Midway
preserve
Re: Midway
Post by preserve » Fri Nov 06, 2020 4:12 am
Woodstock wrote: Wed Nov 04, 2020 3:37 am Considering that it doesn't appear that anyone has volunteered to send the information Mike would need to fix it, it will probably continue to not choose correctly.
I am curious how active Mike is with working on this though, as I've submitted the required files before, including submitting one that MakeMKV identifies incorrectly, but those discs haven't been resolved.
Using: ASUS BW-16D1HT 3.00
Re: Midway
Post by Woodstock » Fri Nov 06, 2020 2:11 pm
Quite the valid question... Maybe he's devoting too much time toward that UHD stuff? :)
Krawk
Re: Midway
Post by Krawk » Tue Nov 10, 2020 12:52 am
This thread alone has user submissions, which should help some way.
Is there a digital signature users could send, along with what they have uncovered as the correct playlist?
I know the program tries to guess the right playlist based on java code, would analyzing and fixing the issue on a more recent movie fix the analysis heuristics to work on pretty much everything current and older?
We could take a Blu-ray player with 5 year old firmware and it analyzes and plays correctly, so I get that the software emulation is still not quite perfect.
kfreeb
Re: Midway
Post by kfreeb » Tue Dec 01, 2020 6:10 pm
Just finished checking the Blu-ray that came with the 4K version and this is the correct play list for the Blu-ray that was included with the 4K disc.
UPC code for the 4K cover art: UPC 31398 31416
Title information
Source file name: 00539.mpls
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Segment map: 504,510,501,507,502,505,506,509,503,508
File name: Midway_t119.mkv
UPDATE: Have sent to support, an image of the Midway disc so that they can figure out the Java scripting issue with this Blu-ray Disc that comes with the 4K UHD disc.
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
TwitchBronBron
Re: Midway
Post by TwitchBronBron » Wed Dec 09, 2020 5:23 pm
Blu-Ray + Dvd + Digital from Target online (UPC 0 3139831413 4 80).
Using DVDFab Passkey and VLC, looks like it's reading 00539.
12:11:50.3253416 PM	vlc.exe	10312	FileSystemControl	E:\BDMV\PLAYLIST\00539.mpls	INVALID DEVICE REQUEST	Control: 0x90390 (Device:0x9 Function:228 Method: 0)
12:11:50.3253565 PM	vlc.exe	10312	QueryAttributeInformationVolume	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS	FileSystemAttributes: Case Preserved, Case Sensitive, Unicode, Named Streams, Read Only, 0x1400200, MaximumComponentNameLength: 254, FileSystemName: UDF
12:11:50.3262666 PM	MsMpEng.exe	4352	CreateFileMapping	E:\BDMV\PLAYLIST\00539.mpls	FILE LOCKED WITH ONLY READERS	SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE|PAGE_NOCACHE
12:11:50.3262823 PM	MsMpEng.exe	4352	QueryStandardInformationFile	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS	AllocationSize: 4,096, EndOfFile: 2,302, NumberOfLinks: 1, DeletePending: False, Directory: False
12:11:50.3263434 PM	MsMpEng.exe	4352	ReadFile	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS	Offset: 0, Length: 2,302, I/O Flags: Non-cached, Paging I/O, Synchronous Paging I/O, Priority: Normal
12:11:50.7392307 PM	vlc.exe	10312	QueryStandardInformationFile	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS	AllocationSize: 4,096, EndOfFile: 2,302, NumberOfLinks: 1, DeletePending: False, Directory: False
12:11:50.7392629 PM	vlc.exe	10312	ReadFile	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS	Offset: 0, Length: 2,302, Priority: Normal
12:11:50.7393344 PM	vlc.exe	10312	ReadFile	E:\BDMV\PLAYLIST\00539.mpls	END OF FILE	Offset: 2,302, Length: 28,672, Priority: Normal
12:11:50.7394032 PM	vlc.exe	10312	ReadFile	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS	Offset: 2,298, Length: 4, Priority: Normal
12:11:50.7394359 PM	vlc.exe	10312	ReadFile	E:\BDMV\PLAYLIST\00539.mpls	END OF FILE	Offset: 2,302, Length: 28,672, Priority: Normal
12:11:50.7394577 PM	vlc.exe	10312	CloseFile	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS
12:11:51.5858357 PM	vlc.exe	10312	CreateFile	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS	Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, Write, AllocationSize: n/a, OpenResult: Opened
12:11:51.5872354 PM	vlc.exe	10312	QueryStandardInformationFile	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS	AllocationSize: 4,096, EndOfFile: 2,302, NumberOfLinks: 1, DeletePending: False, Directory: False
12:11:51.5872736 PM	vlc.exe	10312	ReadFile	E:\BDMV\PLAYLIST\00539.mpls	SUCCESS	Offset: 0, Length: 2,302, Priority: Normal
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
andrewskaterrr
Re: Midway
Post by andrewskaterrr » Fri Jul 09, 2021 12:33 am
I know I'm late to the party but I wanted to post my findings as a quick go-to for people because there's a lot of different versions. I compared each chapter in both rips to the Bluray's chapters using my PS3.
