Vlc/application/vlc.app
Jman5150
Post by Jman5150 »
For this setting i assume it just allows the movie to play in vlc without damaging anything in the file.
My question is this..
If you scanned a movie without it and wanted it do you need to rescan or can it be added after the fact somehow?
Re: Vlc/application/vlc.app
Are you talking about VLC on the integration tab of MakeMKV preferences?
Jman5150
Post by Jman5150 »
Yep! Thats the one.
That integration enables VLC to use MakeMKV as the decryption engine to allow VLC to play discs.
If you've used MakeMKV to rip a disc and create a .mkv file, the copy protection that comes on discs has already been removed and VLC can play it on its own.
