Yep.leosantare wrote: Fri Jan 21, 2022 4:05 am I installed Java and finally the rip was successful. I don't understand, do only some UHD discs require Java? For example, I have been ripping standard blu rays for years and never needed Java.
Thank you,
Full Size Desktop 4K UHD Drive
Re: Full Size Desktop 4K UHD Drive
leosantare
Is Java only needed for ripping "some" 4K UHD discs and not regular blu ray discs?
For example, I have ripped over 80 regular blu ray discs and never came across needing Java.
Is needing Java for ripping 4K UHD discs becoming more common? (Meaning, more 4K UHD discs will require Java)
Will there be an update for makeMKV so that Java is not needed?
I now have (3) 4K UHD discs and two of them require Java.
As you may tell, I am not a fan of needing Java or any other 3rd party software to rip my discs.
