Morning -
I have read the section on trouble ripping. I have increased the number of passes to 10, and cleaned the disc. No the issue I am having is I get a message below; "NOT READY: Logical unit is in process of becoming ready". When reading disk it terminates with Type as "Data. I did Season 1 Disk 1 with no issues.
Is this a disk or drive issue? I have been ripping all day and had no other issues.
Running paid version on Windows 10
Dave
MakeMKV v1.16.5 win(x64-release) started
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive BU10 MOAL4AF5653' at offset '1048576'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive BU10 MOAL4AF5653' at offset '65536'
udf: UDF mount: reading in reserve VDS extent
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive BU10 MOAL4AF5653' at offset '98304'
udf: UDF mount: error reading volume space
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive BU10 MOAL4AF5653' at offset '32768'
Troubles
Re: Troubles
Your drive is not getting enough power use both USB connectors or a high powered USB hub
dtcjem
Re: Troubles
Thank You. Does that mean I should use both plugs on the drive? Is there another way to remedy?I
I appreicate the reply!
Dave
Dave
Re: Troubles
Yeah use both plugs if the light is still red get a higher powered USB hub like this https://smile.amazon.com/gp/product/B00 ... VXLJ&psc=1dtcjem wrote: Fri Jan 21, 2022 11:59 pm Thank You. Does that mean I should use both plugs on the drive? Is there another way to remedy?I
Dave
