ShatteredGlass
Re: SDFtool Flasher
Post by ShatteredGlass »
MartyMcNuts wrote: Wed Jan 19, 2022 10:16 pm
ShatteredGlass wrote: Wed Jan 19, 2022 10:05 am I've been doing some testing and it seems that the only way to switch between MK firmware on a BP50NB40-NB50 is by using the "RECOVER" option in SDFtool Flasher. For example, a BP50NB40-NB50 that has 1.03 MK Firmware on it, I'm unable to downgrade to 1.01 unless I use the "RECOVER" option. Or if I'm on 1.01 and want to switch to 1.03 I must use the "RECOVER" option. Both of the MK Firmware's have "DE" set @ 0x1ec056 so I know that's not the issue. I'm able to use the "ASUS ODD FW Changer (Modified)" to switch firmware on the BP50NB40 no problem. Also, I can switch firmware on my WH16NS40 with SDFtool Flasher no problem, i.e. going from 1.05 to 1.03 and back to 1.05. So this only seems to be an issue with the BP50NB40.
Another thing I noticed is that if I try to switch from 1.03 to 1.01 on my BP50NB40 and I remove the "DE" byte from the MK Firmware and flash with SDFtool, it won't produce any error. The process will complete 100%, even though it doesn't actually downgrade. However, if I do the same thing with my WH16NS40 and try to switch from 1.05 to 1.03 with the "DE" by removed, SDFtool will throw a "Command produced error code 0x8f052400" error.
So why the differences between the two drives? Is this a bug or just by design?
LG have done something to the latest model BP50NB40 which causes these issues. We haven't figured out what that is yet ..
Ahhh ok, I was wondering what the issue was. Makes sense now. Thanks for the info.
vmax5000
Re: SDFtool Flasher
Post by vmax5000 »
I just purchased a new LG drive, see screenshot from MKV snip and I tried to downgrade the firmware from 1.05 to 1.02 but I keep getting the error shown in screenshot error. I am running windows 11, shouldn't make a difference I would think. Am I using the wrong firmware or is it some other issue? I tried both encrypted and unencrypted with the program but got the same error.
ShatteredGlass
Re: SDFtool Flasher
vmax5000 wrote: Sat Jan 22, 2022 9:03 pm I just purchased a new LG drive, see screenshot from MKV snip and I tried to downgrade the firmware from 1.05 to 1.02 but I keep getting the error shown in screenshot error. I am running windows 11, shouldn't make a difference I would think. Am I using the wrong firmware or is it some other issue? I tried both encrypted and unencrypted with the program but got the same error.
That's because you're trying to flash DE firmware. You need to use MK firmware from THIS THREAD
Last edited by ShatteredGlass on Sun Jan 23, 2022 6:05 am, edited 1 time in total.
Re: SDFtool Flasher
You cannot flash directly to WH16NS40 1.02 from the encrypted 1.05. Also, the best (and recommended) firmware for your drive is WH16NS60 1.02-MK, which can be flashed to directly.
vmax5000
Re: SDFtool Flasher
Post by vmax5000 »
Thanks guys, but I hate to sound dumb but where do I find the MK firmware? There seems to be a few links to firmware.
Sorry to bug you guys...
vmax5000
Re: SDFtool Flasher
Post by vmax5000 »
by ShatteredGlass » Sat Jan 22, 2022 1:17 pm
vmax5000 wrote: ↑
Sat Jan 22, 2022 1:03 pm
When I click on THIS THREAD it just takes me right back here...
vmax5000
Re: SDFtool Flasher
Post by vmax5000 »
I found it!
Thanks for your help.
poster72
Re: SDFtool Flasher
Post by poster72 »
Hope you can all bear with me here, lots of threads and lots of info, and i have tried many failed attempts. I have a WH15N60 which came with 1.03 encrypted firmware i think. Trying to flash it for use with UHD discs for backing up. I have tried the original BH14ns40_patched application, the ASUS_ODD_FW and now the SDFtool flasher. I attemtempted to flash my drive with the HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010. I get a desktop drive handshake error, trying slim drive handshake, and error code 0x8f052400 finally.
Can someone give me a hint here?
Product: BD-RE WH16NS6
Firmware date: 2120-05-08 10:10
Harware support: Yes
Firmware support: No
Firmware version: 1.03
USB 3.0 connected external enclosure
poster72
Re: SDFtool Flasher
Post by poster72 »
well ignore my previous post i apologize. I thought it was possible over usb, however docking it internally allowed me to do the downgrade.
Firmware version: 1.02
Re: SDFtool Flasher
poster72 wrote: Sun Jan 23, 2022 7:56 pm well ignore my previous post i apologize. I thought it was possible over usb, however docking it internally allowed me to do the downgrade.
Yes, it is possible over USB if you have a compatible enclosure or SATA to USB adapter.
poster72
Re: SDFtool Flasher
Post by poster72 »
I was using this enclosure from amazon, surprised it didn't work with the enclosure i guess?
Vantec NST-536S3-BK NexStar DX USB 3.0 External Enclosure for SATA Blu-Ray/CD/DVD Drive all black
https://www.amazon.com/gp/product/B01MR ... =UTF8&th=1
Re: SDFtool Flasher
poster72 wrote: Mon Jan 24, 2022 4:18 pm I was using this enclosure from amazon, surprised it didn't work with the enclosure i guess?
Yeah, apparently the new Vantec NST-536S3-BK enclsoures don't work for flashing anymore. The older one's do. I believe Vantec have changed the chip inside due to shortages.
MastaG
Re: SDFtool Flasher
Post by MastaG »
Any reason why I should choose the MK 1.02 over version 1.03?
I mean the latter is more recent right?
Re: SDFtool Flasher
MastaG wrote: Tue Jan 25, 2022 12:38 am Any reason why I should choose the MK 1.02 over version 1.03?
More recent does not mean better. The 1.03-MK is made from the encrypted firmware and is crap. Plenty of people have had issues with it. 1.02-MK is the recommended firmware. It reads good and is fast.
eatont9999
Re: SDFtool Flasher
Post by eatont9999 »
I just flashed my new LG WH16NS60 drive from its original 1.03 firmware to the MK/old/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin and selected non-encrypted. It seems to read Blu-ray discs but not UHD disks. It would read either one before the flash but I couldn't rip UHD disks, obviously. Now it just sits there seeking and MakeMKV says the disc is being loaded. It does not move from that status.
I had to connect it via SATA due to the recent Vantec issues. I did all flashing connected via SATA. Before it would give me a handshake error.
I tried version 1.01 and 1.03 but both do the same thing. Is it me doing something wrong or is this process not working with the latest drives. Mine was manufactured on 2021-08-18, SVC Code: NS60, ROM: 1.03.
Any help is appreciated.
