Neon Genesis Evangelion
BanquosGhost
#1 Post by BanquosGhost » Sat Jan 15, 2022 5:06 pm
I'm getting
DEBUG: Code 0 at ZkNy'P[;AHR3{9Bw:29396092
DEBUG: Code 0 at ZkNy'P[;AHR3{9Bw:29394850
for all five disks of this release. I sent the .tgz files for them to svq@makemkv.com around this time last week, but I'm still unable to rip them. Have I done something wrong, or should I simply continue to wait and try again next week?
Re: Neon Genesis Evangelion
#2 Post by Woodstock » Sat Jan 15, 2022 5:23 pm
First, is this a UHD release, or regular BD? The BD versions should not need to download keys... At least, mine did not.
If they are UHDs, I'll move this topic to the correct forum.
Are you getting any errors when MakeMKV tries to get the latest key file? At the top of the UHD Disk forum, the UHD FAQ may have your answer.
BanquosGhost
#3 Post by BanquosGhost » Sun Jan 16, 2022 9:29 am
I'm fairly sure it's regular BD. There's no mention of UHD on the case, and each disk is around 45-50 GB in size, if that helps pin it down.
I didn't see any errors when it tried to get the key file yesterday. I'm afraid I've lost that particular log now, but running just now gives me this in the log:
Debug log started at Sun Jan 16 09:23:02 2022 , written by MakeMKV v1.16.5 linux(x64-release)
001005:0000 MakeMKV v1.16.5 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/hrm/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.74.0/OpenSSL/1.1.1m/1.42.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at >^^([@W{uy/H_u_}~,S|(N:29393631
No  SDF v07f: PIONEER_BD-RW___BDR-207D_1.20_LDDL019630WL
SDF id v07f: PIONEER_BD-RW___BDR-207D_1.20_LDDL019630WL
003006:0000 Opening files on harddrive at file:///media/pipeline/ripped/EVA2
DEBUG: Code 2147483648 at FQ@4Ykl]Gj-yP7D=:121264625
003332:0000 Saved AACS dump file as file:///home/hrm/.MakeMKV/MKB_v76_Neon_Genesis_Evangelion_-_Disc_2_0E82.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at ZkNy'P[;AHR3{9Bw:29396092
001003:0020 DEBUG: Code 0 at ZkNy'P[;AHR3{9Bw:29394850
Two things here that may be relevant:
1) I mounted the disks on a headless server, used cp to copy the contents to my hard disk, and I'm running this on the copy from a different machine with a GUI on it. I haven't tried working this way before, so I don't know if it's a valid thing to be doing.
2) My BD drive is rather old.
#4 Post by Woodstock » Sun Jan 16, 2022 4:33 pm
OK, the issue may be the AACS v76 on the disks, although the current version of MakeMKV is supposed to handle that, even with an older drive.
I'm stumped at this point. I'd suggest following the FAQ link in my signature and send the information requested to support@makemkv.com so that Mike can look at it. This is separate from the .tgz file, and it can help when it's a "structure" problem, rather than encryption.
BanquosGhost
#5 Post by BanquosGhost » Sun Jan 16, 2022 7:27 pm
Thanks for looking at it. I'm glad it's not something silly I've done wrong. :)
I've sent the requested data for one of the disks to the support address. I'm assuming that only one will be needed to work out what the problem is, but can send the other four if necessary.
