Is the Asus sbw-s1 pro supported by libredrive
Paule
Post by Paule »
I can't find any info if it is supported nor if it's not supported.
Thanks.
Re: Is the Asus sbw-s1 pro supported by libredrive
If you're thinking "will it support UHD", the answer is an unqualified NO; it was built before the UHD specification existed.
Depending on the drive inside, it may be possible to use it a a LibreDrive for the other features of LD.
If you own it already, you can have MakeMKV look at its hardware and firmware and render a judgment. If you don't, it's probably not a good candidate to purchase.
