Slimline/Slotin drive for UHD
gubber
Post by gubber » Sun Jan 16, 2022 1:31 pm
Hello everyone,
for a HTPC projekt, I need a slimline/slotin drive and I would love it when I can use it as an UHD player.
I was not aware that UHD does not work that simple like a regular BD drive with anyDVD and I just purchased a Panasonic UJ267 (I can return it).
As I understood Panasonic drives can not hanel this, right?
Is there any usable slimline/slotin drive?
Maybe an LG CA30N?
But I find no clear answer if it supports BD-XL / UHD.
Thanks and regards,
Felix
Re: Slimline/Slotin drive for UHD
Post by Billycar11 » Sun Jan 16, 2022 1:36 pm
No ca30/40n
Can't do UHD
Get a BU40N and figure out how to make a tray load drive work no slot load drives do UHD yet
gubber
Post by gubber » Sun Jan 16, 2022 4:25 pm
Unfortunately there is no way to change the case (without makes it look like shit).
Do I have to expect issues with the UJ267 with regualr BDs?
myswe
Post by myswe » Sun Jan 16, 2022 9:00 pm
I am actually also looking for a slot-in drive (for my Node8 case). If there aren't any available at all, are there any external slot-in ones that maybe could get converted?
DataMeister
Post by DataMeister » Sat Oct 01, 2022 9:45 pm
I'm also looking for a UHD compatible, slimline, slot load drive. I found a couple external slimline drives like the Pioneer BDR-XS06T and BDR-XS07UHD, but I can't tell if those might could be disassembled and used in a regular laptop mount.
Post by Coopervid » Sat Oct 01, 2022 9:56 pm
Don't go for a Panasonic. They have even issues with BDs and regions. Look here. Get a LG BU40 or a Pioneer slim.
viewtopic.php?f=16&t=19634
DataMeister
Post by DataMeister » Sat Oct 01, 2022 10:01 pm
Coopervid wrote: Sat Oct 01, 2022 9:56 pm Don't go for a Panasonic. They have even issues with BDs and regions. Look here. Get a LG BU40 or a Pioneer slim.
The BU40 isn't a slot load. However the Pioneer BDR-XS07UHD is an external slot load. Does anyone know if the drive inside is SATA and could be mounted in a laptop?
Post by Coopervid » Sat Oct 01, 2022 10:18 pm
Sometimes you need to change the front part. Make sure your laptop hasn't any restrictions regarding brands and types. Or just get an USB enclosure.
Blackened2687
Post by Blackened2687 » Sun Oct 02, 2022 1:18 pm
DataMeister wrote: Sat Oct 01, 2022 10:01 pm However the Pioneer BDR-XS07UHD is an external slot load. Does anyone know if the drive inside is SATA and could be mounted in a laptop?
The drive inside has a USB connector soldered directly on the drive's PCB. It cannot be installed in the laptop, however, it can be installed in most SFF PC cases designed for laptop drives. To connect the drive to the motherboard it will require a special MB USB header adapter, which probably can be found in China.
DataMeister
Post by DataMeister » Fri May 26, 2023 9:45 pm
gubber wrote: Sun Jan 16, 2022 1:31 pm Hello everyone,
How did that Panasonic UJ-267 work out?
Post by Billycar11 » Fri May 26, 2023 9:47 pm
The pioneer xs07s flashed to xs07uhd from me is slot load and works with UHD contact details below if you want one
DataMeister
Post by DataMeister » Fri May 26, 2023 9:58 pm
Billycar11 wrote: Fri May 26, 2023 9:47 pm The pioneer xs07s flashed to xs07uhd from me is slot load and works with UHD contact details below if you want one
Will it mount in a slim optical bay like the Ncase M1 chassis has?
Post by Billycar11 » Fri May 26, 2023 10:19 pm
yes 12.7mm bays fit it but the case must have the built in felt if not it will shoot the discs out
JSR Enthusiast
Post by JSR Enthusiast » Wed Jul 23, 2025 1:17 am
Blackened2687 wrote: Sun Oct 02, 2022 1:18 pm The drive inside has a USB connector soldered directly on the drive's PCB. It cannot be installed in the laptop, however, it can be installed in most SFF PC cases designed for laptop drives. To connect the drive to the motherboard it will require a special MB USB header adapter, which probably can be found in China.
Alright, I have been passively watching for a Slim/Super-Slim (12.7mm/9.5mm) SLOT-loading UHD capable blu-ray for almost a decade. I have watched with strong curiosity at the BDR-XS07UHD to see if just ANYONE could buy and open the stupid thing, but still 5 years later there are no pictures of the internals online.
So we now have confirmation that it has a soldered connector like the 'modern' Apple SuperDrives.
Thank you.
So no go in laptops; I will kill the dream of cramming one in a unibody MBP. My other goal is putting one in a case like the Silverstone ML07, for future proof disc reading in a media center. UHD Ripping would be nice too, but I already have that.
So we simply need to convert the USB-C connection to the internal USB-C header on a motherboard, with something like this. Then, there is that stupid 'potentially-needed' DAC-003 AC Adapter that supplies 5V at 3A. Internally modding that sounds like a nightmare, so we would ideally just find a board that supports USB-C PD (The USB ports by default won't break 1.5A). I would wager anyone trying to use this drive is also using a SFF case and would be limited to mini-ITX boards.
Google AI spits out MINISFORUM BD795i SE and ROG STRIX B650E-I GAMING WIFI boards. Haven't verified, but it least there's potentially something.
Does all that check out?
But I am still hung up on why only older XS07 can be flashed (or why not older LG drives for that matter). What about the XS06? And why not newer XS07's? Why can't I open the actual bare drive, find the BIOS chip, and hook up my CH341 programmer? Is there a difference in controllers or other components in one or both of these units that makes the different FW's incompatible?
usernames-all-gone
Post by usernames-all-gone » Wed Apr 22, 2026 10:47 am
Billycar11 wrote: Sun Jan 16, 2022 1:36 pm no slot load drives do UHD yet
Is this still the case @Billycar11?