Retail 4K + Bluray + Digital
UPC: 0 3139831416 5
4K Disc:
Source file name: 00504.mpls
Segment count: 1
Segment map: (502,501,503,500,506,507,505)
File name: Midway_t91.mkv
Bluray Disc:
Segment count: 10
File name: Midway_t122.mkv
jayper
Re: Midway
Post by jayper » Fri Jul 09, 2021 2:17 pm
Have you re-scanned the disc with 1.16.4? There's enhancements that were made around identifying the correct title amongst multiple playlists.
redstang
Re: Midway
Post by redstang » Fri Jul 23, 2021 9:22 pm
For what it's worth, I upgraded to 1.16.4 and it didn't detect the primary playlist at all. In fact, that has never worked for me, it never even suggests one. I have java registered but it seems like it's not even trying.
dg928367
Re: Midway
Post by dg928367 » Tue Aug 10, 2021 12:58 pm
I'm running 1.16.4 and cannot rip this BD disc. The second title on the list seems to be the one others have used:
Title information
Name: Midway (English)
Comment: FPL_MainFeature
Duration: 2:18:24
Chapters count: 16
Segment count: 10
File name: Midway-FPL_MainFeature_t04.mkv
I end up with Read Error and HashCheck Errors. This disc is clean and looks good. I've used this drive for tons of other blu-rays. Do I need to patch the firmware?
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLAK6HF3247
Highest AACS version: 70
dg928367
Re: Midway
Post by dg928367 » Tue Aug 10, 2021 2:58 pm
I am running 1.16.4 and cannot rip a Midway BD (library copy). I found the playlists listed above but I get a sea of hash errors. The disc is very clean and my drive is good (I've used it for many other BDs). Any idea where to start?
centuryx476
Re: Midway
Post by centuryx476 » Sat Nov 27, 2021 11:16 pm
Hello All,
So just to be sure. Since there is multiple postings here
The .mpls is the below for the 4K disc?
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
MKVPlexRoku
Re: Midway
Post by MKVPlexRoku » Tue Jan 18, 2022 4:59 am
andrewskaterrr wrote: Fri Jul 09, 2021 12:33 am I know I'm late to the party but I wanted to post my findings as a quick go-to for people because there's a lot of different versions. I compared each chapter in both rips to the Bluray's chapters using my PS3.
UPC: 0 3139831416 5
4K Disc:
Segment count: 1
Thanks for this! Since I didn't find the other one everyone else was mentioning, your post was the one that led me to the right one.
zzeedd56
Re: Midway
Post by zzeedd56 » Fri Feb 11, 2022 7:41 pm
FYI....( java did not work for me on this disk)
however I am able to confirm
MIDWAY 2019 netflix blu ray version correct playlist as:
Title information
Source file name: 00741.mpls
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Segment map: 507,501,509,502,504,510,508,506,503,505
File name: Midway_t158.mkv
LordMustangGT
Re: Midway
Post by LordMustangGT » Thu Dec 29, 2022 8:13 pm
kfreeb wrote: Tue Dec 01, 2020 6:10 pm Just finished checking the Blu-ray that came with the 4K version and this is the correct play list for the Blu-ray that was included with the 4K disc.
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
This work with for my Bluray 1080p version, that came in my 4K case, as well. It was 00539, and all the segments were in the right order, but the file name was a different number, but it still was the right one. UPC was the same as well too. Also the 4K bluray version in this thread with the link to it, work aswell for the 4k version.
Asus x299 Rampage VI Extreme
Intel 7920x
32gb GSkill
Gigabyte Waterforce 3080Ti WB ver.
Asus 4k Bruray drive
Faber
Re: Midway
Post by Faber » Sat Jun 10, 2023 3:16 am
LordMustangGT wrote: Thu Dec 29, 2022 8:13 pm
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Even after finding the right title/playlist, did you still get the "FFMPEG_ERROR: FFDEC000: [truehd @ 0x7fb9b9d82380] No restart header present in substream" error messages?
