Directly Play 4K UHD BluRays ?
zarc987
Post by zarc987 » Thu Jan 20, 2022 12:57 am
Are there any free programs that directly play the 4K UHD discs out of the UHD drives ?
Re: Directly Play 4K UHD BluRays ?
Post by Billycar11 » Thu Jan 20, 2022 1:01 am
Yes many
Mpc be with mad VR
VLC
Just check the integration box in makemkv for the program.
zarc987
Post by zarc987 » Thu Jan 20, 2022 1:39 am
Billycar11 wrote: Thu Jan 20, 2022 1:01 am Yes many
Mpc be with mad VR
VLC
How come the playback lags a little, do I have to change some settings ?
Post by Billycar11 » Thu Jan 20, 2022 1:52 am
zarc987 wrote: Thu Jan 20, 2022 1:39 am
Mpc be with mad VR
VLC
What are you pc specs?
zarc987
Post by zarc987 » Thu Jan 20, 2022 1:54 am
Billycar11 wrote: Thu Jan 20, 2022 1:52 am What are you pc specs?
i7 9700K, ASUS Z390-P, 16GB RAM
Post by Billycar11 » Thu Jan 20, 2022 2:01 am
Any video card?
The 9700k does support h.265 decoding so it should be smooth you have you display set to 23.97 Hz? Usually that's the 23 option in the menu not 24
zarc987
Post by zarc987 » Thu Jan 20, 2022 2:45 am
Billycar11 wrote: Thu Jan 20, 2022 2:01 am Any video card?
The 9700k does support h.265 deciding so it should be smooth you have you display set to 23.97 Hz? Usually that's the 23 option in the menu not 24
No video card. What budget video cards do you recommend ?
Post by Billycar11 » Thu Jan 20, 2022 3:08 am
zarc987 wrote: Thu Jan 20, 2022 2:45 am
no video cards are reasonable at this time sadly
but your 9700K should work fine for h.265 decoding
do you change your refresh rate to 23hz or have mad vr do it automatically?
zarc987
Post by zarc987 » Thu Jan 20, 2022 3:13 am
Billycar11 wrote: Thu Jan 20, 2022 3:08 am no video cards are reasonable at this time sadly
I changed it in monitor, doesn't seem to have improved. How do I have MADVR automatically change refresh rate to 23 Hz ?
Post by Billycar11 » Thu Jan 20, 2022 3:20 am
zarc987 wrote: Thu Jan 20, 2022 3:13 am
zarc987
Post by zarc987 » Thu Jan 20, 2022 3:52 am
Billycar11 wrote: Thu Jan 20, 2022 3:20 am
Which buttons do I click or check ?
Post by Billycar11 » Thu Jan 20, 2022 4:02 am
zarc987 wrote: Thu Jan 20, 2022 3:52 am
right click in mpc go to madvr render settings
zarc987
Post by zarc987 » Thu Jan 20, 2022 4:14 am
Billycar11 wrote: Thu Jan 20, 2022 4:02 am right click in mpc go to madvr render settings
I mean, in the picture that you posted.
Post by Billycar11 » Thu Jan 20, 2022 7:06 am
zarc987 wrote: Thu Jan 20, 2022 4:14 am
you can just copy mine if you have a 4K display that supports all those modes mine actually has more up to 120 but i haven't updated it since no movie is 120hz lol
zarc987
Post by zarc987 » Thu Jan 20, 2022 1:32 pm
Billycar11 wrote: Thu Jan 20, 2022 7:06 am you can just copy mine if you have a 4K display that supports all those modes mine actually has more up to 120 but i haven't updated it since no movie is 120hz lol
I have a 1080 display, so I replace those numbers with 1080 ?
