Revision: 1.01
Serial number:
Firmware date: 2119-10-16 10:32
Bus encryption flags: 1F
Highest AACS version: 72
Harware support: Yes
Firmware support: No
Firmware version: 1.01
#52 Post by MartyMcNuts » Sat Jan 22, 2022 11:16 pm
EyzOnJim68 wrote: Sat Jan 22, 2022 6:45 am I''ve purchased the same drive that arrived today and I'm going in circles trying to find the specific links to obtain what I need to flash the firmware but with no luck inside and outside of the forums.
SDFTool
BU40N Firmware 1.00
Jim Hernandez
Revision: 1.01
Serial number:
I already replied to you in the other thread. Please don't ask the same question in multiple threads.
snagalin
#53 Post by snagalin » Sun Jan 23, 2022 2:10 am
I bought the same drive. Please let me know the firmware download link and instructions to flash to read 4K UHD discs.
#54 Post by MartyMcNuts » Sun Jan 23, 2022 9:54 pm
snagalin wrote: Sun Jan 23, 2022 2:10 am Hi,
Read the Ultimate UHD drives flashing guide 2022 or try using the search function.
Chipito
#55 Post by Chipito » Thu Aug 03, 2023 8:38 pm
I bought a patched drive with version 1.4.
It was patched with the Leowo UHD Drive Tool.
I will try to rip UHDs with DVDFAB and Makemkv at this weekend.
Is this patched version 1.4 ok, or should I downgrade to version 1.0 (if that is possible)?
Thank you very much.
Greetings :)
#56 Post by Billycar11 » Thu Aug 03, 2023 9:03 pm
Chipito wrote: Thu Aug 03, 2023 8:38 pm Hello,
Greetings :)
you paid $100+ dollars to do a firmware flash to a knock off program when we offer it for $25.
Chipito
#57 Post by Chipito » Thu Aug 03, 2023 9:17 pm
No, I already bought it flashed otherwise I would have definitely bought your package for 25$. A very fair price!
Just wanted to know if the 1.4 patched version is ok or if I should rather downgrade it to version 1.0.
It currently looks like this in MKV.
Drive information
Producer: HL-DT-ST
Revision: 1.04
Serial number: MO8N1UA3358
Firmware Date: 2120-05-06 11:42
Bus encryption marks: 17
Highest AACS version: 78
Firmware version: 1.04
#58 Post by Billycar11 » Thu Aug 03, 2023 9:20 pm
Chipito wrote: Thu Aug 03, 2023 9:17 pm No, I already bought it flashed otherwise I would have definitely bought your package for 25$. A very fair price!
Drive information
Producer: HL-DT-ST
Revision: 1.04
i recommend following the guide or go to 1.00 BU40N
Chipito
#59 Post by Chipito » Fri Aug 04, 2023 7:58 pm
I would like to buy your Tool for flashing to 1.0.
In my case I have no possibility, right?
Note 1: This product will not work for older drives that have a manufactured date prior to October 2015 and are not Drive Platform: MT1959.
My drive:
#60 Post by Billycar11 » Fri Aug 04, 2023 8:27 pm
Chipito wrote: Fri Aug 04, 2023 7:58 pm I would like to buy your Tool for flashing to 1.0.
My drive:
yes you could buy my flash tool or martys both of us have the option to flash down to 1.00 BU40N.
but you are likely fine with that fw try it out first.
