darknight
Post
by darknight » Thu Dec 23, 2021 8:40 pm
I just purchase BU40N and Vantec NST-510S3-BK 9.5mm Slim SATA Case from Amazon. I tried flashing using both makemkvcon64 and SDF tool and both of them said it was successful but the firmware hadn't actually changed.
The firmware I tried was:
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
OS device name: I:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO6LXXXXXXX
Bus encryption flags: 1F
Highest AACS version: 76
Does anyone have an idea why this is happening to me?
Post
by Woodstock » Thu Dec 23, 2021 10:26 pm
Did you reset the drive (power it down) after flashing? The new firmware will not load until the drive reboots.
darknight
Post
by darknight » Thu Dec 23, 2021 10:55 pm
Woodstock wrote: Thu Dec 23, 2021 10:26 pm
drive reboots.
I did and even tried on another computer.
Additional Information:
Amazon Link of the Drive:
https://www.amazon.com/HLDS-BU40N-Inter ... B07BSF41VW
It was built in Aug 2021.
Post
by Billycar11 » Fri Dec 24, 2021 12:45 am
That's a bit strange if it was build aug 21 it should have 1.04 but it has 1.02 but I also don't think 1.02 was originally from 2020
This maybe another case like the nb52 but just in case try it with enc if you haven't already
darknight
Post
by darknight » Fri Dec 24, 2021 1:02 am
Billycar11 wrote: Fri Dec 24, 2021 12:45 am
Hi Billy, I didn't try the ENC option because I didn't think 1.02 would have been encrypted. Guess what? It worked!
I know people were asking about the HLDS BU40N drives on these forums. Does that mean that the newer HLDS drives run an encrypted 1.02? Anyway, we have the answer if anyone asks.
paz1200
Post
by paz1200 » Thu Dec 30, 2021 1:11 am
Thanks Billy and darknight. I bought a BU40N off of Amazon and it had the same build date and firmware version. I also wasn't able to get the MK firmware to apply, but setting enc also did the trick. SDF Tool didn't recognize it as an encrypted firmware. Perhaps it's checking by version number? In any case, makemkvcon64 did the trick.
woogs
Post
by woogs » Fri Jan 07, 2022 5:39 am
I had this same issue. For anyone that can't find the enc checkbox. It appears to be gone from SDFtool flasher 1.3 but it is on 1.2, I was able to use 1.2 to flash.
mkv_andy
Post
by mkv_andy » Fri Jan 07, 2022 4:01 pm
Thank you for the clarification. I am having the same problem on a mac.
How do I activate the enc option on the command line?
More context: I am using `makemkvcon f -l` and then `makemkvcon f -d drivename rawflash main -i firmware.bin` I am quite confident that I have the general things right, because I can flash an older drive of the same kind (BU40N 1.03 Dec 2019 vs BU40N 1.04 Mar 2021) in the same enclosure.
mkv_andy
Post
by mkv_andy » Fri Jan 07, 2022 9:22 pm
I found it in another post myself. Just use ´enc´ instead of ´main´, i.e.
./makemkvcon f -d drivename -f sdf.bin rawflash enc -i firmware.bin
I am not sure if it is possible to also omit `-f sdf.bin` But now it works and I do not want to force my luck
dooferorg
Post
by dooferorg » Sun Jan 09, 2022 5:36 am
Just as an 'FYI' I recently bought an LG BU40N from Amazon and the manufacture date is May 2021. Firmware version 1.04. Successfully flashed with the HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin file from the MK firmware pack using SDFToolFlasher 1.3.1
tsu238
Post
by tsu238 » Sat Jan 15, 2022 11:37 pm
Well I thought I got mine to work based on mkv_andy and his advice about flashing it using enc instead of main. It did flash and now I have my Libredrive info displaying:
OS device name: /dev/rdisk2
Revision: 1.04
Serial number: MOEL91D4042
Firmware date: 2120-05-06 11:42
Highest AACS version: 56
Firmware version: 1.04
I did power off the drive (unplugging the USB and plugging back in). Closed MakeMKV and re-opened and again, my info showed. I used a BluRay and it read the disc and gave me the options to "download," but it eventually gives me the Error, Cant copy kinda message. I'm using a MAC and used terminal with "./makemkvcon f -d '/IOBDServices/AC377684' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin". At a loss now. Any advice would be terrific.
Post
by dcoke22 » Sun Jan 16, 2022 12:30 am
tsu238 wrote: Sat Jan 15, 2022 11:37 pm
If that's what MakeMKV tells you about your drive, then LibreDrive is enabled and you shouldn't need to flash your drive again.
A BU40N will rip a regular blu-ray without flashing. LibreDrive is needed to be able to rip UHDs.
If MakeMKV encountered an error while trying to rip your blu-ray, which is entirely possible, that's probably due to the disc being dirty and needing to be gently cleaned and not due to a firmware issue. If you can post your MakeMKV log, we can take a look. The bottom portion of the MakeMKV window is selectable. Control-Click or Right-Click to copy it.
