Directly Play 4K UHD BluRays ?
Re: Directly Play 4K UHD BluRays ?
#16 Post by Billycar11 » Thu Jan 20, 2022 1:43 pm
zarc987 wrote: Thu Jan 20, 2022 1:32 pm
I have a 1080 display, so I replace those numbers with 1080 ?
Yup and make sure the modes are supported by your monitor/tv
hardcore_gamer29
#17 Post by hardcore_gamer29 » Mon Feb 07, 2022 2:50 pm
zarc987 wrote: Thu Jan 20, 2022 1:39 am
Billycar11 wrote: Thu Jan 20, 2022 1:01 am Yes many
Mpc be with mad VR
VLC
Just check the integration box in makemkv for the program.
How come the playback lags a little, do I have to change some settings ?
if using vlc player, use 64bit then there will be no lag
IceCool
#18 Post by IceCool » Tue Feb 22, 2022 7:26 am
Hello.
I am using latest version of MakeMKV and VLC Video Player. I checked all boxes on integration tab, but VLC can't play blu ray. It says "disc is corrupted". With DVDFab passkey VLC play BDs. Drive is LG BU40N with DE firmware 1.0. How to configure MakeMKV and VLC to work together?
#19 Post by Billycar11 » Tue Feb 22, 2022 2:28 pm
IceCool wrote: Tue Feb 22, 2022 7:26 am Hello.
Do you own makemkv?
Integration only works if you own it
IceCool
#20 Post by IceCool » Wed Feb 23, 2022 12:37 am
Billycar11 wrote: Tue Feb 22, 2022 2:28 pm Do you own makemkv?
Thanks, i already figured it out. I activated trial period:) Now it's working.
