Debug Error when trying to rip a 2nd 4K Bluray
frogurt
Post by frogurt » Wed Jan 19, 2022 6:49 pm
I get this debug code when trying to rip a second 4K bluray. First bluray rips fine, but I don't think it's a disc issue because rebooting fixes the issue, allowing me to rip the disc. Attempting a second disc causes problem to return. The workaround is to reboot after each disc.
DEBUG: Code 3221225664 at FCX0qMEkxy~zx6FI:121267362
Bug Behavior
1. Successfully rip a 4k bluray, no errors
2. Load second 4k bluray, get this makemkv error that keeps repeating over and over
3. Remove disk from drive, unplug drive, close makemkv
4. Plugin drive, no disk in drive, start makemkv, still get error (Error without a disc in the drive)
MakeMKV v1.16.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\user/MakeMKV_log.txt
DEBUG: Code 0 at ZdroV8Qdn>OkoZ=]P3i`_$c8:121261704
DEBUG: Code 3221225486 at ZdroV8Qdn>OkoZ=]P3i`_$c8:121261727
DEBUG: Code 3221225486 at %?"t/)^<UL<M76n|FU]):213130582
5. Reboot computer, try again. Everything works fine for that disc now.
6. Try to load a second disc, error returns
Here is the full debug log
Debug log started at Wed Jan 19 18:31:39 2022 , written by MakeMKV v1.16.5 win(x64-release)
001005:0000 MakeMKV v1.16.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\user/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at ZdroV8Qdn>OkoZ=]P3i`_$c8:121261704
001003:0020 DEBUG: Code 3221225486 at ZdroV8Qdn>OkoZ=]P3i`_$c8:121261727
001003:0020 DEBUG: Code 3221225486 at %?"t/)^<UL<M76n|FU]):213130582
DEBUG: Code 3 at kx/mIn.tna?p(7TlCFJMk\o%:29395310
SDF  v07f: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO2L4TB1116
Application exited at Wed Jan 19 18:39:29 2022
Specs
MakeMKV
- v1.16.5 (Registered)
Drive
- Archgon External (BU40N)
- Firmware flashed to 1.03 (Has been working fine for 10 4k discs previously)
- https://www.amazon.com/gp/product/B07BC ... UTF8&psc=1
- Plugged in both USB cables for enough power
Bluray causing issues:
- 4K UltraHD Lord of the Rings (fellowship, two towers, king all causing the same problem)
OS
- Windows 10 (64-bit)
Re: Debug Error when trying to rip a 2nd 4K Bluray
Post by dcoke22 » Fri Jan 21, 2022 4:31 pm
frogurt wrote: Wed Jan 19, 2022 6:49 pm 1. Successfully rip a 4k bluray, no errors
Does MakeMKV finish with a successful rip in the cases where it displays a debug message? Or does it never finish?
