Slimline/Slotin drive for UHD
Hello everyone,
for a HTPC projekt, I need a slimline/slotin drive and I would love it when I can use it as an UHD player.
I was not aware that UHD does not work that simple like a regular BD drive with anyDVD and I just purchased a Panasonic UJ267 (I can return it).
As I understood Panasonic drives can not hanel this, right?
Is there any usable slimline/slotin drive?
Maybe an LG CA30N?
But I find no clear answer if it supports BD-XL / UHD.
Thanks and regards,
Felix
Maybe an LG CA30N?
Thanks and regards,
Felix
Re: Slimline/Slotin drive for UHD
No ca30/40n
Can't do UHD
Get a BU40N and figure out how to make a tray load drive work no slot load drives do UHD yet
Can't do UHD
Unfortunately there is no way to change the case (without makes it look like shit).
Do I have to expect issues with the UJ267 with regualr BDs?
I am actually also looking for a slot-in drive (for my Node8 case). If there aren't any available at all, are there any external slot-in ones that maybe could get converted?
I'm also looking for a UHD compatible, slimline, slot load drive. I found a couple external slimline drives like the Pioneer BDR-XS06T and BDR-XS07UHD, but I can't tell if those might could be disassembled and used in a regular laptop mount.
Don't go for a Panasonic. They have even issues with BDs and regions. Look here. Get a LG BU40 or a Pioneer slim.
viewtopic.php?f=16&t=19634
The BU40 isn't a slot load. However the Pioneer BDR-XS07UHD is an external slot load. Does anyone know if the drive inside is SATA and could be mounted in a laptop?Coopervid wrote: ↑Sat Oct 01, 2022 9:56 pmDon't go for a Panasonic. They have even issues with BDs and regions. Look here. Get a LG BU40 or a Pioneer slim.
Sometimes you need to change the front part. Make sure your laptop hasn't any restrictions regarding brands and types. Or just get an USB enclosure.
The drive inside has a USB connector soldered directly on the drive's PCB. It cannot be installed in the laptop, however, it can be installed in most SFF PC cases designed for laptop drives. To connect the drive to the motherboard it will require a special MB USB header adapter, which probably can be found in China.DataMeister wrote: ↑Sat Oct 01, 2022 10:01 pmHowever the Pioneer BDR-XS07UHD is an external slot load. Does anyone know if the drive inside is SATA and could be mounted in a laptop?
How did that Panasonic UJ-267 work out?gubber wrote: ↑Sun Jan 16, 2022 1:31 pmHello everyone,
The pioneer xs07s flashed to xs07uhd from me is slot load and works with UHD contact details below if you want one
Will it mount in a slim optical bay like the Ncase M1 chassis has?Billycar11 wrote: ↑Fri May 26, 2023 9:47 pmThe pioneer xs07s flashed to xs07uhd from me is slot load and works with UHD contact details below if you want one
yes 12.7mm bays fit it but the case must have the built in felt if not it will shoot the discs out
