dickcavett
#1
Post
by dickcavett » Tue Jan 18, 2022 8:56 pm
Brand-new DVD that plays fine on a DVD player, and in the DVD player app.
But when I run MakeMKV 1.16.5, I get the following errors when I try to open the disc:
MakeMKV v1.16.5 darwin(arm64-release) started
Optical drive "BD-RE MATSHITA BD-MLT UJ240ES 1.21 HK18 105982d" opened in OS access mode.
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE MATSHITA BD-MLT UJ240ES 1.21 HK18 105982' at offset '524288'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE MATSHITA BD-MLT UJ240ES 1.21 HK18 105982' at offset '1048576'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE MATSHITA BD-MLT UJ240ES 1.21 HK18 105982' at offset '32768'
Any ideas? Thank you.
dickcavett on Wed Jan 19, 2022 3:31 am, edited 1 time in total.
dickcavett
#2
Post
by dickcavett » Wed Jan 19, 2022 3:30 am
Tried again and got more messages:
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE MATSHITA BD-MLT UJ240ES 1.21 HK18 105982' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/VIDEO_TS/VTS_07_1.VOB' at offset '0'
Title #1 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 9-end were skipped due to cell commands (structure protection?)
Cells 27-end were skipped due to cell commands (structure protection?)
Title #4 in broken titleset was skipped
Title #5 in broken titleset was skipped
Title #6 in broken titleset was skipped
This seems to be copy protection and not a bad disc (the disc plays fine otherwise.)
dickcavett
#3
Post
by dickcavett » Wed Jan 19, 2022 3:32 am
I should mention I can't get Handbrake (with libdvdcss installed) to rip this successfully, either.
#4
Post
by MartyMcNuts » Wed Jan 19, 2022 4:15 am
dickcavett wrote: Wed Jan 19, 2022 3:32 am
I haven't ripped a DVD since about 2005!! Anyway, does the ole DVDShrink application still work? That's what I used to use way back when...
dickcavett
#5
Post
by dickcavett » Wed Jan 19, 2022 5:03 am
MartyMcNuts wrote: Wed Jan 19, 2022 4:15 am
I'm on a Mac, so it's not available to me. (I have access to a Windows PC, so maybe I will give it a try if I get the chance.) Part of me thinks it's unlikely that a 15-year-old app would more likely work than apps updated in 2021... but you never know.
Thank you for the suggestion!
#6
Post
by dcoke22 » Wed Jan 19, 2022 6:43 am
Is that drive powered via USB? Does it have two USB connectors and are they both connected either to the computer or two a powered USB hub? I wonder if your drive is running out of power.
dickcavett
#7
Post
by dickcavett » Wed Jan 19, 2022 6:23 pm
Great call! That was the problem! (Or at least, -a- problem. I'd suspected power might be an issue, but I never thought it would manifest itself with those kinds of errors.)
Thank you!
